mayker
(maykar (pronounced "maker" with a southern accent))
859
Hard to say for sure without knowing what your theme’s colors are, but possibly your light theme’s primary-background-color and primary-text-color are the same?
Maybe change the template’s colors as well like #flip > div > div {color:#fff
If your header background is white and that color is white (#fff) then you wouldn’t be able to see it.
You could just remove the color (color:#fff;) or change it to something else, like one of the theme variables
Themes im using is the goole light and google dark theme
light, then background is white indeed, so the color:#fff doesnt show indeed
on dark its ok cause background then is black
problem is, if i change it to dark, then it wont be good when using dark mode
so is there a way to put inside the header config to use white when theme dark mode
and use black when using theme light mode?
i tried changeing the flip div color, but i found 3x times the color in that config
mayker
861
i have a button on my home view that brings me to another view “persoon1”
With custom header i use the split mode so my tabs are at bottom.
In the tabs theres a tab “persoon1” too
I want to get rid of that tab , but when i use hide tab “persoon1” its gone which is good, but when i click the button on my home view, to bring me to that persoon1 view, its gone too
Is there a way to just hide it in the bottom tab , but not on my homepage?
mayker
863
EDIT: Nevermind - please ignore below - just saw in the documentation that the editor is not available in YAML mode. I must not have noticed when I migrated to YAML mode a few months ago and thought it was a more recent issue.
I have a strange issue now where the custom header settings are no longer available in the top right menu. This seems to only happen in the dashboard that is controlled in yaml mode. I tried creating a new dashboard that is controlled via the UI and in this dashboard I can access the custom header settings in the top right.
I can confirm custom header is working in my default yaml dashboard and I tried setting
hide_ch_settings: false
but doesn’t help. I was able to hide the reload resources option by using
Hi can you let me know, how you have done your layout? which theme do you use und how have you set up the cards with your beautiful pics? thank you Regards
mayker
869
For now I would suggest using the device_ID condition as the current user agent used in the iOS app contains no identifying information like “Mobile”, “iPad”, “iPhone”, “Safari”, etc. Also, I wouldn’t rely on using the full user agent shown in ObiKai’s post as it is likely to change as well, though I imagine the io.robbie.HomeAssistant bit will remain.
mayker
870
Another heads up on this:
The iOS user agent is being modified in upcoming iOS app builds. Device names are returning ("iPhone", "iPad", etc). "Mobile" will no longer exist, but you’ll be able to replace that with either "Home Assistant" or "iOS" as they are now included in the apps user agent.
As a reminder, you can use multiple user agent strings by using the template condition as mentioned in this post above.
Hi
I’m interested by the Per user/device feature. Does that mean I can show/hide cards for specific users ?
I don’t find any documentation or example on this subject, can someone give me some tips ?
mayker
872
The exceptions/conditions feature allows you to have different CH configs per user, device, and a fair few other conditions. This would allow you to show/hide entire views based on those conditions among other things.
You can read more about it the docs, but it sounds like what you want to do is conditionally hide a single card. This is something that is more suited for something like state-switch.
mayker
878
Couldn’t tell you. It’s included in HACS by default and found by going to “Frontend”, clicking the add button on the bottom right, and searching for “Custom Header”.
Can someone help me out a bit and explain why this code isn’t working. Susanne and Lisa shouldn’t see the left side menu. Both running the Android app. Running the latest version of Home Assistant.
mayker
880
Latest isn’t a version. Always say what version number you are using as you could be running the beta, a version could be released before someone sees your comment, etc.
What version of CH are you running? Do you get any errors pertaining to CH in your logs or in your browser’s dev tools (when logging in as one of those user’s in a browser)? Include any other information that may be helpful from the issues section of the docs.
Using your exact code and just replacing one of the user names with my own, I can confirm that everything is working as expected in the HA android app, mobile browser, and in multiple browsers on my PC. Are you sure that the user name’s are correct (case and all)? You can check this in the browser dev tools when logged in as one of those users or, if you are not using yaml mode, you can open custom headers settings and scroll to the bottom.
I’m running Home Assistant 111.4 and Custom Header 1.6.3.
The way I have it setup is that each family member has their own dashboard view in Lovelace with components relevant to them. In the app settings I have specified that each family member doesn’t have the default dashboard but the dashboard created for them. When I changed this in the app settings to “default” the left menu disappeared which is exactly what I wanted.
So in case you want to reproduce this bug/feature give that a try. This is fine but would be nice if I could set a user specific dashboard view other than the default one and still get this to work (if this is what is causing this issue for me).
