D-Link DSP-W118 plug timeout
Bit of a long shot… but has anybody had any luck getting D-Link DSP-W118 plugs to work?
I have tried the existing D-Link integration, and also tried getting a custom competent from here:
…to at least connect to the plug, but unfortunately it just times out.
2019-09-01 02:30:34 INFO (MainThread) [custom_components.dlink_motion_sensor.dlink] Logging into device
2019-09-01 02:30:44 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.some_sensor is taking over 10 seconds
2019-09-01 02:30:44 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating dlink_motion_sensor binary_sensor took longer than the scheduled update interval 0:00:10
2019-09-01 02:30:44 ERROR (MainThread) [custom_components.dlink_motion_sensor.dlink] Got an error, resetting private key
2019-09-01 02:30:44 ERROR (MainThread) [custom_components.dlink_motion_sensor.binary_sensor] failed to update motion sensor
  File "D:\HomeAssistant\.homeassistant\custom_components\dlink_motion_sensor\dlink.py", line 105, in call
    result = yield from self.soap().call(method, **kwargs)
  File "D:\HomeAssistant\.homeassistant\custom_components\dlink_motion_sensor\dlink.py", line 225, in call
    self.address, data=xml, headers=headers, timeout=10)
  File "c:\users\joe\homeassistant\lib\site-packages\aiohttp\client.py", line 575, in _request
    break
  File "c:\users\joe\homeassistant\lib\site-packages\aiohttp\helpers.py", line 585, in __exit__
    raise asyncio.TimeoutError from None
concurrent.futures._base.TimeoutError
Any suggestions for debugging why it won’t respond? I tried ping command in Windows cmd shell but I get this (I guess not surprisingly):
Pinging 198.168.0.106 with 32 bytes of data:
Reply from 198.168.#.###: Destination host unreachable.
Thanks.
Hey gjjb777,
Ever get your D-Link DSP-W118 to work as I have one too?
Hi @wizoz,
Unfortunately not :frowning:
I was hopeful that it would still use the same login procedure as the other plugins. But it just seems to not respond.
I live in New Zealand, so there are literally only 3 sockets like this on the market. The other makes a high pitched whine when it is off, which I find annoying for use in bedrooms (TP-link one).
I was going to try a power strip (Vivitar Smart Security WiFi 4 Way Powerstrip), but seems it still has to go through the cloud (and its additional money), Vivitar WiFi Powerstrip, so was not ideal.
Hey guys, did you ever get that to work? Was considering a 2-pack but would only buy if there is HA integration. No interested in using their silly App…
I don’t recommend any D-Link devices. All mine have just stopped working, even on the device itself. :confused:
Hi, any news about DSP-W118 integration in Home Assistant?
Hi… Did anyone get the D-Link DSP-W118 working with HA?
Not yet but I am hoping for some resourceful developer to have a look at the code, probably something simple?
I’ve got the same challenge, after buying such a device. Before i found this thread, i opened a new one here How to bring D-Link DSP-W118 out of cloud into HA?
