@DBuit Welcome back!
My thermostat popup cards don’t have any controls for some reason. The controls are there because if I move the cursor around and tap the thermostat responds but they’re just not visible!
Do you have any idea what could be wrong?
I am combining this card with the custom:layout-card from here, but when using the column/rows feauture the card is broken and just won’t show up (i guess, because the layout card also uses it) I want to achieve something (see picture) where i can have the remote control, combined with the homekit card but it only works if I don’t use the column/rows and that’s something I’d love to use.
So below I’ll show you the code & screenshot of how I bypassed it (by making 3 layouts in the layout card) but I’d love to have 2, with column/row feauture of you enabled in the homekit card
This results in the following (sidebar is not in code, but using your sidebar card), but I more like it to have 2 layouts (so 1 for remote & 1 for homekit card), and now I “bypassed” it by making 3 layouts (1 remote, 1 homekit & another homekit). I prefer the rows/columns version, but that’s just not working out and results in showing nothing (not even an error, just blanco card)
I still have to do this for my lights
I have to able to adjust the brightness of my lights
Now i just turn them on/off
I want it as simple as possible
Whats the best way to do this?
Use the light pop up card?
But i think its too much for that no?
So you can use a slider in the tile to change the brightness, no pop-up needed anymore
If you wanna test it out you can install it with HACS, reinstall the card and enable beta version!
When you have the card in HACS, you can click the 3 dots (bottom right) and click on reinstall.
Than a pop-up shows and there is a switch to enable beta versions
If you use any of the pop-up cards they are all updated with some icon fixes.
For the media player and cover pop-up i added that you can already see the volume/position while sliding.
Mm dont know
maybe a scrollbar at the bottom of the button, or a scrollbar to the far right of the card?
I’m not sure if thats a good way, maybe popup is better or not?
What would you recommend as simple popup for adjusting brightness only, so a simple slidebar
Also with your experience, whats the best thing thing to use? double tap to activate popup? Cause you dont always want the popup, most of the time i just toggle it on/off
The switch popup card?
Looks nice and clean
Wow cool feature!
Just tested this
Its much nicer and cleaner than popupcard i think
However i did encounter troubles
Ill demonstrate with pics
Eettafel is when the light is completely out. i would like to stay it that way
When i turn it on, you get the slider, however when i slide it completely to the left, the button doesnt return to the one like “eettafel”, it looks empty see the pic .
You shouldnt see the slider if its off i think
If i move it back it comes ok again
Maybe it would look nice to if the grey part (which is the off %) would have the same color as when its completely off, if u know what i mean (the shadow color)
edit: i thought it would slide from top to bottom, but when i tried , i saw it slided horizontally… actually very good ! no need to put it to the right then
