Custom UI: Weather state card
Updated the card for Lovelace:
I’m loving the lovelace card, thanks @Bram_Kragten . But on my iPhone XS, it shows the animated weather images in very blurry / low res quality (both in the official iOS app and the Safari web browser). I am using the hosted method, not local/manual.
Is this intentional, or a bug?
Here’s a pic:
I get this sometimes too. I put it down to there not being any @2x images for the retina display.
this has been there for ages on these cards. has to do with the rendering of the page on the device. And is probably gone the you slide the card up. Comes and goes.
How did you create the card with the text of the current and upcoming weather?
Darksky Sensor in configuration.yaml:
  - platform: darksky
    api_key: !secret darksky_key
    update_interval:
      minutes: 12
    forecast:
    - 0
    monitored_conditions:
    - temperature_high
    - temperature_low
    - apparent_temperature_high
    - apparent_temperature_low
    - summary
    - icon
    - nearest_storm_distance
    - precip_type
    - precip_intensity
    - precip_probability
    - temperature
    - dew_point
    - wind_speed
    - wind_bearing
    - wind_gust
    - cloud_cover
    - humidity
    - pressure
    - visibility
    - ozone
    - minutely_summary
    - hourly_summary
    - daily_summary
And an entities card in lovelace:
      - type: entities
        show_header_toggle: false
        entities:
        - sensor.dark_sky_hourly_summary
        - sensor.dark_sky_daily_summary
I’m getting an error…
2019-02-08 18:13:40 ERROR (MainThread) [frontend.js.es5.201901211] http://hassbian.local:8123/lovelace/0:0:0 Uncaught
My ui-lovelace.yaml
  - url: /local/weather-card.js
    type: module
      - type: custom:weather-card
        entity: weather.dark_sky
        icons: "/local/icons/weather_icons/animated/"
I tried adding this to my configuration file:
# DarkSky Weather
weather:
  - platform: darksky
    mode: daily
    - hourly_summary
    - daily_summary
But I don’t get any sensor with the added monitored_conditions:
that’s because you’re using the weather platform, not the sensor:
Right!
Will see if I can manage to change it and still get my weather card as it is right now :blush:
You can use both the weather platform and the sensor at the same time. I actually have 2 weather platforms and a sensor defined.
Is anyone able to help with this please?
It is a vector, so no pixels or 2x images needed :wink:. The pixels are something Apple does, I dont think we can solve that.
You are using es5, what device is this? Try setting the frontend to latest.
It’s Samsung internet browser, frontend is set to latest:
javascript_version: latest
Same issue with that commented out
Can’t you use Chrome?
same problem in chrome too :confused:
also the same in Edge
Made an account to say great job! :slight_smile:
Thanks, but that’s too much honor :blush: . I just made some small adjustments to this card.
In the meanwhile the weather card has improved very much. You can have a look at the current card I am using over here -> https://github.com/iammexx/home-assistant-config/tree/master/ui/darksky.
Is there an option to integrate rain predictions per hour? There are multiple sites that over an overview of the rain in the upcoming hours e.g. weeronline.nl
My best guess would be to scrape the page. But my coding skills are limited…
