Custom Lovelace Card - Homekit style card
Whent back to 115.5. Then everything is fine again. From what i could tell when i had removed all card exept for whats needed to run homekit card with popup windows then my front page still vanish from time to time.
So sins 116.4 wont work with the setup that has worked with the code basicly copied from the default page i recon something is wrong with it on 116, Is a stated before in the thread first it was the header card. And then came update 0.116.4 and then the problem was back.
I suggest no one update to 116.0-4 if you want the best experiance stay at 115.5
Iā€™d like to have this code. Are you willing to share? Thanks a lot
Sure, you can find the whole stuff on my repo!
Is there a way to control the fan modes and the swing modes?
Those are the attributes i got on my a/c (via Sensibo):
hvac_modes: dry, heat_cool, heat, fan_only, cool, off
min_temp: 16.7
max_temp: 30
fan_modes: quiet, low, medium, high, auto, strong
swing_modes: stopped, rangeFull
current_temperature: 22.9
temperature: 20.6
current_humidity: 53.8
fan_mode: auto
swing_mode: rangeFull
battery: null
friendly_name: Aviah's Room
supported_features: 41
@DBuit Needs to address the issue, the following is from the release notes of Home Assistant.
Breaking Changes
Below is a listing of the breaking change for this release, per subject or integration. Click on one of those to read more about the breaking change for that specific item.
Custom Lovelace Cards
This release contains breaking changes for custom card developers, check the developers blog for more information.
If you have a custom card that stopped working this release, please report this with the custom card author.
Hello everyone,
I have the same problems with the card not loading :frowning:
Im trying to fix it but it is hard when you have no idea what is wrongā€¦
This is the error that is in the screen but hidden:
Custom element doesnā€™t exist: homekit-card.
If someone has some ideas let me know!
For now if you use the 3 dots in the top right corner and hit refresh it should load the card
Hello everyone,
so the problem with the initial load of the card is probably an home assistant bug in how card are loaded.
There are some issues on the hass frontend github starting with this one:
there are related issue that are solved and merged and will be available in next version of HASS.
We need to wait i think hope that will fix the problem
Thx.Atleast i know that i had not missed a small thing xD realy tried to help out and find out what was causing it. But maby its fixed with 117.
Ive just updated to 117.
I had a error with swipe card, So removed it.
But still a no.
Something still making it go invisible sadly :frowning: And still no error what so ever for me atleast.
(allso uppdated hacs and browser_mod to latest)
It didnā€™t change in 0.117, but I found a work around in some discussion from other cards facing this problem: I insert this card in a horizontal stack and first tests look promising :wink:
I confirm that all the required updates have been made but the problem already highlighted with 0.116.4 persists even with version 0.117.0
Hi guys,
so no fix yet but i might have found something :trumpet::trumpet::trumpet:
Try setting panel:true -> to false on your view. for me the card does load, and can you guys @Jimmy_Berglund and @claudiovillani58 test this is that also works for you?
I know it doesnt look the way it should be but than we know a but more about the problem.
ok as soon as I get back from work I try
Hello @DBuit
I confirm you that it works.
Of course, it breaks all the stuff and spacing, but I got your point: the home screen appears without the needs of clicking the three dots.
This could be somethingā€¦
I confirm that the problem disappears but the positions of the cards are messed up
Yeh works flawlessly when putting panel to false
Allso worth noting that for me atleast its always just on the first page. (home)
My second panel with lights only is not affected when switched to.
Maybe this could explain why I never had this problem (still donā€™t have it). My default screen (Overview which is generated by HA) is still there so I guess thatā€™s what you mean by first page. I have 3 other dashboards which all use HomeKit-panel and they all work fine, even while setting some of the HomeKit-panel screens as default dashboards for certain devices (wall mounted tablet and mobile default to these dashboards whereas all other devices like a PC will default to the Overview default dashboard (although it is heavily modified but does not use HomeKit-panel)
I hope this helps your investigations
Yeh thats propably why u did not have the problem. :slight_smile:
Good new there is a fix on the way thomas fixed it! :partying_face:
