[Custom Component] TP-Link Router Integration
Hi
I have a AX55 routeur
The Wifi6 buttons are greyed and so cant be used
Any reason / solution ?
thanks
Philippe
@pbranly Hi
It looks like the integration doesnt get info about wifi 6. Could you run this python code and post the result?
from tplinkrouterc6u import TplinkRouter
from logging import Logger
client = TplinkRouter('192.168.0.1', 'yourPassword', logger=Logger('test'))
client.authorize()
print(client.request('admin/status?form=all&operation=read', 'operation=read'))
Hi
Thanks for your help
I am not sure to use the good command
I have created a file ax55.py
I tried the command python ax55.py but my Linux said to use python3 ax55.py
The result is as follow
python3 ax55.py
File “/home/xxxxxxx/ax55.py”, line 1, in
ModuleNotFoundError: No module named ‘tplinkrouterc6u’
@pbranly
You need to install this client GitHub - AlexandrErohin/TP-Link-Archer-C6U: Python package for API access and management for TP-Link Routers. See supported routers list
run
pip install tplinkrouterc6u
mmm life is not so easy with pip !
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
I have tried the 2 proposed methods without success
Phil
edit:
I could install with the suffix --break-system-packages
mmmm this code generates a lot of informations but many are sensitive
Which one do you wish ?
Phil
@pbranly I need all data, but sensitive values you can mark as XXX (like macadress, ip, passwords)
Hi
I don’t care with local ips
Here is the file
{‘guest_2g5g_psk_key’: ‘’, ‘guest_5g_authentication_timeout’: ‘’, ‘wan_ipv4_netmask’: ‘255.255.255.0’, ‘wireless_2g_wds_status’: ‘disable’, ‘wireless_2g_wep_format2’: ‘hex’, ‘wireless_2g_mu_mimo’: ‘off’, ‘guest_5g_redirect’: ‘off’, ‘wan_ipv6_conntype’: ‘passthrough’, ‘wireless_5g_wep_key2’: ‘’, ‘iot_2g_psk_version’: ‘rsn’, ‘iot_2g_encryption’: ‘psk’, ‘storage_vendor’: ‘’, ‘iot_5g_hidden’: ‘off’, ‘wireless_2g_wep_type2’: ‘64’, ‘wireless_5g_wep_select’: ‘1’, ‘wireless_2g_psk_key’: ‘xxxxxxxx,’, ‘wireless_2g_wep_type1’: ‘64’, ‘wireless_5g_wep_type4’: ‘64’, ‘wan_ipv4_snddns’: ‘8.8.4.4’, ‘wireless_5g_extinfo’: {‘support_band’: ‘both’, ‘wds_guest_compatible’: ‘no’, ‘support_guest_dynpasswd’: ‘no’}, ‘guest_2g_hidden’: ‘off’, ‘wireless_2g_channel’: ‘auto’, ‘wireless_2g_wpa_version’: ‘auto’, ‘wireless_5g_psk_key’: ‘xxxxxxxxx,’, ‘guest_5g_redirect_url’: ‘’, ‘wireless_5g_wep_format2’: ‘hex’, ‘iot_2g_ssid’: ‘Ax55_phil_IoT_2.5G’, ‘wireless_5g_wep_key1’: ‘’, ‘lan_macaddr’: ‘ACxxxxxxx-58’, ‘wireless_2g_encryption’: ‘psk’, ‘wireless_2g_psk_cipher’: ‘aes’, ‘wireless_5g_port’: ‘1812’, ‘iot_5g_encryption’: ‘psk’, ‘wireless_5g_wpa_cipher’: ‘auto’, ‘guest_5g_disabled’: ‘off’, ‘wireless_5g_wep_type1’: ‘64’, ‘wireless_5g_disabled_by’: ‘’, ‘lan_ipv6_link_local_addr’: ‘FE80::AE15:xxxxxxxxxF58/64’, ‘guest_5g_portal_password’: ‘’, ‘wan_ipv6_snddns’: ‘::’, ‘wan_ipv6_pridns’: ‘::’, ‘wireless_2g_hidden’: ‘off’, ‘wireless_5g_wpa_key’: ‘’, ‘guest_isolate’: ‘off’, ‘wan_macaddr’: ‘AC-15-xxxxx59’, ‘wireless_5g_hidden’: ‘off’, ‘wireless_2g_wep_key4’: ‘’, ‘wireless_2g_disabled_all’: ‘off’, ‘wireless_5g_htmode’: ‘auto’, ‘wireless_2g_wep_key2’: ‘’, ‘guest_2g_psk_key’: ‘’, ‘guest_5g_psk_version’: ‘rsn’, ‘wireless_5g_server’: ‘’, ‘modem_type’: ‘Modem’, ‘modem_connstatus’: ‘0’, ‘wireless_5g_channel’: ‘auto’, ‘wan_ipv6_enable’: ‘off’, ‘guest_2g5g_psk_version’: ‘rsn’, ‘wireless_2g_wep_mode’: ‘auto’, ‘wireless_5g_wpa_version’: ‘auto’, ‘wireless_5g_wep_type3’: ‘64’, ‘wireless_5g_wds_status’: ‘disable’, ‘wireless_2g_wep_format3’: ‘hex’, ‘guest_5g_authentication_type’: ‘’, ‘wireless_5g_disabled’: ‘off’, ‘wireless_5g_wep_mode’: ‘auto’, ‘storage_available_unit’: ‘B’, ‘wireless_5g_wep_format4’: ‘hex’, ‘guest_2g5g_redirect_url’: ‘’, ‘storage_available’: 0, ‘printer_count’: 0, ‘wireless_5g_wep_type2’: ‘64’, ‘wireless_5g_wep_format1’: ‘hex’, ‘storage_capacity’: 0, ‘access_devices_wired’: [{‘wire_type’: ‘wired’, ‘macaddr’: ‘48-A6-xxxxxxx0’, ‘ipaddr’: ‘192.168.0.40’, ‘hostname’: ‘Sonos_port’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘B8-E9-xxxxx2’, ‘ipaddr’: ‘192.168.0.38’, ‘hostname’: ‘Sonos_salle_TV_HG’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘00-0E-xxxxx-8B’, ‘ipaddr’: ‘192.168.0.36’, ‘hostname’: ‘Sonos_playbar’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘AC-E2-xxxxxxx-9B’, ‘ipaddr’: ‘192.168.0.4’, ‘hostname’: ‘Imprimante_laser’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘00-0E-58-xxxxxx’, ‘ipaddr’: ‘192.168.0.32’, ‘hostname’: ‘Sonos_cuisine’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘B8-E9-xxxxxxxE’, ‘ipaddr’: ‘192.168.0.42’, ‘hostname’: ‘Sonos_salle_TV_HD’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘10-0C-xxxxxxx-4B’, ‘ipaddr’: ‘192.168.0.14’, ‘hostname’: ‘GE’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘00-0E-58-F2-96-BA’, ‘ipaddr’: ‘192.168.0.34’, ‘hostname’: ‘Sonos_salle_de_bain’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘94-C6-xxxxxxxxC1’, ‘ipaddr’: ‘192.168.0.8’, ‘hostname’: ‘xxxxxxxxxxx’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘B8-E9-xxxxxx8’, ‘ipaddr’: ‘192.168.0.44’, ‘hostname’: ‘Sonos_sub’}, {‘wire_type’: ‘wired’, ‘macaddr’: ‘00-11-xxxxxxx95’, ‘ipaddr’: ‘192.168.0.6’, ‘hostname’: ‘PHIL_SYNO’}], ‘lan_ipv6_ipaddr’: ‘FE80::xxxxxxxx/64’, ‘guest_2g_authentication_type’: ‘’, ‘modem_available’: 0, ‘guest_2g5g_portal_password’: ‘’, ‘guest_2g_authentication_timeout’: ‘’, ‘modem_signal’: ‘0%’, ‘wireless_2g_disabled’: ‘off’, ‘modem_status’: ‘0’, ‘modem_gateway’: ‘0.0.0.0’, ‘wireless_5g_encryption’: ‘psk’, ‘modem_ipaddr’: ‘0.0.0.0’, ‘guest_5g_hidden’: ‘off’, ‘guest_access’: ‘off’, ‘modem_ipv4_uptime’: ‘0’, ‘modem_pridns’: ‘0.0.0.0’, ‘guest_2g5g_authentication_type’: ‘’, ‘wireless_5g_disabled_all’: ‘off’, ‘guest_5g_extinfo’: {‘support_band’: ‘both’, ‘wds_guest_compatible’: ‘no’, ‘support_guest_dynpasswd’: ‘no’}, ‘wireless_5g_current_channel’: ‘36’, ‘modem_netmask’: ‘0.0.0.0’, ‘wireless_2g_wpa_cipher’: ‘auto’, ‘conn_type’: ‘0’, ‘iot_2g_hidden’: ‘off’, ‘guest_5g_encryption’: ‘none’, ‘wireless_2g_wep_key3’: ‘’, ‘modem_snddns’: ‘0.0.0.0’, ‘cpu_usage’: 0.13, ‘iot_2g_psk_key’: ‘xxxxxxx,’, ‘wireless_2g_wep_select’: ‘1’, ‘iot_2g_enable’: ‘on’, ‘iot_5g_psk_key’: ‘xxxxxxx,’, ‘access_devices_wireless_host’: [{‘wire_type’: ‘5G’, ‘macaddr’: ‘xxxxx0-A7’, ‘ipaddr’: ‘192.168.0.74’, ‘hostname’: ‘xxxx_iphone’}, {‘wire_type’: ‘5G’, ‘macaddr’: ‘18-B4-xxxxx-B9’, ‘ipaddr’: ‘192.168.0.56’, ‘hostname’: ‘Thermostat_nest’}, {‘wire_type’: ‘5G’, ‘macaddr’: ‘F4-03-xxxxx0’, ‘ipaddr’: ‘192.168.0.54’, ‘hostname’: ‘Amazon-Echo8’}, {‘wire_type’: ‘2.4G’, ‘macaddr’: ‘DC-54-xxxxxxA’, ‘ipaddr’: ‘192.168.0.12’, ‘hostname’: ‘Fire_TV’}, {‘wire_type’: ‘2.4G’, ‘macaddr’: xxxxx-18’, ‘ipaddr’: ‘192.168.0.16’, ‘hostname’: ‘LGwebOSTV’}, {‘wire_type’: ‘5G’, ‘macaddr’: ‘82-AB-xxxxx-F8’, ‘ipaddr’: ‘192.168.0.33’, ‘hostname’: ‘S21-de-Colette’}, {‘wire_type’: ‘2.4G’, ‘macaddr’: ‘70-Exxxxx-1A’, ‘ipaddr’: ‘192.168.0.58’, ‘hostname’: ‘Netatmo’}, {‘wire_type’: ‘5G’, ‘macaddr’: ‘1E-BC-xxxxx1-5D’, ‘ipaddr’: ‘192.168.0.39’, ‘hostname’: ‘network device’}, {‘wire_type’: ‘2.4G’, ‘macaddr’: ‘D6-xxxxxxx-0B’, ‘ipaddr’: ‘192.168.0.94’, ‘hostname’: ‘Philippe-Branly’}], ‘cpu1_usage’: 0.14, ‘mem_usage’: 0.4, ‘cpu2_usage’: 0.13, ‘wireless_wps_active’: ‘on’, ‘guest_2g_encryption’: ‘none’, ‘guest_2g5g_psk_cipher’: ‘aes’, ‘guest_2g_portal_password’: ‘’, ‘usb_storages’: {}, ‘modem_pinlock’: ‘0’, ‘guest_2g_disabled_by’: ‘’, ‘wireless_5g_wep_key4’: ‘’, ‘wireless_2g_ssid’: ‘ax55_phil’, ‘guest_5g_ssid’: ‘TP-Link_Guest_FF58_5G’, ‘wireless_2g_wep_format4’: ‘hex’, ‘wireless_2g_macaddr’: ‘AC-15-xxxxxx7’, ‘guest_2g_ssid’: ‘TP-Link_Guest_FF58’, ‘wireless_5g_psk_cipher’: ‘aes’, ‘iot_5g_disabled_by’: ‘’, ‘guest_2g5g_passwd_cycle’: ‘never’, ‘lan_ipv4_netmask’: ‘255.255.255.0’, ‘wireless_2g_airtime_fairness’: ‘off’, ‘guest_5g_enable’: ‘off’, ‘wireless_2g_wep_format1’: ‘hex’, ‘guest_2g_psk_version’: ‘rsn’, ‘wireless_2g_disabled_by’: ‘’, ‘guest_5g_disabled_by’: ‘’, ‘wan_ipv4_uptime’: 399709, ‘wan_ipv6_gateway’: ‘::’, ‘printer_name’: ‘None’, ‘wireless_2g_txpower’: ‘high’, ‘wireless_5g_airtime_fairness’: ‘off’, ‘guest_2g_psk_cipher’: ‘aes’, ‘wireless_2g_psk_version’: ‘rsn’, ‘iot_5g_disabled’: ‘off’, ‘wireless_5g_txpower’: ‘high’, ‘wireless_2g_current_channel’: ‘9’, ‘wireless_5g_mu_mimo’: ‘off’, ‘guest_2g_redirect’: ‘off’, ‘wireless_5g_hwmode’: ‘anacax_5’, ‘guest_2g_redirect_url’: ‘’, ‘wireless_2g_wps_state’: ‘configured’, ‘wireless_2g_extinfo’: {‘support_band’: ‘both’, ‘wds_guest_compatible’: ‘no’, ‘support_guest_dynpasswd’: ‘no’}, ‘wireless_5g_psk_version’: ‘rsn’, ‘guest_5g_psk_key’: ‘’, ‘wireless_2g_server’: ‘’, ‘iot_5g_psk_cipher’: ‘aes’, ‘wireless_5g_wep_format3’: ‘hex’, ‘wan_ipv4_ipaddr’: ‘192.168.1.107’, ‘guest_2g_extinfo’: {‘support_band’: ‘both’, ‘wds_guest_compatible’: ‘no’, ‘support_guest_dynpasswd’: ‘no’}, ‘lan_ipv6_assign_type’: ‘slaac’, ‘wireless_2g_port’: ‘1812’, ‘iot_5g_enable’: ‘on’, ‘lan_ipv4_ipaddr’: ‘192.168.0.1’, ‘wireless_2g_wep_key1’: ‘’, ‘wireless_2g_wep_type3’: ‘64’, ‘guest_5g_psk_cipher’: ‘aes’, ‘iot_2g_psk_cipher’: ‘aes’, ‘wireless_5g_enable’: ‘on’, ‘wireless_2g_htmode’: ‘auto’, ‘wireless_5g_ssid’: ‘ax55_phil’, ‘iot_2g_disabled_by’: ‘’, ‘guest_2g_disabled’: ‘off’, ‘guest_2g5g_authentication_timeout’: ‘’, ‘guest_2g5g_encryption’: ‘none’, ‘wireless_2g_enable’: ‘on’, ‘wireless_5g_macaddr’: ‘AC-15-xxxxxx56’, ‘lan_ipv4_dhcp_enable’: ‘On’, ‘wireless_2g_wpa_key’: ‘’, ‘iot_5g_ssid’: ‘Ax55_phil_IoT_5G’, ‘wireless_2g_hwmode’: ‘bgnax’, ‘iot_5g_psk_version’: ‘rsn’, ‘wireless_5g_wps_state’: ‘configured’, ‘wan_ipv4_pridns’: ‘8.8.8.8’, ‘guest_2g_enable’: ‘off’, ‘wireless_5g_wep_key3’: ‘’, ‘guest_2g5g_redirect’: ‘off’, ‘wireless_2g_wep_type4’: ‘64’, ‘wan_ipv6_ip6addr’: ‘::’, ‘storage_capacity_unit’: ‘B’, ‘wan_ipv4_conntype’: ‘dhcp’, ‘wan_ipv4_gateway’: ‘192.168.1.1’, ‘iot_2g_disabled’: ‘off’}
Phil
@pbranly Thanks!
Your router gives info about 2g and 5g network only. So there is no info about Wifi6
Hi thanks for the answer
This is my fear !
This router is supposed to support WiFi 6 .
Would you have any explanation ?
I must admit I don’t have any WiFi 6 menu either when accessing to the configuration pages
Strange ….
Phil
@pbranly I am afraid your router doesnt support WiFi 6 according router response. Also there is no WiFi 6 info in the router menu
I agree
Documentation is marketing oriented !
In this case, could you deactivate the sensors rather than having them greyed ?
Just an idea ….
Phil
Hi!
I have researched and I noticed nothing about the deco x55 been tested, could it work? I’m thinking to buy it but not sure if it doesn’t integrate…
Pablo
Hey, I just got the x55 and it does work with this plugin. Do note that it kicks you out of the web interface every time it polls, so just use the app.
And yes I made an account just for this
@i_made_an_account_ju Thank you! What is your router hardware version?
Archer C50 v3 00000001
Sorry for the delay, I ended up busy with other things
awaiting return :slight_smile:
please tell me, archer c3200 supports?
v1.15.1 Released
Changelog
  • Added support Archer BE805 v1.0
If you have Archer BE… router please try this integration and let me know.
@AlexandrErohin
I have the same issue with m5 1.7.4 Build 20231222 Rel. 63684.
TplinkRouter - TPLinkDecoClient - An unknown response - Expecting value: line 1 column 1 (char 0); Request admin/wireless?form=wlan - Response lvtIIV2nmloAp6wny+0lvP4AFdl2hfHoOTPCfM2Q/xK7NMXjbVsucJfg2HfAVZwY3tcLhxCrlADy3bUuLqYwaya8Z0JB/nNIjHioj4rUS5vLGLySZRqgZBQ2JDuv3fZCinO78jo+CCh3ZzVX3E7hT/o+krEqzgcFT/7KJ8GGMjIklqPBu0Ohs9Gj9Q8aCXxhRZvOAbzN5VCjRJh8t8IzmRXevJiJOi12HQ/NAD2xiNizZYk2b1QZeon0KcllnA+F8VYpuekT+kLs7SFJSKPYSUkYPKdO3T3h2S4KUmy0/LWDy86Xn5W4ObkHEOtlBUJeAPhVS1HD87+kWW/diUO5hRY71bw9lfhZVFubN+7aSf4=
As I dont have this router - It would be great if you could fix it in the client TP-Link-Archer-C6U/tplinkrouterc6u/client.py at 399b3ea6dea0e33b9b432b92dc117d8e9a54a400 ¡ AlexandrErohin/TP-Link-Archer-C6U ¡ GitHub
