I am reasonably savvy with HomeAssistant, but not able to do the levels of programming to create a custom component.
Anyone with one of these care to give it a shot or have any tips on how I could pull information in (like a sensor for if its empty) via a template/sensor?
First of all, thanks for the awsome integration. I got it working and see the food state and desiccant state.
What I can’t se though is the feed_amount and feed_time. I also cannot give our cat a snack. I see it in the app, but it does not get dispensed.
any idea what i am doing wrong?
I tried to install the latest version (looks like March 11) and HA wouldn’t load it due to an error with the new button component. I just grabbed an older version of the init file from February since it didn’t look like anything else was changed and it seems to work now.
It looks like my feeders might not report the amount of food they’re holding. Feed amount is just showing 0 on both, and there’s food in them. I checked the service request data and the realAmountTotal attribute isn’t reported. It looks like this model just relies on the Status to tell when it’s low or out of food.
Hi guys, I will sound like a complete newby but I need your help
So I added and download the custom repo through HACS, then restarted HA. I tried to add the integration on the integration screen, but it tells me it needs to be added on configuration.yaml. No problem, I follow the documentation and add this to my config file (password removed here of course):
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
petkit:
# Single account
username: 31-minititof # Username of Petkit APP (小佩宠物), important to use country code
password: xxx # MD5 or Raw password
api_base: http://api.petkt.com/latest/ # Optional, default is China server: http://api.petkit.cn/6/
scan_interval: 00:02:00 # Optional, default is 00:02:00
feeding_amount: 10 # Optional, default is 10(g), also can be input_number entity id.
My region is the Netherlands so I used 31 as the country code.
But then my question is, now what? I don’t understand what I should do to be able to add a button that would start feeding my cat.
Maybe it has something to do with the Service section at the end of the doc; but I don’t know what to do with that.
If you’ve successfully added the custom integration, you should see new entities in HA.
Then, you should now have a switch entity which can be toggled to start the feeding process.
You can just add a switch card to your dashboard to add a feeder button.
Anyone have experience in the European region? I have downloaded the integration, set it up in yaml, but so far no entities are showing up for puramax. I enabled sharing in the app, tried switching to Chinese for the US region, but no response.
