sure, thanks for your time!
import { LitElement, html, } from 'https://unpkg.com/@polymer/lit-element@^0.5.2/lit-element.js?module';
// Create your custom component
class DarkSkyWeatherCard extends LitElement {
// Declare properties
static get properties() {
return { hass: Object, config: Object, };
// ##### Define Render Template
_render( {hass, config }) {
// Handle Configuration Flags
var icons = this.config.static_icons ? "static" : "animated";
var sunLeft = this.config.sunset ? this.sunSet.left : "";
var sunRight = this.config.sunset ? this.sunSet.right : "";
// Build HTML
return html`
<style>
${this.style}
</style>
<ha-card class = "card">
<span class="icon bigger" style="background: none, url(/local/weather/animated/${this.weatherIcons[this.current.conditions]}.svg) no-repeat; background-size: contain;">${this.current.conditions}</span>
<span class="temp">${this.current.temperature}</span><span class="tempc">${this.getUOM('temperature')}</span>
<span>
<ul class="variations right">
<li><span class="ha-icon"><ha-icon icon="mdi:water-percent"></ha-icon></span>${this.current.humidity}<span class="unit"> %</span></li>
<li><span class="ha-icon"><ha-icon icon="mdi:gauge"></ha-icon></span>${this.current.pressure}<span class="unit"> ${this.getUOM('air_pressure')}</span></li>
${sunRight}
</ul>
<ul class="variations">
<li><span class="ha-icon"><ha-icon icon="mdi:weather-windy"></ha-icon></span>${this.current.windBearing} ${this.current.windSpeed}<span class="unit"> ${this.getUOM('length')}/h</span></li>
<li><span class="ha-icon"><ha-icon icon="mdi:weather-fog"></ha-icon></span>${this.current.visibility}<span class="unit"> ${this.getUOM('length')}</span></li>
${sunLeft}
</ul>
</span>
<div class="forecast clear">
${this.forecast.map(daily => html`
<div class="day fcasttooltip">
<span class="dayname">${(daily.date).toLocaleDateString(this.config.locale,{weekday: 'short'})}</span>
<br><i class="icon" style="background: none, url(/local/weather/animated/forecast/${this.weatherIcons[this.hass.states[daily.condition].state]}.svg) no-repeat; background-size: contain;"></i>
<br><span class="highTemp">${Math.round(this.hass.states[daily.temphigh].state)}${this.getUOM('temperature')}</span>
<br><span class="lowTemp">${Math.round(this.hass.states[daily.templow].state)}${this.getUOM('temperature')}</span>
<div class="fcasttooltiptext">${ this.config.tooltips ? this.hass.states[daily.summary].state : ""}</div>
</div>`)}
</div>
<br><span class="unit">${hass.states[this.config.entity_daily_summary].state}</span></br>
</ha-card>
// ##### windDirections" returns set of possible wind directions by specified language
get windDirections() {
const windDirections_en = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSW','SW','WSW','W','WNW','NW','NNW','N'];
const windDirections_fr = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSO','SO','OSO','O','ONO','NO','NNO','N'];
const windDirections_de = ['N','NNO','NO','ONO','O','OSO','SO','SSO','S','SSW','SW','WSW','W','WNW','NW','NNW','N'];
const windDirections_nl = ['N','NNO','NO','ONO','O','OZO','ZO','ZZO','Z','ZZW','ZW','WZW','W','WNW','NW','NNW','N'];
switch (this.config.locale) {
case "fr" :
return windDirections_fr;
case "de" :
return windDirections_de;
case "nl" :
return windDirections_nl;
default :
return windDirections_en;
// ##### dayOrNight : returns day or night depending opn the position of the sun.
get dayOrNight() {
const transformDayNight = { "below_horizon": "night", "above_horizon": "day", }
return transformDayNight[this.hass.states[this.config.entity_sun].state];
// ##### weatherIcons: returns icon names based on current conditions text
get weatherIcons() {
return {
'clear-day': 'day',
'clear-night': 'night',
'rain': 'rainy-5',
'snow': 'snowy-6',
'sleet': 'rainy-6',
'wind': 'cloudy',
'fog': 'cloudy',
'cloudy': 'cloudy',
'partly-cloudy-day': 'cloudy-day-3',
'partly-cloudy-night': 'cloudy-night-3',
'hail': 'rainy-7',
'lightning': 'thunder',
'thunderstorm': 'thunder',
'windy-variant': `cloudy-${this.dayOrNight}-3`,
'exceptional': '!!',
// ##### forecast : returns forcasted weather information for the next 5 days
get forecast() {
var forecastDate1 = new Date();
forecastDate1.setDate(forecastDate1.getDate()+1);
var forecastDate2 = new Date();
forecastDate2.setDate(forecastDate2.getDate()+2);
var forecastDate3 = new Date();
forecastDate3.setDate(forecastDate3.getDate()+3);
var forecastDate4 = new Date();
forecastDate4.setDate(forecastDate4.getDate()+4);
var forecastDate5 = new Date();
forecastDate5.setDate(forecastDate5.getDate()+5);
const forecast1 = { date: forecastDate1,
condition: this.config.entity_forecast_icon_1,
temphigh: this.config.entity_forecast_high_temp_1,
templow: this.config.entity_forecast_low_temp_1,
summary: this.config.entity_summary_1, };
const forecast2 = { date: forecastDate2,
condition: this.config.entity_forecast_icon_2,
temphigh: this.config.entity_forecast_high_temp_2,
templow: this.config.entity_forecast_low_temp_2,
summary: this.config.entity_summary_2, };
const forecast3 = { date: forecastDate3,
condition: this.config.entity_forecast_icon_3,
temphigh: this.config.entity_forecast_high_temp_3,
templow: this.config.entity_forecast_low_temp_3,
summary: this.config.entity_summary_3, };
const forecast4 = { date: forecastDate4,
condition: this.config.entity_forecast_icon_4,
temphigh: this.config.entity_forecast_high_temp_4,
templow: this.config.entity_forecast_low_temp_4,
summary: this.config.entity_summary_4, };
const forecast5 = { date: forecastDate5,
condition: this.config.entity_forecast_icon_5,
temphigh: this.config.entity_forecast_high_temp_5,
templow: this.config.entity_forecast_low_temp_5,
summary: this.config.entity_summary_5, };
return [forecast1, forecast2, forecast3, forecast4, forecast5];
// ##### current : Returns current weather information
get current() {
var conditions = this.hass.states[this.config.entity_current_conditions].state;
var humidity = this.hass.states[this.config.entity_humidity].state;
var pressure = Math.round(this.hass.states[this.config.entity_pressure].state);
var temperature = Math.round(this.hass.states[this.config.entity_temperature].state);
var visibility = this.hass.states[this.config.entity_visibility].state;
var windBearing = this.windDirections[(Math.round((this.hass.states[this.config.entity_wind_bearing].state / 360) * 16))];
var windSpeed = Math.round(this.hass.states[this.config.entity_wind_speed].state);
return {
'conditions': conditions,
'humidity': humidity,
'pressure': pressure,
'temperature': temperature,
'visibility': visibility,
'windBearing': windBearing,
'windSpeed': windSpeed,
// ##### sunSetAndRise: returns set and rise information
get sunSet() {
var nextSunSet = new Date(this.hass.states[this.config.entity_sun].attributes.next_setting).toLocaleTimeString(this.config.locale, {hour: '2-digit', minute:'2-digit'});
var nextSunRise = new Date(this.hass.states[this.config.entity_sun].attributes.next_rising).toLocaleTimeString(this.config.locale, {hour: '2-digit', minute:'2-digit'});
var sunLeft;
var sunRight;
var nextDate = new Date();
nextDate.setDate(nextDate.getDate() + 1);
if (this.hass.states[this.config.entity_sun].state == "above_horizon" ) {
nextSunRise = nextDate.toLocaleDateString(this.config.locale,{weekday: 'short'}) + " " + nextSunRise;
return {
'left': html`<li><span class="ha-icon"><ha-icon icon="mdi:weather-sunset-down"></ha-icon></span>${nextSunSet}</li>`,
'right': html`<li><span class="ha-icon"><ha-icon icon="mdi:weather-sunset-up"></ha-icon></span>${nextSunRise}</li>`,
} else {
if (new Date().getDate() != new Date(this.hass.states[this.config.entity_sun].attributes.next_rising).getDate()) {
nextSunSet = nextDate.toLocaleDateString(this.config.locale,{weekday: 'short'}) + " " + nextSunSet;
return {
'left': html`<li><span class="ha-icon"><ha-icon icon="mdi:weather-sunset-up"></ha-icon></span>${nextSunRise}</li>`,
'right': html`<li><span class="ha-icon"><ha-icon icon="mdi:weather-sunset-down"></ha-icon></span>${nextSunSet}</li>`,
// ##### style: returns the CSS style classes for the card
get style() {
// Get config flags or set defaults if not configured
var tooltipBGColor = this.config.tooltip_bg_color || "rgb( 75,155,239)";
var tooltipFGColor = this.config.tooltip_fg_color || "#fff";
var tooltipBorderColor = this.config.tooltip_border_color || "rgb(255,161,0)";
var tooltipBorderWidth = this.config.tooltip_border_width || "1";
var tooltipCaretSize = this.config.tooltip_caret_size || "5";
var tooltipWidth = this.config.tooltip_width || "110"
var tooltipLeftOffset = this.config.tooltip_left_offset || "-12"
var tooltipVisible = this.config.tooltips ? "visible" : "hidden"
return html`
.clear {
clear: both;
.card {
margin: auto;
padding-top: 2em;
padding-bottom: 1em;
padding-left: 1em;
padding-right:1em;
position: relative;
.ha-icon {
height: 18px;
margin-right: 5px;
color: var(--paper-item-icon-color);
.temp {
font-weight: 300;
font-size: 4em;
color: var(--primary-text-color);
position: absolute;
right: 1em;
.tempc {
font-weight: 300;
font-size: 1.5em;
vertical-align: super;
position: absolute;
right: 1em;
margin-top: -14px;
margin-right: 7px;
.variations {
display: inline-block;
font-weight: 300;
list-style: none;
margin-left: -2em;
margin-top: 4.5em;
.variations.right {
position: absolute;
right: 1em;
margin-left: 0;
margin-right: 1em;
.unit {
font-size: .8em;
.forecast {
width: 100%;
margin: 0 auto;
height: 9em;
.day {
display: block;
width: 20%;
float: left;
text-align: center;
border-right: .1em solid #d9d9d9;
line-height: 2;
box-sizing: border-box;
.dayname {
text-transform: uppercase;
.forecast .day:first-child {
margin-left: 20;
.forecast .day:nth-last-child(1) {
border-right: none;
margin-right: 0;
.highTemp {
font-weight: bold;
.lowTemp {
color: var(--secondary-text-color);
.icon.bigger {
width: 10em;
height: 10em;
margin-top: -4em;
position: absolute;
left: 0em;
.icon {
width: 50px;
height: 50px;
margin-right: 5px;
vertical-align: middle;
background-position: center center;
background-repeat: no-repeat;
text-indent: -9999px;
.weather {
font-weight: 300;
font-size: 1.5em;
text-align: left;
position: absolute;
top: -0.5em;
left: 6em;
word-wrap: break-word;
width: 30%;
.fcasttooltip {
position: relative;
.fcasttooltip .fcasttooltiptext {
visibility: hidden;
width: ${tooltipWidth}px;
background-color: ${tooltipBGColor};
color: ${tooltipFGColor};
text-align: center;
border-radius: 6px;
border-style: solid;
border-color: ${tooltipBorderColor};
border-width: ${tooltipBorderWidth}px;
padding: 5px 0;
/* Position the tooltip */
position: absolute;
z-index: 1;
bottom: 50%;
left: 0%;
margin-left: ${tooltipLeftOffset}px;
.fcasttooltip .fcasttooltiptext:after {
content: "";
position: absolute;
top: 100%;
left: 50%;
margin-left: -${tooltipCaretSize}px;
border-width: ${tooltipCaretSize}px;
border-color: ${tooltipBorderColor} transparent transparent transparent;
.fcasttooltip:hover .fcasttooltiptext {
visibility: ${tooltipVisible};
// ##### getUOM: gets UOM for specified measure in either metric or imperial
getUOM(measure) {
const lengthUnit = this.hass.config.unit_system.length;
switch (measure) {
case 'air_pressure':
return lengthUnit === 'km' ? 'hPa' : 'mbar';
case 'length':
return lengthUnit;
case 'precipitation':
return lengthUnit === 'km' ? 'mm' : 'in';
default:
return this.hass.config.unit_system[measure] || '';
setConfig(config) {
// if (!config.entity) {
// throw new Error('You need to define an entity');
this.config = config;
// The height of your card. Home Assistant uses this to automatically
// distribute all cards over the available columns.
getCardSize() {
return 3 //this.config.entities.length + 1;
customElements.define('dark-sky-weather-card', DarkSkyWeatherCard);
config:
# https://github.com/iammexx/home-assistant-config/tree/master/ui/darksky
- type: custom:dark-sky-weather-card
entity_sun: sun.sun
entity_daily_summary: sensor.dark_sky_daily_summary
entity_current_conditions: sensor.dark_sky_icon
entity_humidity: sensor.dark_sky_humidity
entity_pressure: sensor.dark_sky_pressure
# entity_apparent_temp: sensor.dark_sky_apparent_temperature
entity_temperature: sensor.dark_sky_temperature
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.dark_sky_wind_bearing
entity_wind_speed: sensor.dark_sky_wind_speed
entity_forecast_high_temp_1: sensor.dark_sky_forecast_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_forecast_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_forecast_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_forecast_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_forecast_daytime_high_temperature_5
entity_forecast_low_temp_1: sensor.dark_sky_forecast_overnight_low_temperature_0
entity_forecast_low_temp_2: sensor.dark_sky_forecast_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_forecast_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_forecast_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_forecast_overnight_low_temperature_4
entity_forecast_icon_1: sensor.dark_sky_forecast_icon_1
entity_forecast_icon_2: sensor.dark_sky_forecast_icon_2
entity_forecast_icon_3: sensor.dark_sky_forecast_icon_3
entity_forecast_icon_4: sensor.dark_sky_forecast_icon_4
entity_forecast_icon_5: sensor.dark_sky_forecast_icon_5
entity_summary_1: sensor.dark_sky_forecast_summary_1
entity_summary_2: sensor.dark_sky_forecast_summary_2
entity_summary_3: sensor.dark_sky_forecast_summary_3
entity_summary_4: sensor.dark_sky_forecast_summary_4
entity_summary_5: sensor.dark_sky_forecast_summary_5
tooltips: true
static_icons: false
sunset: true
locale: nl
tooltip_bg_color: 'rgb( 75,155,239)'
tooltip_border_color: orange
tooltip_border_width: 1
tooltip_caret_size: 10
tooltip_fg_color: '#fff'
tooltip_left_offset: -5
tooltip_width: 100
resource:
- url: /local/lovelace/resources/dark-sky-weather-card.js?v=7.2
type: module
image files:
