I have a load of utility meters that are set to reset daily. For the last 2 days this is not working correctly. I have not changed anything with my config apart from updating to 2024.12 a couple of days ago.
Anyone else seeing this? Chart below shows the change in how it is working.
Unfortunately this issue has returned after a couple of days working again so I donβt think 2024.12.1 fixed it.
So now I am investigating again and have found something strange but not sure if it is related.
I noticed a file named core (700mb) in my home assistant config directory. I have never seen this file before. The timestamp on the file is 12:03am. Looking at the utility meters I see they update to the incorrect value at 12:03am.
same issue in my setup
i have a daily utility meter, i config to reset daily after reading my electric company meter which is always goes up and never resets
but the util meter seems to go up always never reset
i use helper util meter
any idea?
For my issue it was a HACS integration crashing my system at exactly 12am and this was interfering with the utility meter reset.
When I was looking into this issue, I created a few utility meter helpers for testing. Use a source sensor that is always changing and create a hourly and daily test utility meter.
Post back if you can confirm it is not working as expected.
