Hi all,
Here is my card and I love it. The problem is - today is already Tuesday and as you can see on forecast panel the first day of the forecast is also Tuesday. And that would be not a big deal but the actual forecast in this slot is from Wednesday.
Does anyone compare his forecast to the other sources? I think it should start from Wednesday , so how i can fix my forecast days appearance?
Hi all,
This is probably a very basic question, but I’m new to both HA and Dark Sky.
- Is there any way to change the color (and size?) of the summary icon, or can I change the icons to my own icons for every possible state?
Right now it’s black, which doesn’t really show too well on grey background. - Can I somehow get rid of the C for Celsius to only display the temperature and the degrees sign? Would be nice to have a cleaner look if possible.
ui-lovelace,yaml
#Weather
#Today image
- type: image
image: /local/Weather/Today.svg
style:
left: 27%
top: 3%
#Today Summary
- type: state-icon
entity: sensor.dark_sky_summary_0d
style:
left: 27%
top: 10%
#Today Temp
- type: state-label
entity: sensor.dark_sky_temperature
style:
left: 27%
top: 16%
color: white
font-size: 23px
#Tomorrow image
- type: image
image: /local/Weather/Tomorrow.svg
style:
left: 76%
top: 3%
#Tomorrow Summary
- type: state-icon
entity: sensor.dark_sky_summary_1d
style:
left: 76%
top: 10%
#Tomorrow Temp
- type: state-label
style:
left: 76%
top: 16%
color: white
font-size: 23px
Configuration.yaml
#Dark Sky Sensor
- platform: darksky
api_key: SecretCode
forecast:
- 0
- 1
monitored_conditions:
- summary
- temperature
- icon
- temperature_low
- temperature_high
Kind regards
Daniel
I’ve been using this card and I like it a lot! Have one problem though - the card seems to be too wide when displayed on iPhone (XR), attached is a screenshot from Safari, in homeassitant companion app the gap from the right is not that big, but it’s there. I was trying to fix it myself, but have no clue. Can anyone help please?
Is there anything better in the Home Assistant Community Store? I can’t fine one, with Dark Sky support.
This one is in HACS - but i doesn’t looks like there’s support for Dark Sky
Is there a way to hide the units for one of the sensors, like for: “entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5d”, for example?
Not sure what you mean, bramkragten/weather-card supports dark sky. Scroll to the bottom of that repositories readme to see how to set weather to use Dark Sky.
Wow. How did i miss that part. I guess i looked for a larger selection of configs or so Thanks decairn.
Hi guys,
i’ve installed new script version and all work as it should but icons doens’t show.
I’ve installed it in www/icons/weather-icons/
Any ideas?
Thank you so much in advance and happy new year to all!!
Regards,
Alessandro
Should be
www/icons/weather_icons/
i’m here again.
Cards on pc desktop works as it should but on my mobile phone (android with Chrome browser) not:
Thanks in advance for any help.
Regards,
Alessandro
might be a cache issue, did you refresh? Sometimes have that same thing on iPhone, and killing the app to force refresh does the thing.
Incredible!
I’ve refreshed cache browser, cards are gone
This is my configuration:
This is also my card code:
- badges: []
cards:
- entity_apparent_temp: sensor.dark_sky_apparent_temperature
entity_current_conditions: sensor.dark_sky_icon
entity_daily_summary: sensor.dark_sky_daily_summary
entity_daytime_high: sensor.dark_sky_daytime_high_temperature_0d
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1d
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2d
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3d
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4d
entity_forecast_icon_1: sensor.dark_sky_icon_1d
entity_forecast_icon_2: sensor.dark_sky_icon_2d
entity_forecast_icon_3: sensor.dark_sky_icon_3d
entity_forecast_icon_4: sensor.dark_sky_icon_4d
entity_forecast_icon_5: sensor.dark_sky_icon_5d
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_0d
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1d
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2d
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3d
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4d
entity_humidity: sensor.umidita_esterna
entity_pop: sensor.dark_sky_precip_probability
entity_pop_1: sensor.dark_sky_precip_probability_1d
entity_pop_2: sensor.dark_sky_precip_probability_2d
entity_pop_3: sensor.dark_sky_precip_probability_3d
entity_pop_4: sensor.dark_sky_precip_probability_4d
entity_pop_5: sensor.dark_sky_precip_probability_5d
entity_pop_intensity: sensor.dark_sky_precip_intensity
entity_pressure: sensor.barometro
entity_summary_1: sensor.dark_sky_summary_1d
entity_summary_2: sensor.dark_sky_summary_2d
entity_summary_3: sensor.dark_sky_summary_3d
entity_summary_4: sensor.dark_sky_summary_4d
entity_summary_5: sensor.dark_sky_summary_5d
entity_sun: sun.sun
entity_temperature: sensor.temperatura_esterna
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.direzione_vento
entity_wind_speed: sensor.raffica_vento
locale: it
old_daily_format: false
show_beaufort: true
static_icons: false
time_format: 24
tooltip_bg_color: 'rgb( 75,155,239)'
tooltip_border_color: orange
tooltip_border_width: 3
tooltip_caret_size: 10
tooltip_fg_color: '#fff'
tooltip_left_offset: -12
tooltip_width: 100
tooltips: true
type: 'custom:dark-sky-weather-card'
Thank you so much for any help.
Regards,
Alessandro
all cards, or only the dark_sky card?
did you try another browser too?
any error messages in the log, or inspector? If the card shows on desktop this would at least mean the config is alright, and it is an android/chrome combination issue…
as far as I can see, the config would be fine, and I can tell you it does work on iPhone /Chrome like that.
Is there anything you changed before the issue started?
Is there a way to import a personal weather station data into this card? If one gets PWS data in HA, having local/personal weather shown in this card could be awesome.
Only dark-sky card.
weather card doesn’t show anymore on both system, Android and windows
Please, could you send me valid dark-sky-weather-card.js file?
This is my manual card code:
type: ‘custom:dark-sky-weather-card’
entity_temperature: sensor.dark_sky_temperature
locale: en
static_icons: false
tooltip_bg_color: ‘rgb( 75,155,239)’
tooltip_fg_color: ‘#fff’
tooltip_width: 100
tooltips: true
time_format: 24
show_beaufort: true
locale: it
static_icons: false
tooltip_width: 100
tooltips: true
time_format: 24
show_beaufort: true
About log file errors.
Where is it? It’s the general home-assistant.log?
Thank you so much for your support.
Regards,
Alessandro
check home-assistant-config/ui/darksky at master · iammexx/home-assistant-config · GitHub
I have manual edited mine to some serious extent, so best to stay with the original for now
yes, that is a good source for config errors
also, right click the Desktop Lovelace interface and select inspector (depends on the browser you are using), an error should be displayed if it exists.
must be an accidental error you made in the custom card? did you by any chance edit the file?
Did you re-download it using the Raw button?
https://raw.githubusercontent.com/iammexx/home-assistant-config/master/ui/darksky/dark-sky-weather-card.js
Hello folks,
I’m having a problem. I 've done all the steps one by one. I have all files, folders etc in the rights places. I have cleared cache and tried another browser but still I can;t see the icons. I have the card and temperatures but not icons. any ideas? I have the lovelace splitted and what i have for the weather is this
title: Weather
icon: mdi:weather-hazy
cards:
- type: custom:dark-sky-weather-card
