Custom Lovelace Card - Homekit style card
Remove the #Default stuff in de style maybe it breaks the style the icons should be alot blogger than
Yup it works now, thx mate for your help and the added features !
In a later stadium, im gonna add the popup card, so i can change the brightness of the lamp with a sliderā€¦
Iā€™m guessing you wonā€™t need my code anymore now that this card supports theming :slight_smile: I didnā€™t have time to experiment with the icon alignment unfortunately. Glad to see you have your solution regardless.
true thx anyway
@DBuit
More questions.
  • If i dont use columns, but only rows
    canā€™t i use the tileOnRows then? cause when i add 4 entities, it splits up 3 to 1
  • if i set it like ā€œTitle:ā€ and dont fill in, it still uses spaceā€¦ can i get rid of the space (row title)?
  • is there a problem with style, cause when not using columns, it doesnt pick up the style (although copy)
my code
title: Test
icon: mdi:test-tube
path: test
theme: ios-dark-mode
cards:
  - type: markdown
    content: >
      {% set time = states('sensor.time') %}
      {% if '00:00' < time < '06:00' %} ## Goeie Nacht !
      {% elif '06:00' < time < '12:00' %} ## Goeie Morgen !
      {% elif '12:00' < time < '18:00' %} ## Goeie Middag !
      {% else %} ## Goeie Avond !
      {% endif %}
  - type: vertical-stack
    cards:
      - type: 'custom:weather-card'
        current: true
        details: false
        entity: weather.thuis
      - type: horizontal-stack
        cards: []
        cards:
            cards:
              - type: picture-entity
                entity: person.stijn
                show_name: true
                image: /local/stijn.jpg
                tap_action:
                  action: navigate
                  navigation_path: /lovelace/persoon1
                entity: person.kim
                show_name: true
                image: /local/kim.jpg
                tap_action:
                  action: navigate
                  navigation_path: /lovelace/persoon2
          - type: "custom:homekit-card"
            home: false
            enableColumns: false
            style: |
              :host {
                --tile-background: rgba(0, 0, 0, 0.3);
                --tile-border-radius: 12px;
                --tile-width: 100px;
                --tile-height: 100px;
                --tile-on-background: rgba(255, 255, 255, 1);
                --tile-name-text-color: rgba(255, 255, 255, 0.7);
                --tile-on-name-text-color: rgba(0, 0, 0, 1);
                --tile-state-text-color: rgba(255, 255, 255, 0.4);
                --tile-on-state-text-color: rgba(0, 0, 0, 1);
                --tile-state-changed-text-color: rgb(134, 134, 134);
                --tile-unavailable-state-text-color: rgba(255, 255, 255, 0,5);
                --tile-value-text-color: rgba(255, 0, 0, 1);
                --tile-icon-color: rgba(255, 255, 255, 1);
                --tile-on-icon-color: rgb(255, 140, 0);
                --tile-width-mobile: 90px;
                --tile-height-mobile: 90px;
              .button-inner .icon {
                    width:55px;
                    height:55px;
              .button-inner .icon ha-icon {
                    width: 40px;
                    height:40px;
            entities:
              - title:
                entities:
                  - custom: lampen
                    icon: mdi:lightbulb-group
                    tap_action:
                      action: navigate
                      navigation_path: /lovelace/lichten
                  - custom: entertainment
                    tap_action:
                      action: navigate
                      navigation_path: /lovelace/entertainment
                  - custom: server
                    tap_action:
                      action: navigate
                      navigation_path: /lovelace/server
                  - custom: network
                    tap_action:
                      action: navigate
                      navigation_path: /lovelace/network
It works now. Thank you!
The deep_press mod works fine for me in combination with the light-popup-card (not the homekit-panel-card).
How I set it up:
  • ui-lovelace.yaml (somewhere in the top):
deep_press:
  enable_unsupported: true
  • Per-entity config:
    type: custom:button-card
    tap_action:
      action: toggle
    dbltap_action:
      action: more-info
    hold_action:
      action: more-info
    deep_press: true
    (etc.)
  • And in the popup_cards: section a pretty much copy-exact of @DBuitā€™s example code on GitHub.
On iOS when I hold the button card for like a second, it gives me a blurry transition and haptic tap, and automatically opens the popup card. I prefer this over the normal hold_action, as this one waits for you to release your finger (which is a bit counter-intuitive).
I hope this is helpful for you!
@neliss What goes in the entity config after deep_press: true ?
Do you then define an action? If so whatā€™s the caller? (as opposed to the standard tap_action and hold_action
Rest of my config is as described in the button-card manual, see: button-card on GitHub.
In my case, most parameters are styling options to mimic homekit layout (there is also a code example on that GitHub page).
Actions I defined are not more than toggle on single press and more-info on long / double press.
What about with deep_press if I use decluttering?
If I turn deep_press: true in a decluttering template, it cannot get the entity.
this is my decluttering template:
# Default Config
default:
  # Button Options
  - lock: false
  - aspect_ratio: 1/1
  - opacity: 0.5
  - opacity_on: 1.0
  - border-radius: 2px
  - ha-card-background: var(--card-color-off)
  - box-shadow: var(--box-shadow)
  # Name
  - name: # Leave this empty if you want to be able to use names defined in customize.yaml (default is empty!)
  # Label
  - label: '&nbsp;'
  # Icon Options
  - color: auto
  - size: 55%
  - margin-right: 50px
  - margin-left: 0px
  - variable: spin
  - spin: false
  - off_variable: spin
  - off_spin: false
  - icon: # Leave this empty if you want to be able to use icons defined in customize.yaml (default is empty!)
  # Show Options
  - show_name: true
  - show_state: true
  - show_label: true
  - show_icon: true
  - show_last_changed: true
  # Tap and Hold Actions
  - tap_action:
      action: toggle
      haptic: light
  - hold_action:
     haptic: heavy
     action: call-service
     service: browser_mod.command
     service_data:
      command: popup
      title: >
        [[[ return entity.attributes.friendly_name ]]]
      style:
        position: fixed
        z-index: 999
        top: 0
        left: 0
        height: 100%
        width: 100%
        display: block
        align-items: center
        justify-content: center
        background: rgba(0, 0, 0, 0.8)
        color: "#FFF"
        flex-direction: column
        margin: 0
        "--iron-icon-fill-color": "#FFF"
      card:
        type: custom:light-popup-card
        entity: >
          [[[ return entity.entity_id ]]]
        icon:
        brightnessWidth: 110px
        brightnessHeight: 400px
        switchWidth: 110px
        switchHeight: 400px
        scenesInARow: 2
        settings: true
        settingsPosition: bottom
        fullscreen: false
  # Button 'Off' Options
  - off_icon_color: var(--icon-color-off)
  - off_name_color: var(--name-color-off)
  - off_state_color: var(--state-color-off)
  - off_label_color: var(--label-color-off)
  # Button 'On' Options
  - on_name_color: var(--name-color-on)
  - on_state_color: var(--state-color-on)
  - on_label_color: var(--label-color-on)
  - on_card_color: var(--card-color-on)
  # Name and Label Options
  - margin-top-name: 0px
  - label_font_size: 11px
  - label_font_weight: normal
  - justify-self-name: start
  - padding-left-name: 10px
  # Grid
  - grid:
      - grid-template-areas: '"i" "n" "s" "l"'
      - grid-template-columns: 1fr
      - grid-template-rows: 1fr min-content min-content
  # Custom Fields # Changed/Added in 0.13.3
  - notification: "[[[ return '&nbsp'; ]]]"
  - custom_fields:
      notification:
        - background-color: "[[[ return 'var(--card-color-off)'; ]]]"
        - color: var(--notification-badge-color)
        - border-radius: 50%
        - overflow: visible
        - position: absolute
        - right: 7%
        - top: 7%
        - height: 22px
        - width: 22px
        - font-size: 11px
        - line-height: 20px
  # Lock # Changed/Added in 0.13.3
  - lock: false
# Card Config
# Do NOT change this unless you know what you are doing!
card:
  show_entity_picture: true
  deep_press: true
  icon: '[[icon]]'
  color: '[[color]]'
# Lock config below # Changed/Added in 0.13.3
  lock:
    enabled: '[[lock]]'
    unlock: hold
    duration: 5
  aspect_ratio: '[[aspect_ratio]]'
  entity: '[[entity]]'
  label: '[[label]]'
  show_name: '[[show_name]]'
  show_icon: '[[show_icon]]'
  show_state: '[[show_state]]'
  show_label: '[[show_label]]'
  show_last_changed: '[[show_last_changed]]'
  tap_action: '[[tap_action]]'
  hold_action: '[[hold_action]]'
  styles:
    card:
      - border-radius: '[[border-radius]]'
      - --ha-card-background: '[[ha-card-background]]'
    label:
      - font-size: 11px
      - font-family: Helvetica
      - padding: 0px 10px
      - justify-self: start
      - color: var(--label-color-off)
    state:
      - font-size: 11px
      - padding: 0px 10px
      - text-transform: capitalize
      - font-weight: bold
      - padding-left: 10px
      - color: var(--state-color-off)
    grid: '[[grid]]'
    custom_fields: '[[custom_fields]]'
    img_cell:
      - align-self: start
      - text-align: start
      - margin-right: '[[margin-right]]'
      - margin-left: '[[margin-left]]'
    name:
      - justify-self: '[[justify-self-name]]'
      - padding-left: '[[padding-left-name]]'
      - font-weight: bold
      - font-size: 16px
      - margin-top: '[[margin-top-name]]'
  custom_fields:
    notification: '[[notification]]'
  state:
    - value: "on"
      '[[variable]]': '[[spin]]'
      styles:
        card:
          - --ha-card-background: '[[on_card_color]]'
          - opacity: '[[opacity_on]]'
          - box-shadow: '0px 0px 2px 2px var(--paper-item-icon-active-color)'
        name:
          - color: '[[on_name_color]]'
        state:
          - color: '[[on_state_color]]'
        lock:
          - color: var(--lock-color-on)
        label:
          - color: '[[on_label_color]]'
    - value: "off"
      '[[off_variable]]': '[[off_spin]]'
      styles:
        card:
          - opacity: '[[opacity]]'
          - border-style: solid
          - border-width: 0px
          - border-radius: 0px
          - border-color: '#ADB1B7'
        icon:
          - filter: grayscale(100%)
        name:
          - color: '[[off_name_color]]'
        state:
          - color: '[[off_state_color]]'
        label:
          - color: '[[off_label_color]]'
          - font-size: '[[label_font_size]]'
          - font-weight: '[[label_font_weight]]'
        lock:
          - color: var(--lock-color-off)
    - value: "idle"
      styles:
        card:
          - opacity: 0.8
        name:
          - color: var(--name-color-off)
        label:
        icon:
          - color: var(--icon-color-off)
        lock:
    - value: "unavailable"
      styles:
        card:
          - opacity: 0.2
        name:
        label:
        state:
        icon:
        lock:
and this is what I get:
What Iā€™m doing wrong?
Hi @skank,
If you dont use the columns you can use tileOnRows. It just fits the as much tiles on a row as fits on the screen but on mobile when screen < 768 px it is always 3 tiles.
If you dont want title i think you can just leave title from your config and it wont take up space
style should work always, still got this problem? maybe cache?
Is there a way to increase the space between the tiles and titles when viewing on a mobile/small screen?
Transparent icon, no reason.
Check this image: https://ibb.co/rMTqN9v
This is my code:
https://pastebin.com/GM2rq7VA
Hi so for lights the icon takes the color of the light. is it possible light.lume has a white color for the light? than the icon will also be whiteā€¦
Ye you can use the style option to add some css for example use this:
@media (max-width: 768px) {
  .card-title {
     margin-top:20px!important;
This add extra space above the title for screens smaller than 768 px (mobile)
Even if i put a blue color on light.lume i have the icon ā€œwhiteā€
Strange, i see it works for light.bagno2 but can you share the info of the light entity in the developer info in home assistant for entity light.lume?
What happens if you set these to false?
useBrightness: true
useTemperature: true
Is the same, nothing change.
[light.lume]
brightness: 255 hs_color: 0, 0 rgb_color: 255, 255, 255 xy_color: 0.323, 0.329 friendly_name: Lume supported_features: 17
If we dont use cardStyle, The measurement unit is not displayed correctly!
Hi @odiv,
What measurement unit do you mean? Can you share a screenshot?
