Custom Header
If you expand the card-mod error even more by using the drop down right before {type: "result" does it provide any more info? Is Custom Header listed anywhere in the errors? If you temporarily remove Custom Header from your resources do you still get this error?
I used the following code in compact custom header. How do I implement the same in custom header? I don’t see (so maybe oversee :relaxed:) such a conditional example in the docs.
  conditional_styles:
    template:
      - tab:
          1:
          - color: >
              if      (states["alarm_control_panel.egardia"].state == "armed_away") "red";
              else if (states["alarm_control_panel.egardia"].state == "armed_home") "orange";
              else "yellow";
It’s really not a big deal but why does this work…
button_text:
  options: "\U0001F31E"
But this (and no variation of it that I can find) does not?
button_text:
  options: >-
    {{ time }} ~ "\U0001F31E"
Just has to do with how templates are rendered. If you want to use something like that in a template, use the HTML equivalent:
  button_text:
    options: >-
      {{ time }} ~ 🌞
custom_header:
  tabs_color:
    1: >-
      {%- if is_state('alarm_control_panel.egardia','armed_away') -%}red
      {%- elif is_state('alarm_control_panel.egardia','armed_home') -%}orange
      {%- else -%}yellow{%- endif -%}
Hi, is it possible to link these card headers, to another tab page respectfully? thanks
Yes! The colors are back! Thank you!
I’m not exactly sure what you’re asking. Custom Header does not affect cards, only the Lovelace navigation header.
Thanks and just for completeness here is what I was trying to do.
(Note that I didn’t need the joining ‘~’ or the trailing ‘;’
  options: >-
    {%- if states('sensor.elevation') >= '0' -%}
    {{ time }} &#127774 {{ states('sensor.dark_sky_current_temperature') | round }}°C
    {%- else -%}
    {{ time }} &#127772 {{ states('sensor.dark_sky_current_temperature') | round }}°C
    {%- endif -%}
It was a card-mod issue but recently in the log appears two Custom Header error right after HA restart:
  • http://192.168.1.20:8123/community_plugin/custom-header/custom-header.js:145:58720 Uncaught TypeError: Cannot read property 'shadowRoot' of null
  • http://192.168.1.20:8123/community_plugin/custom-header/custom-header.js:145:62297 Uncaught TypeError: Cannot read property 'current_view' of null
    Could you please point me in the right direction to resolve these errors. Thank you.
These have been reported already and a fix is in place for the next release. They shouldn’t effect anything and will only happen when having a Lovleace window open on restart.
Thank you very much. Really appreciate your help and thank you for this awesome work.
HI Ryan,
as of late I get this quite often on reloading/refreshing:
23
and after a while apparently auto reloads to what it is supposed to show:
24
in inspector the only thing showing is:
not even sure if this is related, but seems to coincide.
my option template is:
button_text:
  options: >-
    {% if is_state('input_boolean.ch_use_options_text_template','on')%}{{ time }} - <ha-icon icon='{{states('sensor.weather_icon')}}' style='vertical-align: middle';></ha-icon> - {{states('sensor.temp_current') }}°
    {% endif %}
and it has been working ever since you introduced that possibility.
version CH 1.3.2 Hassio 104.3
thanks!
Yes, so do I. I have the same format as you, time - icon - temp and often the time doesn’t show (until it refreshes itself at the next minute).
ALSO
As I’m here, I don’t know if it is related to CH (although I feel like it might be?) I always get the Refresh toast message after every refresh.
@Mariusthvdb @klogg Looking into the button text template thing
@klogg For the toast message: If it happens every refresh, then it should be easy to reproduce in order to troubleshoot. Temporarily remove CH from your resources and see if it still happens.
Yeah good point. I hadn’t thought about it as it was just a mild irritation that I only mentioned as I was already posting. It looks like it isn’t CH.
Hmm… that’s a shame (for me, not you :wink: ) it’ll make it a bit harder to track down…
Well, not quite…
By a process of elimination I narrowed it down to my resources.
It turns out it seems to be this that is causing it.
- url: /community_plugin/custom-header/custom-header.js
  type: module
It doesn’t matter if I have this,
custom_header:
  !include lovelace/custom_header/custom-header.yaml
in my ui-lovelace.yaml or not
Any idea how that could be?
Not sure I understand. So, after removing this from your resources:
  type: module
and refreshing the page (CTRL-SHIFT-R). You no longer see the toast message when refreshing?
That is correct.
Except that CTRL-SHIFT-R (or F5) never causes a problem, only the refresh from the top right menu (clicking on, in my case, the time/date)
…hhmmm, it’s a long shot but could it be connected with the above issue of time not always refreshing?
Okay, now I understand. Thought you were talking about a page refresh not a lovelace refresh. Not sure there is anything I can do about that, but I will look into it (not related to time template).
