The weather card show 3 instead of 5 days when the width of the card is below 245px.
So i cant really do anything but the only way it to increase the --tile-width-mobile so there is atleast 245px.
I tested it and if you set mobile width to 98px it works.
Thx man. Yeh that keeps the days there. half the text still dissapers but it looks better. It does the same on the video i showed before so you get what i mean.
Is there anyway to keep it there? Played abitt witht he high and with but seems to not change anything.
In any case its better and if nothing can be done than im ok.
The popup card stopped working a while ago and i just cant get it to work again.
Been pulling my hair for a while now so writing here in hopes some of you can find my mistake.
Browser_mod is installed and set up in configuration.yaml with browser_mod: and nothing else.
I have all my resources for lovelace listed in configuration file also.
Homekit panel card, card mod and light popup card are installed through HACS and resources added.
Below is my config
In the media view you got a style part where you put a custom width and height.
Have you set any style width and height on the other view? if not maybe try set it with the default valueâs so it does get set when switching maybe it makes sure the values are reset.
Can I put a border around all and/or individual card? Sorry, Iâm really bad with css, so failed to figure it out myself. Approach with --tile-border-color: like tags doesnât work.
Iâm just getting started with these cards, trying to integrate them in so I can use them with Dwainâs Dashboard.
Iâm trying to use a global configuration so all entities of a class open these custom popups. Iâve got that part working just fine, but Iâm having a few issues/questions about the popups themselves.
1: Regardless if a light entity is a switch, dimmer or bulb Iâm getting a popup with only the option of on/off. If I set displayType: auto, theyâre still all on/off. Of course if I set displayType: slider theyâre all slider. How do I get it so it can distinguish between on/off, dimmer and bulb? I hope the answer isnât to create a custom popup for each entity.
2: The popup cards work great on mobile, but through a desktop theyâre extremely cropped. For the light-popup-card setting fullscreen: false seems to do the trick, but that doesnât seem to be working for any of the other card types. This seems to have fixed itself somehow.
Well it actually only works on some and not others. I doesnât work for light groups or lights that have rgb even though I tired useBrightness: false useRGB: false useTemperature: false. I canât get the icon to use the color in --tile-on-icon-color:. It works on switches and plugs for sure but that seems to be about it for me.
I was trying to adjust my Thermostat today via the popup, and discovered I am missing the icons (Hot/Dry/Cold) on the bottom of the popup, The âHot Spotsâ are there and I can click them, But no
Icons or texts appear there⌠(I have to admit I didnât use it for a very long time, Not sure when this problem existsâŚ)
