Custom icon help
i have tried several things found in various posts here and cannot seem to get my icon to load… The icon is located in config/www/pficon.ico. I have also tried with a png of the same icon.
This is the code from the entities card:
  - icon: /local/pficon.ico
    type: weblink
    url: https://192.168.1.1:8081/index.php
Have also tried this…
  - entity_picture: /local/pficon.ico
    type: weblink
The latter results in this for pfsense on the final card… This link icon oddly enough is the one that I used on the top of my main lovelace panel. Not sure what i am doing wrong here…
Make it an svg file, not an ico file. ICO files are a windows format last I checked.
A .png file will not work either? OK, gotta figure out what an svg file is… Will try.
But, how do I make use of it once I have it?
Ok, tried both entity_picture: and icon: The entity_picture resulted in the link icon again and the icon: resulted in a blank icon location.
This really should not be this hard.
A png file will work as well
Also, you should only be using picture_entity. icon is for built in icons only. Lastly, the custom integration for fontawesome has the ability to add custom svg icons that are usable in the icon field.
Ok, so I must be an idiot… Here is my full card and this still does not work…
entities:
  - icon: mdi:home-assistant
    type: weblink
    url: http://192.168.1.6:8123/hassio/ingress/a0d7b954_portainer
    type: weblink
    url: http://www.yamllint.com/
  - icon: mdi:pi-hole
    type: weblink
    url: http://192.168.1.7/admin/index.php
  - picture_entity: /local/pficon.svg
    type: weblink
    type: weblink
    url: http://192.168.1.7/cgi-bin/smokeping.cgi
    name: Home Assistant Forums
    type: weblink
    url: https://community.home-assistant.io/
  - icon: mdi:git
    type: weblink
    url: https://github.com/
  - icon: mdi:home-battery
    type: weblink
    url: http://192.168.1.7/cgi-bin/nut/upsstats.cgi/
    type: weblink
    url: http://192.168.1.7/cgi-bin/nut/upsset.cgi/upsset.cgi
show_header_toggle: false
title: Weblink
type: entities
You can not change the entities icon in this way.
I think your options are (but I will be corrected when wrong) either;
If you want to add many custom icons the last option would be the way forward. If you search on Github for hass icons or home assistant icons you will find many more repositories with custom icons.
So, I got it working with the SimpleIcons integration. I wish I understood more about github and I would try to make my own repo with a custom icon set.
Thanks to all for the help here.
