[Custom Component] TP-Link Router Integration
Tnaks for your answer. I dont understand, what exactly should I do with clent.py
Hi all,
Let’s say at first that I’m not a developer, I’m a user / system administrator.
I bought a TP-Link MR600 v3,
added this integration to my home assistant and it works like a charm.
is there any way to get the LTE details on the dashboard?
ISP:
Network type: <3G / 4G / 4G LTE>
Band:
Data: xx.xxMB (Total Used)
Upload speed: x.x KB/s
Download speed: x.x KB/s
SIM Card Status: < status >
Signal Strength: xx%
RSRP: xx dBm
RSRQ: xx dB
SNR: xx dB
I got this info from the router status page, so logically the information should be available.
Thanks in advance
I have the Archer GX90 v1.0 and everything appears to be working.
Parental Controls would be amazing. Enabling/disabling my kids internet based on the Grocy Chore list has been something that I’ve been trying to implement. What do you need to possibly get this added?
EDIT: I submitted a new issue with the HAR file. If you need anything else, I’m happy to help.
Hi there, this looks really good!
Do you know if it would be possible to add a switch to trigger the Network Optimization feature?
Is there way to access my Archer C7 router if not the default login name is set (admin), but a different one?
I could not find this in the description.
Thank you in advance.
@bigyo Could you make a screenshot with a router login page?
v1.15.2 Released
Changelog
  • Added support Archer GX90 v1.0
  • Fixed wifi switches for Archer C1200
Can i wait for archer c64 support, or it is bad idea, and it will not be supported?
As I dont have this router - It would be great if you create PR with a new class for your router witch extends AbstractRouter
Where is easy manual, i see some code, in your link, how i can do it?
I must run some python commands, and send you results?
TP-Link AC1750 Archer C7
You router has different API, so it would be great if you could add support for your router by creating PR with a new class for your router witch extends AbstractRouter
