Same issue here.
Read the breaking changes, there are issues with custom cards.
Hi everyone I am using the Mini media player card to play Spotify playlists but I have two problems: the first concerns the function keys: back, forward, pause and stop these do not work on the card while if I go to spotify they work regularly. I am attaching the code and screenshots where I have circled the keys that do not work in red. Another thing I noticed is that if spotify does not open the tab on Home assistant it does not work at this point, sorry to my ignorance, what is the use of having a tab that controls spotify if then the same spotify must be launched? Last question: with a card like this, how can you manage your playlists it seems that you can launch them one at a time and then always re-enter Spotify. can you help me?
enableColumns: true
home: false
masonry: false
rows:
- columns:
- column: 1
entities:- entities:
- card: âcustom:mini-media-playerâ
noPadding: true
wider: true
higher: true
double_tap_action:
action: popup
entity: media_player.spotify_claudio
cardStyle: |
ha-card {
height: 100%;
background: none !important;
box-shadow: none !important;
position: absolute;
font-size: 0.5vw !important;
ha-card{
overflow: hidden !important;
:host #primaryProgress{
background: #474A52 !important;
display: flex !important;
height: 100%;
cardOptions:
artwork: full-cover
hide:
power: true
progress: false
runtime: true
icon: true
source: true
volume: true
controls: false
tileOnRow: 9
statePositionTop: true
type: âcustom:homekit-cardâ
useBrightness: false
useTemperature: false
- entities:
- column: 1
Summary
This text will be hidden
This is fantastic work, I am currently updating my whole setup to this
Couple of questions
- is it possible not to display âOnâ âOffâ on the tile? I have found hideState but this seems to be just for brightness or other state?
- the statePositionTop setting, is it possible to set as a per tile basis rather than than global across all tiles on the card?
Apologises if I am missing something.
Have you found a way to hide the circle?
Just found: custom element is not found on load, thereâs a hidden error card saying âCustom element doesn't exist: homekit-card. ...
â After switching to edit mode it is there, thoughâŚ
Hi everyone I had already reported this problem and Dbuit had informed me which colors are assigned to the âonâ or âoffâ icon of the thermostat. Unfortunately, they still do not see the orange icon on (flame symbol), but only gray even when the boiler is on. Could you help me understand why? I attach screenshots
Can inform that it was the Custom header that made its akt as it does for you and me.
Custom header is anounced dead. and wont be updated anymore by its creater. If you remove it you will propably have it working again.
I have the same problem
Hi everyone, is there anyone who has implemented a card on the CARD homekit panel to view live images of an ESP32CAM? I was able to load the software with esphome and view the contents of the camera on a non-Homekit Panel card and also the images are not fluid but jerky. Could you help me if someone has already done something to view the images of an ESP32CAM? Thank you
Not really
Nice Ones!, Mind Sharing your Config?
You better create a popup with picture entity card.
Use the HomeKit Tile to see the presence detection status, and then set a browser-mod popup as âmore-infoâ.
If you want, see my popup here below (the screen isnât on HomeKit Card, but It will work):
The tile should show something like that:
If you need the code, let me know!
That one is a request. He doesnât has that popupâŚ
Grazie Andrea se puoi condividere il codice te ne sarei grato, come sai sono neofita, anche se grazie al forum e alle schede di dBuit ho imparato molto e ci provo sempre, ma qui sto trovando qualche difficoltĂ .
Approfitto della tua gentilezza e conoscenza per chiederti qualche info sulla gestione (nel caso lo usassi) di Spotify. Io ho fatto una scheda seguendo il codice di mini media player, ma ho notato che i comandi avanti, indietro, pausa e play non funzionano. La cosa che mi pare di capire sulla gestione di Spotify è che Spotify deve essere sempre attivo affinchè le playlist create possano essere gestite dal mini media player e solo cosĂŹ funziona lâascolto, ma i comandi di cui sopra comunque non funzionano. Nella configuration.yaml le uniche info da me riportate sono : Client ID e Client Service non so se andrebbe scritto altro.
Grazie per il tuo aiuto
Hello I will have a look what is going on with the climate card.
Just updated thermostat popup card to fix the color of the icons to change when mode is active.
