I have just ordered a new Daikin system and it will come with WIFI module BRP069A81.
Would I be able to fully integrate my system in HA?
Hi Andriy7811,
I bought a new Daikin too and It comes with BRP069a81. Did you manage to link it with home assistant?
Thanks!!
Did not install it yet, but I’ve been told by Daikin this should be possible.
I’m planning to do that within the next month, and I will share anything good.
Are you facing issues with that?
I’m going to buy my unit today but it won’t be installed for another month, so I won’t be able to test until then. Thanks for your answer.
I should be able to share my experience before, hopefully it will be an easy one
I hope so too, if I get it I’ll tell you the details
Can someone confirm that HA is working with wifi unit BRP069A81? Thanks.
Hi.
This BRP069A81 Daikin reference includes a BRP069A42 unit. I can confirm it works perfectly with HA.
Please bear in mind that the BRP069C81 does not work with HA, at least using the standard Daikin AC integration.
