Daily Utility meter suddenly stops to reset at midnight
And girls, and others. We are a diverse lot please do not limit your available help like that it is quite insulting.
Here:
And here: Utility Meter no longer resetting correctly in 2024.12
You are the second person I’ve seen report this. It continues to work for everyone else.
Can you post a screenshot of the history graph for the source sensor the utility meter is using, covering the same time range as the one you show above?
Also a close-up around one of the midnight reset failures for the sources sensor.
