I love the card by @gerard33, it looks very nice on my wall mounted tablet.
What I’m missing though is a forecast for the current day.
For instance when waking up in the morning, being able to see what the min and max temp is going to be today.
Is there any way to edit the card so that the forecast for the current day is added (and perhaps the last of the 5 forecast days be removed so the size stays the same)?
Hello, thank you for sharing your project with the HomeAssistant community.
I have a question, I have Hassbian installed and the directory where it contains the * .yaml files is: (/home/homeassistant/.homeassistant) however there is no directory (www), and even I creating the directory and putting the necessary files inside, it seems that the Hassbian does not find.
Should I create the directory and set the location like this: (/home/homeassistant/.homeassistant/ www / weather_icons / animated /)? because even then the files are not found.
Thank you for sharing your work with the community.
I need help to solve my problem, I have two weather cards being displayed in my home. I have modified almost everything and nothing to solve.
If anyone can help me, I thank you!
homeassistant:
# Name of the location where Home Assistant is running
name: Lar doce lar!
# Location required to calculate the time the sun rises and sets
latitude: -XX.417859
longitude: -XX.337051
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 330
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Sao_Paulo
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
extra_html_url:
- /local/custom_ui/custom-weather-card.html
extra_html_url_es5:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# base_url: https://XXXXXX.ddns.net:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
api_password: XXXXXXX@
ip_ban_enabled: true
login_attempts_threshold: 5
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Example configuration.yaml entry
camera:
- platform: generic
#mjpeg_url: http://192.168.25.205/mjpeg
still_image_url: http://192.168.25.205/image/jpeg.cgi
username: admin
password: mkmt.vix.
# Enables a map showing the location of tracked devices
map:
# Track the sun
# sun:
# Weather prediction
weather:
- platform: yweather
woeid: "26800926"
input_boolean:
weather:
I have been trying to get this to work the whole day, tried everything i can think of.
But i do not get the mdi icons in frot of the humidity/windspeed etc.
I configured it just like mentioned in this post, also used this html
