Get the latest update for the card (link below). There was something that was stopping that url from working. I think it was done by unpkg themeselves. The latest update to the card looks like it gets lit-element from somewhere in HA itself.
I have
resources:
- url: /local/custom_ui/dark-sky-weather-card.js?v=7.1
type: module
Can see a card, but any time I hit refresh error in log:
Log Details (ERROR)
Wed Jan 30 2019 21:23:45 GMT-0500 (Eastern Standard Time)
https://xxxxxxxxx.duckdns.org/local/custom_ui/dark-sky-weather-card.js?v=7.1:682:0 NotSupportedError: Operation is not supported
You have version 7.1. Latest is 8.3.
Changed to 8.3.
Log Details (ERROR)
Wed Jan 30 2019 22:00:15 GMT-0500 (Eastern Standard Time)
https://xxxxxxxxx.duckdns.org/local/custom_ui/dark-sky-weather-card.js?v=8.3:682:0 NotSupportedError: Operation is not supported
Unless you are using the card tracker card and scripts the version number isn’t relevant. It used to be that the number needed to change everytime you wanted to load a new version of the card. That is not the case anymore. As mentioned above the card tracker does use the version number to know what version it thinks you have and compares it to the version number on github. If you are not using card tracker then the v= number can be anything you want and will likely be different for each person using the card depending on when they stopped incrementing it to get new versions of the card to load.
Line 682 is
customElements.define('dark-sky-weather-card', DarkSkyWeatherCard);
Which is the command to register the card in HA / Lovelace.
Are there any errors in the chrome developer tools console?
Not using card tracker card.
I’ll check chrome developer tools console.
Commented out
custom_ui: local
in customizer:
and error stop appearing in log
I’ve fought with getting this to work for this whole week and I’ve given up fighting on my own. Hopefully someone here can figure out what’s going on. I’m running Hassio 0.86.3. I’ve updated to dark-sky-card.js v8.3. I’ve cleared out everything on my lovelace editor to only display this. I fought past the card doesn’t exist errors and now I’m to a blank screen. I get the tab named “weather” and one with the mdi cloudy icon, but neither have anything in them. Running this in chrome.
Lovelace raw config editor:
resources: - url: /local/custom_ui/dark-sky-weather-card.js?v=8.3 title: Home Assistant type: module views: - icon: 'mdi:weather-cloudy' - cards: null entity_apparent_temp: sensor.dark_sky_apparent_temperature entity_current_conditions: sensor.dark_sky_icon entity_current_text: sensor.dark_sky_current_text entity_daily_summary: sensor.dark_sky_daily_summary entity_daytime_high: sensor.dark_sky_daytime_high_temperature_0 entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1 entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2 entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3 entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4 entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5 entity_forecast_icon_1: sensor.dark_sky_icon_1 entity_forecast_icon_2: sensor.dark_sky_icon_2 entity_forecast_icon_3: sensor.dark_sky_icon_3 entity_forecast_icon_4: sensor.dark_sky_icon_4 entity_forecast_icon_5: sensor.dark_sky_icon_5 entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_0 entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1 entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2 entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3 entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4 entity_humidity: sensor.dark_sky_humidity entity_pop: sensor.dark_sky_precip_probability entity_pop_1: sensor.dark_sky_precip_probability_1 entity_pop_2: sensor.dark_sky_precip_probability_2 entity_pop_3: sensor.dark_sky_precip_probability_3 entity_pop_4: sensor.dark_sky_precip_probability_4 entity_pop_5: sensor.dark_sky_precip_probability_5 entity_pop_intensity: sensor.dark_sky_precip_intensity entity_pressure: sensor.dark_sky_pressure entity_summary_1: sensor.dark_sky_summary_1 entity_summary_2: sensor.dark_sky_summary_2 entity_summary_3: sensor.dark_sky_summary_3 entity_summary_4: sensor.dark_sky_summary_4 entity_summary_5: sensor.dark_sky_summary_5 entity_sun: sun.sun entity_temperature: sensor.dark_sky_temperature entity_visibility: sensor.dark_sky_visibility entity_wind_bearing: sensor.dark_sky_wind_bearing entity_wind_speed: sensor.dark_sky_wind_speed locale: en old_daily_format: false show_beaufort: true static_icons: false time_format: 24 title: Weather tooltip_bg_color: 'rgb( 75,155,239)' tooltip_border_color: orange tooltip_border_width: 3 tooltip_caret_size: 10 tooltip_fg_color: '#fff' tooltip_left_offset: -12 tooltip_width: 100 tooltips: true type: 'custom:dark-sky-weather-card' Sensors.yaml: - platform: darksky api_key: [redacted] forecast: - 0 - 1 - 2 - 3 - 4 - 5 monitored_conditions: - icon - summary - nearest_storm_distance - nearest_storm_bearing - humidity - temperature - temperature_high - temperature_low - apparent_temperature - apparent_temperature_high - apparent_temperature_low - wind_speed - wind_bearing - precip_type - precip_probability - precip_accumulation - precip_intensity - precip_intensity_max - uv_index - daily_summary - pressure - visibility update_interval: minutes: 10
when I run the console, the errors I see 2 errors:
error 1:
[Deprecation] HTML Imports is deprecated and will be removed in M73, around March 2019. Please use ES modules instead. See Chrome Platform Status for more details.
error 2:
Unknown resource type specified: undefined
1 issue I think could cause this is the sensor dark-sky-current-text. I don’t know where to put that. I’ve tried my sensors.yaml, but can’t get the config to accept that. I doubt that’s causing the entire card to show up blank though.
Any ideas or help here? I’d greatly appreciate it as I’m out of ideas as I’ve read through this whole thread and tried everything.
your config is pretty messed up.
you need to move things around and indent correctly.
try this:
resources:
type: module
cards:
- type: 'custom:dark-sky-weather-card'
## optional ##
entity_sun: sun.sun
show_separator: True
Yes, sorry. It was late and I had to edit post to get the quote to display properly. It lost the formatting when I did that. It was mostly formatted like yours, but for the sake of checking, I copied/pasted your config and checked that as well. Same thing. Nothing is showing…
This did present a new error though:
Uncaught (in promise) TypeError: Cannot read property 'state' of undefined at HTMLElement.render (dark-sky-weather-card.js?v=8.3:26) at HTMLElement.update (app-3b4bb4ed.js:377) at HTMLElement.performUpdate (app-3b4bb4ed.js:344) at HTMLElement._enqueueUpdate (app-3b4bb4ed.js:344)
Here’s my sensors.yaml as well.
- platform: darksky
api_key: [redacted]
forecast:
- 0
- 1
- 2
- 3
- 4
- 5
- icon
- summary
- humidity
- temperature
- temperature_high
- temperature_low
- wind_speed
- wind_bearing
- precip_type
- precip_intensity
- uv_index
- daily_summary
- pressure
- visibility
update_interval:
minutes: 10
The template sensor goes into either configuration.yaml or if you break out your sensors into sensors.yaml, it can go there as well. As it is HA configuration level you must restart HA for it to take effect.
It looks like you are including entity_current_text in your lovelace card config. If you do not have a valid sensor.dark_sky_current_text entity (see above) it will cause the error you are seeing which in turn will break the card. That entity is optional so if you don’t have the template sensor setup just remove that line from the card config in lovelace.
The Readme file lists all the optional entities and provides an example of how to setup this specific template sensor. It assumes you already know how to setup template sensors in general. If you don’t, there is documentation on how to setup them up here.
It appears the two minor mistakes I made were including the incomplete entity_current_text and some incorrect formatting of the config. It is now working. Thank you both for your replies. I had nearly given up on getting this working. I have my templates card and I did see the optional entities (but I had missed that the entity_current_text was optional, so thank you for pointing that out). Appreciate the help!
I also can’t get it to work (did everything as per instructions I think, maybe i’ve missed something), here is my raw editor config and relevant bits from configuration yaml:
Hopefully you can help me since i’m going crazy staring and trying different things for hours
What error are you having?
That it doesnt exist.
Custom element doesn't exist: dark-sky-weather-card.
“type”: “custom:dark-sky-weather-card”,
“entity_current_conditions”: “sensor.dark_sky_icon”,
“entity_temperature”: “sensor.dark_sky_temperature”,
“entity_forecast_high_temp_1”: “sensor.dark_sky_daytime_high_temperature_1”,
“entity_forecast_high_temp_2”: “sensor.dark_sky_daytime_high_temperature_2”,
“entity_forecast_high_temp_3”: “sensor.dark_sky_daytime_high_temperature_3”,
“entity_forecast_high_temp_4”: “sensor.dark_sky_daytime_high_temperature_4”,
“entity_forecast_high_temp_5”: “sensor.dark_sky_daytime_high_temperature_5”,
“entity_forecast_icon_1”: “sensor.dark_sky_icon_1”,
“entity_forecast_icon_2”: “sensor.dark_sky_icon_2”,
“entity_forecast_icon_3”: “sensor.dark_sky_icon_3”,
“entity_forecast_icon_4”: “sensor.dark_sky_icon_4”,
“entity_forecast_icon_5”: “sensor.dark_sky_icon_5”,
“entity_forecast_low_temp_1”: “sensor.dark_sky_overnight_low_temperature_0”,
“entity_forecast_low_temp_2”: “sensor.dark_sky_overnight_low_temperature_1”,
“entity_forecast_low_temp_3”: “sensor.dark_sky_overnight_low_temperature_2”,
“entity_forecast_low_temp_4”: “sensor.dark_sky_overnight_low_temperature_3”,
“entity_forecast_low_temp_5”: “sensor.dark_sky_overnight_low_temperature_4”,
“entity_summary_1”: “sensor.dark_sky_summary_1”,
“entity_summary_2”: “sensor.dark_sky_summary_2”,
“entity_summary_3”: “sensor.dark_sky_summary_3”,
“entity_summary_4”: “sensor.dark_sky_summary_4”,
“entity_summary_5”: “sensor.dark_sky_summary_5”
What browser are you using? If you are using chrome can you post the specifics of the error that is showing in the console of the chrome developer tools window. It will help narrow down the specific error that is causing the card to break.
I assume you downloaded the card .js file in raw format from github and placed it in the correct directory. Basic question I know, but it’s been a problem for some folks in the past.
Sorry if this is a stupid question…is this card supposed to update dynamically, like other sensors do in HA? Because mine only changes if I refresh my browser page (i.e. F5). I’m using Chrome on a Windows PC.
It doesn’t currently. I am looking into what can be done to make it.
Thanks…appreciate the info and for looking into it!
