Custom Lovelace Card - Homekit style card
Hi @DBuit,
I’ve update and tested again. Now it’s working and showing the right sizes.
Great and thanks for this. :ok_hand:
Again, almost perfect but not yet aligned 100% strak
That’s true.
I think it should be possible with vertical stack but with alot of trial and error.
Haha almost strak.
I will see if i can get it strakker :wink:
Haha thank you.
The card on desktop however is now the other way around: The smaller tiles are slight stretching out: (zoomed in for showing)
Hello how can I have the longest brick or card configuration could you put a code example Thanks
Like this?
- row: 2
  columns:
      - column: 1
        tileOnRow: 3
        entities:
            - custom: Scripts
              icon: mdi:silverware-fork-knife
              tap_action:
                 action: script.turn_on
                 entity: script.dinner
I don’t know what the today’s update did, but styles aren’t working anymore. At least changing --tile-background doesn’t do anything anymore :frowning:
Almost the action is service:
- custom: Scripts
                        tap_action:
                          action: call-service
                          service: script.dinner
                          service_data: <- Not sure if you need service data?
Here you can see the part in the readme about actions: https://github.com/DBuit/Homekit-panel-card#action-options
I’m getting a "cannot call service “script turn on” expected dict for dictionary value @data[service_data] Got script.dinner
                    custom: Scripts
                    tap_action:
                      service: script.turn_on
                      service_data: script.dinner
edit:
got it
no need for service data
Still have a problem though… the button shows the color as like i press the button…
Hi guys I need a lot of help I would like to integrate a specific “iframe” card like the one I am attaching to my cards to view forecast data in real time.
The url to which I would like to connect the card is the following: https://embed.windy.com/embed2.html
Could you help me and indicate the type of card to use among those homekit cards and the code to use to view what is attached?
Also I wanted to know and you just need to prepare the card or you need to write some code also in configuration.yaml or other files.
Thanks I hope someone can help me
Does it show like it is in the “on” state?
Yes it’s shown like it is in the “on” state.
Im using it on another yaml page too for my lights dashboard.
When i change it on the page containing the scripts - so its shown like it is in the “off” state (like i want to)
then its good, but then on the other lights yaml page, the colors show there are like the off state too although the code is differently
Very strange
So i cant get it right
for Dbuit
Hello could you help me to display this card with one of those homekit panel cards maybe a little bigger, forgive me if I ask you this but it is the day that I try to read and reread your info on the forum and on your pages but I do not come out. The image I am attaching is the classic Home assistant card but I would like to use Homekit panel card but I can’t thanks claudio
[image]
Posting this again in the hope I’ll find some help.
My popups appear in a very small scrollable window and I can’t figure out why.
Most of my config is copied from the sample in @DBuit’s repo but with my own entities.
Here are screenshots of how they look and also my full view code
config:
  background: var(--background-image)
custom_header:
  background: 'rgba(155, 155, 155, 0.25)'
  button_text:
    options: '{{ hours24 }}:{{ minutesLZ }}'
  compact_mode: true
  hide_header: true
  hide_help: true
popup_cards:
  climate.office_ac:
    card:
      entity: climate.office_ac
      type: 'custom:thermostat-popup-card'
    style:
      '--iron-icon-fill-color': '#FFF'
      align-items: center
      background: 'rgba(0, 0, 0, 0.8)'
      display: block
      flex-direction: column
      height: 100%
      justify-content: center
      left: 0
      margin: 0
      position: fixed
      top: 0
      width: 100%
      z-index: 999
    title: ''
  - cards:
      - entities:
          - entities:
              - entity: lock.front_door
                halfheight: true
                offStates:
                  - locked
                tap_action:
                  action: toggle
              - entity: sensor.night_status
                halfheight: true
                hide: |
                    var state = states['input_boolean.night_mode'].state ;
                    return (state == 'idle') ||  (state == 'boo');
                hideState: true
                tap_action:
                  service: input_boolean.toggle
                  service_data:
                    entity_id: input_boolean.night_mode
              - entity: input_boolean.away_mode
                halfheight: true
                hide: |
                    var state = states['input_boolean.away_mode'].state ;
                    return (state == 'idle') ||  (state == 'off');
              - entity: light.entryway
                popup:
                  brightnessHeight: 350px
                  brightnessWidth: 130px
                  scenesInARow: 2
                  switchHeight: 300px
                  switchWidth: 110px
                  type: 'custom:light-popup-card'
                state: binary_sensor.motion_entryway
              - entity: light.kitchen
                style: |
                  :host {
                    --tile-icon-color: rgba(255, 0, 0, 0.3);
                    --tile-on-icon-color: rgba(0, 255, 0, 0.3);
              - entity: light.dining_room
              - entity: light.lounge
              - entity: light.hallway
              - entity: light.closet
              - entity: light.bedroom
              - entity: light.living_room
              - entity: light.adams_room
              - entity: light.office
                state: sensor.temperature_office
              - entity: light.patio_lights
              - entity: light.porch
              - entity: light.lounge_led
              - entity: light.bar
              - entity: light.shed
              - entity: light.living_room_colour_lamp
                halfheight: true
                state: false
                wider: true
                widerSize: 2
              - entity: climate.office_ac
                tap_action:
                  action: more-info
              - entity: light.lounge_lamp
                halfheight: true
                hideState: true
                style: |
                  :host {
                    --tile-icon-color: rgba(0, 0, 0, 0.3);
                    --tile-on-icon-color: #f75977;
                    --tile-icon-size: 10px;
                    --tile-border-radius: 5px;
              - entity: light.buffet_led
                halfheight: true
                style: |
                  :host {
        masonry: true
        popup:
          scenesInARow: 2
          switchHeight: 300px
          switchWidth: 110px
        statePositionTop: true
        state_color: true
        style: |
          :host {
            --tile-icon-size: 25px;
        titleColor: '#FFF'
        type: 'custom:homekit-card'
        useBrightness: false
        useTemperature: false
        fullscreen: true
    icon: 'mdi:tablet'
    panel: true
    path: wallmount
    title: Wallmount
@DBuit
@thecrane Did you ever find a way to do this?
Screen Shot 2020-09-11 at 12.42.02
Does anyone know how (which css properties) I can change the circle around the state icon?
I need to change the colour or shape or hide it altogether
Hello mate, I just followed your awersome code for the media player card. Thank you for sharing!
I have a question, due to the fact I really don’t know how to manage Style codes: how can I remove those white border on the 4 angles? Thank you!
2020-09-11_97
@DBuit I have this UI issue on Chrome and Firefox when I use the masonry with the weather card. Do you have an idea how to avoid it?
From iOS app it’s all regular…
2020-09-11_98
Can you share your config for media player card
Thx
Sure, I took this from @martheijnen and I added the popup:
  - card: 'custom:mini-media-player'
    entity: media_player.tv_sala
    noPadding: true
    wider: true
    higher: true
    tap_action:
        action: navigate
        navigation_path: /lovelace/media
    hold_action:
        action: popup
    cardStyle: |
        ha-card {
        height: 100%;
        background: none  !important;
        box-shadow: none !important;
        position: relative;
        font-size: 0.5vw !important;
        ha-card{
        overflow: hidden !important;
        :host #primaryProgress{
        background: #474A52 !important;
        display: flex !important;
        height: 100%;
    cardOptions:
        artwork: full-cover
        entity: media_player.appletv_soggiorno
        hide:
        power: true
        progress: false
        runtime: true
        icon: true
        source: true
        volume: true
        controls: false
    popup:
        type: 'custom:media_player-popup-card'
        actions:
        - service: media_player.appletv_soggiorno
            service_data:
            entity_id: media_player.appletv_soggiorno
            icon: 'mdi:skip-previous'
            service_data:
            icon: 'mdi:play-pause'
            service_data:
            icon: 'mdi:skip-next'
