Ahh! Thanks, alignment has been restored! Sorry for the repeat query.
And for the observant of you; that today high reading is correct, it IS 38 degrees Celsius in Sydney today. 100.4 F. Melting hot!
New Version is available
Note This version has been modified to work correctly with the latest version of HA 86.x. If you are using 85.1 or below you will likely need to adjust the top-margin of the temperature otherwise it will be misaligned. Use the temp_top_margin flag to specify a new margin. ā5pxā is a good place to start.
Iāve gone back to defaults now for this and it looks great againā¦
are you using lovelace in Yaml mode? I disabled yaml mode and mine does not work at all.
Have you tried copying your ui-lovelace.yaml file to the clipboard (the whole file) and then opening lovelace editor in raw editor and overwriting it with that? THere is no reason yaml or storage mode will produce a different result other than there being a difference in the respective configurations.
Thanks David, worked like charm
I use a card-modder to design my lovelace.
Since last update 0.86.2 I get an error:
/local/custom_ui/card-modder.js:44:23 Uncaught TypeError: this.card.style.setProperty is not a function
what could be the problem?
You can see more information in my github - https://github.com/abeksis/My-HomeAssistant-Config
- type: custom:card-modder
card:
type: custom:dark-sky-weather-card
entity_sun: sun.sun
entity_daily_summary: sensor.dark_sky_daily_summary
entity_current_conditions: sensor.dark_sky_icon
entity_humidity: sensor.dark_sky_humidity
entity_pressure: sensor.dark_sky_pressure
entity_temperature: sensor.dark_sky_temperature
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.dark_sky_wind_bearing
entity_wind_speed: sensor.dark_sky_wind_speed
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_0
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4
entity_forecast_icon_1: sensor.dark_sky_icon_1
entity_forecast_icon_2: sensor.dark_sky_icon_2
entity_forecast_icon_3: sensor.dark_sky_icon_3
entity_forecast_icon_4: sensor.dark_sky_icon_4
entity_forecast_icon_5: sensor.dark_sky_icon_5
entity_summary_1: sensor.dark_sky_summary_1
entity_summary_2: sensor.dark_sky_summary_2
entity_summary_3: sensor.dark_sky_summary_3
entity_summary_4: sensor.dark_sky_summary_4
entity_summary_5: sensor.dark_sky_summary_5
locale: en
static_icons: false
tooltip_bg_color: 'rgb( 75,155,239)'
tooltip_border_color: orange
tooltip_border_width: 3
tooltip_caret_size: 10
tooltip_fg_color: '#fff'
tooltip_left_offset: -12
tooltip_width: 100
tooltips: true
old_daily_format: false
time_format: 24
show_beaufort: true
show_separator: true
style:
background-image: url("/local/lovelace/background/cardbackk.png")
background-repeat: no-repeat
background-color: rgba(50,50,50,0.3)
background-size: 100% 68px
border-radius: 20px
border: solid 1px rgba(100,100,100,0.3)
box-shadow: 3px 3px rgba(0,0,0,0.4)
overflow: hidden
I get this as well. Exact same error. Iāve already asked @thomasloven who develops card-modded. Iām just waiting for his reply.
I saw that you responded to him ā¦ I also wrote him ā¦ Still no answer
Iāve been using an older version of Dark Sky Weather card and have been watching this thread with interest. Today I installed the latest version (with temp_top_margin: 5px as suggested - Iām still on 0.85.1, and using YAML mode). It is really amazing and I am so happy with it. Many, many thanks to @m.p.frankland and everyone who has contributed!
Iām trying to limit the crazy amount of Dark Sky data coming in to HA. It seems to me that some of the monitored conditions included in the sensor arenāt actually used for anything. These would be
nearest_storm_distance
nearest_storm_bearing
apparent_temperature_high
apparent_temperature_low
uv_index
Can I remove these from the sensor, or am I missing something?
For those who use card-modder, Iāve just made an update to it to handle this card.
For @m.p.frankland
Iām by no means a java developer but Iā¦ donāt think this is a good ideaā¦
get
functions are for things you wish to expose outside of your element. Is it vital that other card can read (but not edit) the styles of your card?
A better way, in my amateur opinion, would be to replace that line with style() {
and this one with ${this.style()}
. You might want to do that to other properties-that-should-be-functions as well.
Thanks a lot, works great.
No I donāt think you are.
Anything not used by this card or by you anywhere else can be removed.
But you could just comment them out for now to make sure it doesnāt break anything else.
Hey all - I just tried adding this to my HASS server and lovelace config, but I canāt seem to get it working. Iāve followed the directions on the git, set up my Dark Sky sensor properly and then put everything into my lovelace config, but nothing is showing up where the card should be. I am putting it between two cards, and I just get an extra space between the cards. Without custom card:
With custom card:
I am not seeing any errors in the log, although I am logging at warning. I did switch the log back to debug, and I can see debug messages for the card, but no errors. Iāve even removed the ?v=7.1 from the end of the URL in the resource in lovelace to see if that was causing a problem, and it kicked out an error in the log so I know that did something. Iāve even double checked that Iāve got the files in the right place also:
Any ideas what I could be doing wrong here?
try refreshing your browser (ctrl-F5 for chrome).
Hi, thank you for your hard work. Everything is working perfectly. I just would like to ask you, if entity_pop_intensity could be rounded like value_template: "{{ states.sensor.dark_sky_precip_intensity.state | round(1) }}"
Thank you
Thanks, I had already tried that before posting with no change. I just tried it again with the same results. Any other ideas?
try posting your config for the card. maybe thereās something in there that isnāt right that youāre not seeing.
Hereās the lovelace config for the resource:
resources:
- url: /local/custom_ui/dark-sky-weather-card.js?v=7.1
type: module
And hereās the actual card config:
- type: 'custom:dark-sky-weather-card'
Iāve even tried removing the quotes from the card name for type: but that didnāt make any difference either.
Everything looks the same in my working config as yours does above.
Iām having some funky stuff going on with my lovelace in that I need to restart my HA (instead of just a browser refresh) on every change to the config. Which is really annoying and I need to figure out whyā¦
But try a restart to see if that might fix it.
