Thank you so much for all the work you have done on this and the work you are doing in both of your jobs helping others. Family first!!
The transparent background not working in footer mode. If âfooter_mode: falseâ itâs look like
If footer_mode: true:
My config:
custom_header:
active_tab_color: yellow
all_buttons_color: white
background: transparent
clock_am_pm: false
clock_format: '24'
compact_mode: true
date_css: 'font-weight:200'
date_locale: hu-hu
editor_warnings: false
exceptions: []
footer_mode: true
header_css: 'border-bottom: 1px;'
hide_help: true
menu_dropdown: true
options: clock
swipe_amount: '50'
swipe_animate: swipe
swipe_prevent_default: true
time_css: 'font-size: 23pt;font-weight:300'
view_css: 'padding-top:75px;'
voice: hide
voice_dropdown: true
voice_hide: true
Itâs a bug, or I miss something?
Thanks for your help!
Hi
may I ask how do you place icons in the tabs instead of name?
You can do this without custum_header
, itâs a feature from HA itself.
Look here: https://www.home-assistant.io/lovelace/dashboards-and-views/#icon
EDIT: Actually there is an error in the documentation for HA. The anchor for âiconâ is wrongly used twice on that page. Click the link, you will see an explanation about âiconâ, but thatâs the wron one. Scroll down a bit, there you will see the second anchor for âiconâ.
In short: you have to define an icon for your tab. If youâve done that, HA uses the icon automatically. If no icon is defined, the title is shown.
Here is copy&paste from the doc:
If you define an icon the title will be used as a tool-tip.
Example
- title: Garden icon: mdi:flower
Sorry, because apparently I am asking in the wrong thread. last question otherwise I will open a new thread.
In the following, I get no picture, just blank (no name either). Can you show me yours tab please?
EDIT: it works with = mdi:flower
Thanks!
Youâre welcome! You can find the icons you can use here: https://materialdesignicons.com/
On my smartphone (5.5" display), whenever my theme changes, the 5th view icon is partially blocked by an arrow. But there is clearly enough space to display everything without the need of this arrow.
This happens both on a browser and with the official android app.
Whenever this happens, I need to rotate my screen 90°, and then rotate it back so that the arrow disappears.
Is there a way to remedy to this issue ?
some screenshots to illustrate this minor bug :
Thanks !
Hi guys! I love the CH as it helps to have a much more sleeker design! Great Job!
I saw that someone had issues in Footer Compact Mode with an iOS device. I have this issue too and wanted to ask if itâs fixed now. Alternatively an option to make the footer a little bit big would help too.
Thanks a lot
Maybe you can explain what kind of issues
For footer I use this CSS styling option. Change the â30pxâ to a value you see fit.
tab_container_css: >-
padding-bottom: 30px !important;
Give this (see my footer):
Ah cool! Thanks. IÂŽll try that. And please show more screenshots from your Dashboard
Edit: Worked! Thanks a lot!
Is it possible to make the icon size from the custom header bigger? I think this look much better and also much smoother using on a mobile device.
Hi, I have tried to look through above but its a lot of comments/input on this great project! So feel free to point me to an answer if better.
I have a pretty simple installation of HA and just installed Custom Header. In the Examples in the github installation/conf help you can find this:
__
This will make the menu button display the date like this Wed. Dec. 25 2019
custom_header:
button_text:
menu: '{{ dayNameShort }}. {{ monthNameShort }}. {{ dayNum }} {{ year4d }}
and that is all fine but in my HA this example give no result because I dont think I see this Menu button at all. Where is it?
The example above this one (about the header text display) works perfect, no problems, but I have now spent hours trying to understand where this menu button is. Im probbaly stu⊠but anyhowâŠ
It is a great solution!
Is there a way to put a virtual button to the header-bar?
To control some things (for example to control the conditional cards)
Thank you
@sand_Rr There is no easy method to increase icon size but you could try messing with custom CSS to achieve it.
@danlun The menu button in HA is only visible when the sidebar has been hidden, either by a small screen width or by turning on âAlways hide the sidebarâ in the user settings.
@Korte No and I donât think this is something I would add.
Thanks, I didnt know that. I just messed up my config while testing all possibel things and need to restore. But then I will try this. And of course you mean âAlways hide the sidebarâ setting inside the Customer Header plugin?
No, user settings are found in HA by clicking on the user icon in the sidebar (very bottom)
Hi Ryan,
please keep up with the importance of Covid-19 before doing any requests here. we all support you there!
if a spare moment would arise, let me please ask if it would be feasible to have an animated tab icon.
use case:
I now use this for a tab_color:
tabs_color:
developer: >-
{{'green' if is_state('binary_sensor.github_repo_has_update','off') else 'red'}}
I would love to make it blink, like we can do in js css with:
animation: >
if (entity.state == 'on') return 'blink 2s ease infinite';
but am not sure how to do so in jinja, or if this would even be possible in the current CH implementation.
maybe add a new option to tabs:
tabs_animation:
developer: >-
{{'none' if is_state('binary_sensor.github_repo_has_update','off') else 'blink 2s ease infinite'}}
As said, if you do find a moment of ease, could you have a look?
thanks!
Hi, these Errors came from time to time definately caused by the mobile app:
https://xxxc.ui.nabu.casa/hacsfiles/custom-header/custom-header.js:603:15224 Uncaught TypeError: Cannot read property 'setAttribute' of null
shall I open an issue on github or can I do something by myself?
I cleared the chrome cache yesterday on every device.
I want to show the weather tab icon with templates and i am using unsuccesfully this template:
tab_icons:
5: >-
<ha-icon icon='mdi:weather-{%if is_state("weather.meteo_darksky", "partlycloudy") -%}night-partly-cloudy{%- else
-%}{{ states('weather.meteo_darksky')}}{%- endif %}'></ha-icon>
Can someone help me to understand where is wrong?
