If you ever wanted to control your Jablotron from HA without connecting directly to it using USB you are on the right place.
Let me introduce you my first integration to control Jablotron remotely using Cloud API. Unfortunatelly Jablotron keeps local API closed and we have only those two options.
Here it is:
I’m open to your suggestions and comments below.
Btw. if anyone can find why first entity created by this integration takes 30s to update please let me know and I will fix it.
Tbh I never heard about jablotron in car. But if you are able to controll the alarm from jablotron cloud accessible on https://www.jablonet.net/ page then yes it should work for you as well.
PIN is mandatory parameter but if you enter random number it will not block the integration but you will not be able to controll sections of alarm that requires PIN.
In your log’s I see that integration was not able to detect any device. To see detailed logs you need to enable debug loggin on the integration.
Here is how:
I have the same issue :-/ Can anyone kindly update the status?
This is the only one integration which I am missing after migration from OpenHAB
many thanks
regards
Petr
The integration is great. Thanks for making it. Unfortunately I’m having some issues lately. I’m attaching the first log problem. I need to reload integration to make it work again. Any thoughts what could be wrong? Everything worked fine for whole last year.
Error requesting Jablotron data: HTTPSConnectionPool(host=‘api.jablonet.net’, port=443): Max retries exceeded with url: /api/2.2/serviceListGet.json (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7f4b04dc10>: Failed to establish a new connection: [Errno -3] Try again’))
