Custom Component: HACS
Is it possible to use HACS along with the official github sensor here:
Can I use the same github access token for them both?
Just a thought:
It’s neither store, marketplace, bazaar, flea market, agora, or yard sale. No goods are exchanged for currency.
If it needs a ‘ring’ to it then there’s HACR as in Home Assistant Community Repository … because it’s a consolidated repository (so Home Assistant Consolidated Repository would work equally well).
Naming aside, the concept is great. Bringing together all these custom components and Lovelace plugins in one master-view is long overdue. Thanks for this!
I have been using it for a few days but after restart on the OVERVIEW the message is just No elements to show, open the store to install some awesome stuff.
I have like 4 cards installed and actually using it (example mini-media-player) and it appears on the store as it is not installed.
Raspberry pi 3b+
HACS version: 0.8.1
Home Assistant version: 0.94.3
Open an issue https://github.com/custom-components/hacs/issues/new?template=issue.md
So not to be pedantic but Persistent is spelt Persistent, not Peristant…
(But great automation. Thanks.)
Yes, and you can use the same token, but you should not.
Each integration should have it’s own token.
only one I couldnt install is:
It will be in by default in the next version.
https://github.com/custom-components/hacs/pull/132
Just wondering if Visual Studio Code add-on from @frenck is going to be added to HACS?
Why? How? Can you elaborate?
That is an add-on, not a custom component or lovelace card…
There is already a store for that, which is available on every Hass.io installation by default… :man_shrugging:
My problem is that I’m running Ubuntu in a Proxmox CT with HA in a virtual environment. I have not been able to install Visual Studio and get it to work.
Using that setup, does not give you add-ons, only Hass.io adds those features. On other setups you’ll have to do that yourself and is not controllable by anything around Home Assistant.
The VS Code addon looks to be here.
https://marketplace.visualstudio.com/items?itemName=keesschollaart.vscode-home-assistant
Not the same thing, this is off topic for this thread.
Please find/create another around this :slight_smile:
just changed from custom_updater to HACS. really impressive and much easier to handle!
However, i got a shortly flashing screen and the log tells me this error message
[homeassistant.core] Error doing job: Fatal error on transport
when i try to install the following components from the store:
  • mini-graph-card
  • bar card
  • Simple Thermostat
/ Ralf
As stated both in the OP here and in the documentation, please use GitHub for issues :slight_smile:
Thanks @frenck
Sorry buddy. I was hoping. By the way. Love the custom component.
Great Work :+1:
Ok, thanks, I’ll make a seperate token, I guess I could hit rate limits otherwise. :slight_smile:
