Custom Lovelace Card - Homekit style card
Tried so many Tiles implementations, Nothing can be compared to yours…
Keep the good work!
Hi Dbuit I tried as soon as I did the update BUT STILL THE FLAME ICON WHEN I PRESS TO LIGHT IT REMAINS GRAY
Hello JEJU_Park after the modification made d DBuit to you the flame of the thermostat lights up? ame still not and also I immediately updated in HACS
@DBuit Thank you very much for your kindness.
Heat mode and off mode operate rightly. However, heat_cool mode doesn’t operate rightly. @DBuit Can you check it?
비정상동작_heat_cool
heat mode and off mode operate rightly. however, heat_cool mode doesn’t…
That is strange all modes work the same.
For me it is working for heat_cool mode…
screenshot
Maybe the color variable is somewhere changed?
In the style part of the popup you can try to set the colors for the modes, this are all variables:
:host {
            --auto-color: #EE7600;
            --eco-color: springgreen;
            --cool-color: #2b9af9;
            --heat-color: #EE7600;
            --manual-color: #44739e;
            --off-color: lightgrey;
            --fan_only-color: #8a8a8a;
            --dry-color: #efbd07;
            --idle-color: #00CC66;
            --unknown-color: #bac;
Thanks @DBuit this finally brings back coloured mode icons :+1:
thank you Jejun
Thank you DBuit
I will test it again… ㅜㅜ
@DBuit
I think it judging by mixing both hvac_action and hvac_mode. Is it right?
When I tested it with heat mode, it didn’t show the color when the mode was heat and hvac_action was idle.
Can you change the logic to judge only by mode?
There was some extra logic that was not needed anymore i guess
I removed it try the new version and let me know.
@DBuit
it operate rightly!!
Thanks for your kindness!!
Sure, you can find my code here: https://github.com/NdR91/NdR-HomeAssistant
Regarding Spotify, i’m not using it, sorry!
(Certo, puoi trovare qui il mio codice: https://github.com/NdR91/NdR-HomeAssistant
Purtroppo non uso Spotify, mi spiace!)
Grazie andrea per la condivisione se non sono troppo invadente mi avevi sugerito per la telecamera di creare una CARD popup ho provato ma senza successo se hai qualcosa tu da condividere te ne sarei grato…sto studiando molto il forum e devo dire che si ottengono buoni risultati più che in un manuale. Grazie ancora.
Great …it operate rightly!!
Thank you for your job!!!
After i updated browser_mod and Light popup card the other day to the latest the no homepage showing started again.
Is there anyway to make the homekit card more informative on what is going on rather then just going totaly blank?
On firefox it happens half the time on chrome its all the time cash cleard
And worst of all browser say no error.
And as before if you go in to edit and out its back.
enableColumns: true
home: false
icon: 'mdi:home-outline'
rows:
  - columns:
      - column: 1
        entities:
          - entities:
              - entity: light.utomhus_vagglampa
                icon: 'mdi:wall-sconce'
                popupExtend:
                  actions: null
                  settings:
                    closeButton: stäng
                    openButton: Inställningar
                  settingsCard:
                    cardOptions:
                      secondary_info: last-changed
                      smooth_color_wheel: true
                    cardStyle: |
                      background-color:#FFF;
                    type: 'custom:light-entity-card'
                  title: Vägglampa
              - deep_press: true
                entity: light.utomhus_ljusslinga
                offStates:
                  - 'off'
                  - unavailable
                  - otillgänglig
                  - unknown
                popupExtend:
                  actions: null
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
              - deep_press: true
                entity: light.busklampor
                offStates:
                  - 'off'
                  - unavailable
                  - otillgänglig
                  - unknown
                popupExtend:
                  actions: null
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
            popup:
              brightnessHeight: 300px
              brightnessWidth: 110px
              scenesInARow: 2
              supportedFeaturesTreshold: 40
              switchHeight: 300px
              switchWidth: 110px
              type: 'custom:light-popup-card'
            title: Utomhus
        tileOnRow: 3
      - column: 1
        entities:
          - entities:
              - deep_press: true
                entity: light.alla_lampor_grupp
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service: light.turn_on
                      service_data:
                        color_temp: 153
                        entity_id: light.alla_lampor_grupp
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                    - color: '#2E8B57'
                      service_data:
                        color_name: seagreen
                    - color: '#D2691E'
                      service_data:
                        color_name: chocolate
                    - color: '#FF00FF'
                      service_data:
                        color_name: fuchsia
                    - color: '#DC143C'
                      service_data:
                        color_name: crimson
                    - color: '#1E90FF'
                      service_data:
                        color_name: dodgerblue
                    - color: '#FFD700'
                      service_data:
                        color_name: gold
                  actionsInARow: 5
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                      consolidate_entities: true
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.vardagsrumslampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.vardagsrumslampor
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                  actionsInARow: 2
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.sovrumslampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.sovrumslampor
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                    - color: '#2E8B57'
                      service_data:
                    - color: '#D2691E'
                      service_data:
                    - color: '#FF00FF'
                      service_data:
                        color_name: fuchsia
                    - color: '#DC143C'
                      service_data:
                        color_name: crimson
                    - color: '#1E90FF'
                      service_data:
                    - color: '#FFD700'
                      service_data:
                        color_name: gold
                  actionsInARow: 5
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.sovrumsbank_lampor_grupp
                name: Sovrums Bänklampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.sovrumsbank_lampor_grupp
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                    - color: '#2E8B57'
                      service_data:
                    - color: '#D2691E'
                      service_data:
                    - color: '#FF00FF'
                      service_data:
                        color_name: fuchsia
                    - color: '#DC143C'
                      service_data:
                        color_name: crimson
                    - color: '#1E90FF'
                      service_data:
                    - color: '#FFD700'
                      service_data:
                        color_name: gold
                  actionsInARow: 5
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.sovrums_temp_lampor_grupp
                name: Sovrum Temp lampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.sovrums_temp_lampor_grupp
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                  actionsInARow: 2
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.evelinsrumslampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.evelinsrumslampor
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                  actionsInARow: 2
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
              - deep_press: true
                entity: light.malvinasrumslampor
                popupExtend:
                  actions:
                    - color: '#d8d9e1'
                      service_data:
                        color_temp: 153
                        entity_id: light.malvinasrumslampor
                    - color: '#d5b08d'
                      service_data:
                        color_temp: 326
                    - color: '#ce944b'
                      service_data:
                        color_temp: 500
                    - color: '#271a00'
                      service_data:
                        brightness: 5
                        color_temp: 500
                  actionsInARow: 2
                  settings:
                    closeButton: stäng
                  settingsCard:
                    cardOptions:
                    cardStyle: |
                  switchHeight: 300px
                  switchWidth: 110px
            popup:
            title: Grupper
        tileOnRow: 7
    row: 1
statePositionTop: false
style: |
  :host {
    --tile-background: rgba(10, 10, 10, 0.22);
    --tile-border-radius: 12px;
    --tile-width: 100px;
    --tile-height: 100px;
    --tile-on-background: var(--card-background-color);
    --tile-name-text-color: var(--paper-item-icon-color);
    --tile-on-name-text-color: var(--primary-text-color);
    --tile-state-text-color: var(--paper-item-icon-color);
    --tile-on-state-text-color: var(--paper-item-icon-active-color);
    --tile-state-changed-text-color: var(--primary-text-color);
    --tile-unavailable-state-text-color: rgba(255, 0, 0, 1);
    --tile-value-text-color: var(--primary-text-color);
    --tile-icon-color: var(--paper-item-icon-color);
    --tile-on-icon-color: var(--paper-item-icon-active-color);
    --tile-width-mobile: 90px;
    --tile-height-mobile: 90px;
    --min-header-height: 150px;
    --tile-icon-size: 30px;
    --tile-image-radius: 100%
    --slider-width: 120px;
    --slider-height: 120px;
title: Home
titleColor: '#FFF'
type: 'custom:homekit-card'
Stiripped down my code to this and it still happens.
Hi there,
I style my tiles dark. Now I just want to modify the icon and text color of the integrated mini-gaph-card. But I got strange results. Am I wrong with something? Is this an issue with my theme I’m using?
Thanks in advance!
left: styled mini-graph (font size too big, background of inner card visible, round corners)
right: default mini-graph
Bildschirmfoto vom 2020-10-23 22-55-10
- card: 'custom:mini-graph-card'
  cardStyle: |
    .header .icon {
        color: #FFFFFF;
  noPadding: true
  cardOptions:
    animate: true
    color_thresholds:
      - color: '#009ddc'
        value: 0
      - color: '#62bb47'
        value: 15
      - color: '#fcb827'
        value: 24
      - color: '#e03a3c'
        value: 30
    entities:
      - entity: sensor.dwd_temperature
    hour24: true
    show:
    hours_to_show: 12
    points_per_hour: 1
Im down to using only these card and im still getting the front page gone
Help me someone…
Ive allso remove to only be using homekit card alone with only its dependensies. Still get it.
