markus3
(Marco)
May 1, 2021, 11:30am
21
the two routers are at 1 meter distance and wire connected (LAN to LAN port) since I’m doing these testings.
INFO Reading configuration /config/esphome/saletta_temp_sensor.yaml...
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[13:25:30][D][wifi:324]: Starting scan...
[13:25:36][D][wifi:339]: Found networks:
[13:25:36][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:25:36][W][wifi:394]: No matching network found!
[13:25:41][D][wifi:324]: Starting scan...
[13:25:47][D][wifi:339]: Found networks:
[13:25:47][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:25:47][W][wifi:394]: No matching network found!
[13:25:52][D][wifi:324]: Starting scan...
[13:25:58][D][wifi:339]: Found networks:
[13:25:58][D][wifi:341]: No network found!
[13:26:03][D][wifi:324]: Starting scan...
[13:26:09][I][wifi:116]: Starting fallback AP!
[13:26:09][C][wifi:161]: Setting up AP...
[13:26:09][C][wifi:163]: AP SSID: 'Sensor Saletta Temp'
[13:26:09][C][wifi:164]: AP Password: '7ta8GtVGagir'
[13:26:09][C][wifi:173]: IP Address: 192.168.4.1
[13:26:10][D][wifi:339]: Found networks:
[13:26:10][D][wifi:341]: No network found!
[13:26:15][D][wifi:324]: Starting scan...
[13:26:21][D][wifi:339]: Found networks:
[13:26:21][D][wifi:341]: No network found!
[13:26:26][D][wifi:324]: Starting scan...
[13:26:32][D][wifi:339]: Found networks:
[13:26:32][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:26:32][W][wifi:394]: No matching network found!
[13:26:37][D][wifi:324]: Starting scan...
[13:26:43][D][wifi:339]: Found networks:
[13:26:43][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:26:43][W][wifi:394]: No matching network found!
[13:26:48][D][wifi:324]: Starting scan...
[13:26:54][D][wifi:339]: Found networks:
[13:26:54][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:26:54][W][wifi:394]: No matching network found!
[13:26:59][D][wifi:324]: Starting scan...
[13:27:05][D][wifi:339]: Found networks:
[13:27:05][D][wifi:341]: No network found!
[13:27:10][D][wifi:324]: Starting scan...
[13:27:16][D][wifi:339]: Found networks:
[13:27:16][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:27:16][W][wifi:394]: No matching network found!
[13:27:21][D][wifi:324]: Starting scan...
[13:27:26][D][wifi:339]: Found networks:
[13:27:26][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[13:27:27][W][wifi:394]: No matching network found!
[13:27:32][D][wifi:324]: Starting scan...
[13:27:37][D][wifi:339]: Found networks:
[13:27:37][D][wifi:341]: No network found!
[13:27:42][D][wifi:324]: Starting scan...
[13:27:48][D][wifi:339]: Found networks:
[13:27:48][D][wifi:341]: No network found!
[13:27:53][D][wifi:324]: Starting scan...
[13:27:59][D][wifi:339]: Found networks:
[13:27:59][D][wifi:341]: No network found!
[13:28:04][D][wifi:324]: Starting scan...
markus3
(Marco)
May 1, 2021, 1:13pm
22
I tried to flash another D1 mini with esphome-flasher. Now the D1 sees the network but still cannot connect to.
Using 'COM3' as serial port.
Connecting....
Detecting chip type... ESP826 %)Writing at 0x00044000... (100 %)Wrote 401952 bytes (278885 compressed) at 0x00000000 in 7.1 seconds (effective 454.9 kbit/s)...
Hash of data verified.
Leaving...
Hard Resetting...
Done! Flashing is complete!
Showing logs:
[14:51:21][I][logger:166]: Log initialized
[14:51:21][C][ota:366]: There have been 2 suspected unsuccessful boot attempts.
[14:51:21][I][app:029]: Running through setup()...
[14:51:21][C][dht:011]: Setting up DHT...
[14:51:21][C][wifi:033]: Setting up WiFi...
[14:51:22][D][wifi:324]: Starting scan...
[14:51:27][D][wifi:339]: Found networks:
[14:51:27][D][wifi:389]: - 'FRITZ!BoxMyNet_LR' (8C:6D:50:8F:44:A0) ▂▄▆█
[14:51:27][D][wifi:389]: - 'Disappinted 2.0' (78:94:B4:8A:24:83) ▂▄▆█
[14:51:27][D][wifi:389]: - 'WOW FI - FASTWEB' (E2:19:54:9B:8C:44) ▂▄▆█
[14:51:28][D][wifi:389]: - 'FASTWEB-GA3ADQ' (E0:19:54:9B:8C:44) ▂▄▆█
[14:51:28][D][wifi:389]: - 'Home&Life SuperWiFi-024969' (78:B2:13:2B:A3:03) ▂▄▆█
[14:51:28][W][wifi:394]: No matching network found!
[14:51:33][D][wifi:324]: Starting scan...
[14:51:38][D][wifi:339]: Found networks:
[14:51:38][I][wifi:385]: - 'Dungeon' (18:A6:F7:05:F5:A2) ▂▄▆█
[14:51:38][D][wifi:386]: Channel: 3
[14:51:38][D][wifi:387]: RSSI: -53 dB
[14:51:38][D][wifi:389]: - 'Disappinted 2.0' (78:94:B4:8A:24:83) ▂▄▆█
[14:51:38][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:51:41][W][dht:162]: Requesting data from DHT failed!
[14:51:41][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[14:51:41][D][sensor:092]: 'Saletta Temperature': Sending state nan °C with 1 decimals of accuracy
[14:51:41][D][sensor:092]: 'Saletta Humidity': Sending state nan % with 0 decimals of accuracy
[14:51:42][W][wifi_esp8266:444]: Event: Disconnected ssid='Dungeon' bssid=18:A6:F7:05:F5:A2 reason='Auth Expired'
[14:51:42][W][wifi:485]: Error while connecting to network.
[14:51:42][W][wifi:522]: Restarting WiFi adapter...
[14:51:42][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:51:48][W][wifi_esp8266:441]: Event: Disconnected ssid='Dungeon' reason='Probe Request Unsuccessful'
[14:51:48][W][wifi:485]: Error while connecting to network.
[14:51:48][W][wifi:522]: Restarting WiFi adapter...
[14:51:53][D][wifi:324]: Starting scan...
[14:51:59][D][wifi:339]: Found networks:
[14:51:59][I][wifi:385]: - 'Dungeon' (18:A6:F7:05:F5:A2) ▂▄▆█
[14:51:59][D][wifi:386]: Channel: 3
[14:51:59][D][wifi:387]: RSSI: -50 dB
[14:51:59][D][wifi:389]: - 'Disappinted 2.0' (78:94:B4:8A:24:83) ▂▄▆█
[14:51:59][D][wifi:389]: - 'FRITZ!BoxMyNet_EXT' (80:3F:5D:67:76:69) ▂▄▆█
[14:51:59][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:52:02][W][wifi_esp8266:444]: Event: Disconnected ssid='Dungeon' bssid=18:A6:F7:05:F5:A2 reason='Auth Expired'
[14:52:02][W][wifi:485]: Error while connecting to network.
[14:52:02][W][wifi:522]: Restarting WiFi adapter...
[14:52:02][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:52:04][W][wifi_esp8266:444]: Event: Disconnected ssid='Dungeon' bssid=18:A6:F7:05:F5:A2 reason='Auth Expired'
[14:52:04][W][wifi:485]: Error while connecting to network.
[14:52:04][W][wifi:522]: Restarting WiFi adapter...
[14:52:09][D][wifi:324]: Starting scan...
[14:52:11][W][dht:162]: Requesting data from DHT failed!
[14:52:11][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[14:52:11][D][sensor:092]: 'Saletta Temperature': Sending state nan °C with 1 decimals of accuracy
[14:52:11][D][sensor:092]: 'Saletta Humidity': Sending state nan % with 0 decimals of accuracy
[14:52:15][D][wifi:339]: Found networks:
[14:52:15][I][wifi:385]: - 'Dungeon' (18:A6:F7:05:F5:A2) ▂▄▆█
[14:52:15][D][wifi:386]: Channel: 3
[14:52:15][D][wifi:387]: RSSI: -48 dB
[14:52:15][D][wifi:389]: - 'Disappinted 2.0' (78:94:B4:8A:24:83) ▂▄▆█
[14:52:15][D][wifi:389]: - 'FRITZ!BoxMyNet_LR' (8C:6D:50:8F:44:A0) ▂▄▆█
[14:52:15][D][wifi:389]: - 'FRITZ!BoxMyNet' (18:0F:76:BC:EE:D2) ▂▄▆█
[14:52:15][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:52:21][W][wifi_esp8266:441]: Event: Disconnected ssid='Dungeon' reason='Probe Request Unsuccessful'
[14:52:21][W][wifi:485]: Error while connecting to network.
[14:52:21][W][wifi:522]: Restarting WiFi adapter...
[14:52:21][I][wifi:194]: WiFi Connecting to 'Dungeon'...
[14:52:21][I][wifi:116]: Starting fallback AP!
[14:52:21][C][wifi:161]: Setting up AP...
[14:52:21][C][wifi:163]: AP SSID: 'Saletta T-H Fallback Hotspot'
[14:52:21][C][wifi:164]: AP Password: 'LyM8fY73ZnRL'
[14:52:22][C][wifi:173]: IP Address: 192.168.4.1
[14:52:28][W][wifi_esp8266:441]: Event: Disconnected ssid='Dungeon' reason='Probe Request Unsuccessful'
[14:52:28][W][wifi:485]: Error while connecting to network.
[14:52:33][D][wifi:324]: Starting scan...
[14:52:39][D][wifi:339]: Found networks:
[14:52:39][D][wifi:389]: - 'Disappinted 2.0' (78:94:B4:8A:24:83) ▂▄▆█
[14:52:39][D][wifi:389]: - 'FRITZ!BoxMyNet_EXT' (80:3F:5D:67:76:69) ▂▄▆█
[14:52:39][W][wifi:394]: No matching network found!
[14:52:41][W][dht:162]: Requesting data from DHT failed!
[14:52:41][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[14:52:41][D][sensor:092]: 'Saletta Temperature': Sending state nan °C with 1 decimals of accuracy
[14:52:41][D][sensor:092]: 'Saletta Humidity': Sending state nan % with 0 decimals of accuracy
[14:52:44][D][wifi:324]: Starting scan...
I’m spit balling here: I know there are imitation boards out there. Could it be that? Alternatively, could there be an issue with your ESPHome installation (say a dependency giving issues but not visibly so besides the symptoms)?
birchman
(Mattias Björkman)
May 1, 2021, 4:11pm
24
Found this.
Playing around with a esp8266 nodemcu
I getting “Probe Request Unsuccessful”
[17:07:50][W][wifi:451]: Error while connecting to network.
[17:07:55][D][wifi:304]: Starting scan...
[17:08:01][D][wifi:319]: Found networks:
[17:08:01][I][wifi:365]: - 'MYLE-2' (D8:5D:4C:E5:80:FE) ▂▄▆█
[17:08:01][D][wifi:366]: Channel: 11
[17:08:01][D][wifi:367]: RSSI: -65 dB
[17:08:01][D][wifi:369]: - 'MYLE' (18:F1:45:C2:E1:27) ▂▄▆█
[17:08:01][D][wifi:369]: - 'DIRECT-0A-HP MYLE' (F4:39:09:A4:6A:0B) ▂▄▆█
[17…
That points to this
opened 04:43PM - 26 Dec 19 UTC
closed 11:26AM - 10 Feb 21 UTC
stale
<!-- Thanks for reporting a bug for this project. READ THIS FIRST:
- Provide … as many details as possible. Simply saying "X gives bug" or "X gives error" is not enough!
- Paste logs, configuration sample and code into the backticks (```).
- Read through the template carefully and fill out all missing details.
- Please also search for similar issues in this issue tracker first and read through the ESPHome FAQ.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue may be closed without a comment.
**Operating environment/Installation (Hass.io/Docker/pip/etc.):**
Please provide details about your environment below this line. -->
ESPHome v1.14.3 docker image esphome/esphome @ ubuntu 18.04 x64, 8GB ram, Intel core2 cpu
**ESP (ESP32/ESP8266, Board/Sonoff):**
Please provide details about which ESP you're using below.
ESP8266, nodemcuv2 board, AM2302 connected to gpio12 with pullup resistor to +3.3V
**Affected component:**
Please add the link to the documentation at https://esphome.io/index.html of the component in question.
https://esphome.io/components/wifi.html
https://esphome.io/components/sensor/dht.html
**Description of problem:**
When there is static IP and AM2302 sensor in yaml config, it compiles, uploads (over USB), but ESP never get connected to WiFi, trying again and again (see log bellow - reason='Probe Request Unsuccessful'). If I comment out static IP parametters OR the DHT sensor block it connects to WiFi without problems, instantly.
Not sure if it is DHT sensor or WiFi component problem.
**Problem-relevant YAML-configuration entries:**
```yaml
PASTE YAML FILE HERE
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
# fast_connect: True
ssid: "Garden WiFi"
password: "somepassword"
# if I comment out these 4 lines it connects without problem
manual_ip:
static_ip: 192.168.88.49
gateway: 192.168.88.1
subnet: 255.255.255.0
ap:
ssid: "Humi01 Fallback Hotspot"
password: "0WxDuZdCQYqq"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "otapassword"
ota:
#also if I comment out this sensor block it connects without problem - does not make sense
- platform: dht
pin: GPIO12
temperature:
name: "Living Room Temperature"
humidity:
name: "Living Room Humidity"
update_interval: 60s
model: AM2302
**Logs (if applicable):**
Please copy the debug log here. If possible, also connect to the ESP over USB and copy those logs into the backticks.
PASTE DEBUG LOG HERE
[logger:156]: Log initialized
[16:20:00][C][ota:364]: There have been 0 suspected unsuccessful boot attempts.
[16:20:00][I][app:028]: Running through setup()...
[16:20:00][C][dht:011]: Setting up DHT...
[16:20:00][C][wifi:033]: Setting up WiFi...
[16:20:00][D][wifi:304]: Starting scan...
[16:20:00][D][dht:048]: Got Temperature=25.4°C Humidity=53.1%
[16:20:00][D][sensor:092]: 'Living Room Temperature': Sending state 25.40000 °C with 1 decimals of accuracy
[16:20:00][D][sensor:092]: 'Living Room Humidity': Sending state 53.10000 % with 0 decimals of accuracy
[16:20:06][D][wifi:319]: Found networks:
[16:20:06][I][wifi:365]: - 'Garden WiFi' (00:14:BF:3C:F4:B3) ▂▄▆█
[16:20:06][D][wifi:366]: Channel: 1
[16:20:06][D][wifi:367]: RSSI: -53 dB
[16:20:06][I][wifi:365]: - 'Garden WiFi' (00:26:5A:77:C1:E0) ▂▄▆█
[16:20:06][D][wifi:366]: Channel: 13
[16:20:06][D][wifi:367]: RSSI: -71 dB
[16:20:06][I][wifi:365]: - 'Garden WiFi' (CE:2D:E0:04:38:65) ▂▄▆█
[16:20:06][D][wifi:366]: Channel: 9
[16:20:06][D][wifi:367]: RSSI: -79 dB
[16:20:06][D][wifi:369]: - 'MikroTik-043865' (CC:2D:E0:04:38:65) ▂▄▆█
[16:20:06][D][wifi:369]: - 'STARNET_Mikulica' (E4:8D:8C:8C:CC:BE) ▂▄▆█
[16:20:06][I][wifi:193]: WiFi Connecting to 'Garden WiFi'...
[16:20:12][W][wifi_esp8266:334]: Event: Disconnected ssid='Garden WiFi' reason='Probe Request Unsuccessful'
[16:20:12][W][wifi:451]: Error while connecting to network.
[16:20:12][W][wifi:488]: Restarting WiFi adapter...
[16:20:12][I][wifi:193]: WiFi Connecting to 'Garden WiFi'...
[16:20:18][W][wifi_esp8266:334]: Event: Disconnected ssid='Garden WiFi' reason='Probe Request Unsuccessful'
[16:20:18][W][wifi:451]: Error while connecting to network.
[16:20:18][W][wifi:488]: Restarting WiFi adapter...
[16:20:23][D][wifi:304]: Starting scan...
[16:20:29][D][wifi:319]: Found networks:
[16:20:29][I][wifi:365]: - 'Garden WiFi' (00:26:5A:77:C1:E0) ▂▄▆█
[16:20:29][D][wifi:366]: Channel: 13
[16:20:29][D][wifi:367]: RSSI: -71 dB
[16:20:29][I][wifi:365]: - 'Garden WiFi' (CE:2D:E0:04:38:65) ▂▄▆█
[16:20:29][D][wifi:366]: Channel: 9
[16:20:29][D][wifi:367]: RSSI: -81 dB
[16:20:29][I][wifi:365]: - 'Garden WiFi' (00:14:BF:3C:F4:B3) ▂▄▆█
[16:20:29][D][wifi:367]: RSSI: -54 dB
[16:20:29][D][wifi:369]: - 'MikroTik-043865' (CC:2D:E0:04:38:65) ▂▄▆█
[16:20:29][I][wifi:193]: WiFi Connecting to 'Garden WiFi'...
[16:20:35][W][wifi_esp8266:334]: Event: Disconnected ssid='Garden WiFi' reason='Probe Request Unsuccessful'
[16:20:35][W][wifi:451]: Error while connecting to network.
[16:20:35][W][wifi:488]: Restarting WiFi adapter...
[16:20:36][I][wifi:193]: WiFi Connecting to 'Garden WiFi'...
[16:20:41][W][wifi_esp8266:334]: Event: Disconnected ssid='Garden WiFi' reason='Probe Request Unsuccessful'
[16:20:41][W][wifi:451]: Error while connecting to network.
[16:20:41][W][wifi:488]: Restarting WiFi adapter...
**Additional information and things you've tried:**
Checked that there is no other device with conflicting IP on my network, also tried to change the IP to different one
also tested with other components such as switch or IR receiver and had no problems to connect to WiFi using the same board and static IP
tried fast_connect: True (you cen see it commented out in my yaml), same situation, refuse to connect
also as you may notice from the logs I have 3 APs with the same SSID in my house (all connected to the same network, with same passwords), not sure if it can be related to this but never had a problem with ESPs / any other wifi devices
all passwords in the yaml above were changed :-)
It little bit like your problems that your experience.
Is your d1 unshielded. Maybe there is a hardware issue that make it work poorly with some router.
/Mattias
Troon
(Troon)
May 1, 2021, 4:33pm
25
You shouldn’t use channel 3. The accepted 2.4GHz channels to avoid overlap are 1, 6 and 11. What channel is the other router running? It’s possible that with two so close together, there’s a lot of interference.
Are you certain you have the password right?
markus3
(Marco)
May 2, 2021, 8:47am
26
Nothing. I followed all your suggestions. Made a brand new installation of everything. Factory reset of main router and secondary router. I ordered a genuine D1 mini. I will try to install it and see if it’s the quality of the components. I will post the results.
Thank you all for your support until now.
Another idea: can you swap your routers, meaning make the other one the primary and see if the issue moves with the router or not? I’m working from the assumption that (one of your many) D1s still connect fine to the primary router (you said so very early so not sure if that’s still the case).
Troon’s first post is correct. The gateway: value should be your 192.168.1.1 router, and NOT the access point.
markus3
(Marco)
May 2, 2021, 10:08am
29
This is the fact That makes me crazy: connecting to the main router is no issue. Connecting to the AP simply doesn’t go with this mini. As I told above I have 2 smart sockets a strip lead and my phone connecting flowlessly with the AP
If I put 192.168.1.1 in the LAN configuration of the router my whole LAN goes crazy.
I think I expressed myself badly. I mean: swap the configurations of the two routers, so that the secondary is now the primary with the name of the primary’s AP (in other words, the primary that works now is the AP that the secondary was before).
There’s something odd here. In the other posts you mention 192.168.1.1
and here it’s 192.168.0.1
– which is a different segment.
Echoing what Troon and Fred said: your gateway for all devices should be 192.168.1.1
regardless of the AP it’s connecting to – assuming you only have one logical network. The secondary router, while it has a fixed IP (normally), routes to the primary (also the gateway). There are obviously other ways to set up networks but I’m assuming the typical home setup here.
(Disclaimer: I’m by no means a CISCO certified engineer and though I think I understand some networking basics, feel free to point out any mistakes.)
markus3
(Marco)
May 2, 2021, 2:56pm
31
This is the last configuration of my sensor:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "Dungeon"
password: "xxxxxxxxxx"
manual_ip:
static_ip: 192.168.1.100
gateway: 192.168.1.1
ap:
ssid: "Saletta T-H Fallback Hotspot"
password: "LyM8fY73ZnRL"
captive_portal:
# Enable logging
logger:
api:
ota:
- platform: dht
pin: D2
temperature:
name: "Saletta Temperature"
humidity:
name: "Saletta Humidity"
update_interval: 30s
and this is the resume of the configuration of my AP.
I flashed the D1 mini again with the last configuration via USB on the RPI4.
Still cannot get connection.
nickrout
(Nick Rout)
May 3, 2021, 7:56am
32
riemers
(Erik-Jan Riemers)
May 3, 2021, 12:38pm
33
Humor me, change your SSID to all lower case, and change that accordingly also for your d1 mini. I had a similar case in the past where i bumped into a strange issue like that. Can’t hurt to try. (was also with a d1 mini)
Review the IP address assignment for your Access Point.
Your graphic image shows 192.168 .0 .1.
It should be something like 192.168 .1 .nnn.
Your D1 mini has 192.168 .1 .xxx.
Your AP should have 192.168 .1 .nnn.
markus3
(Marco)
May 3, 2021, 3:55pm
35
Thanks for this reply. Now I reset the AP which has now IP 192.168.1.2
I reflashed the d1 mini which now has has static IP 192.168.1.50
I can connect to the AP with the PC and surf internet.
What am I doing wrong with the d1 mini?
markus3
(Marco)
May 3, 2021, 4:05pm
36
Last update: I flashed a new d1 mini from AZDelivery and connected like charm. No issue. It was the expressif clone.
