ZwaveJS won’t try to update it if the file isn’t the right type of file, but according to their website, you update these locks via bluetooth on your phone rather than via ZWave.
Got almost same configuration HA. With the danalock.
Only I run my Z-Stick 7 only with z-waveJS. Not with the mqtt
And my HA is on proxmox VM on NUC love it
But the danalock I only have updated this with the app.
Few years ago it had to be done with a separate app of danalock now it can be done in the app itself.
Hi @D-Vine, nice to hear from you again! Excuse me for the late respond
Your answer, seems to me, sure is valid.
Spot on!
I have to try it, but I have to change my LAN setup and the Android App (blocked all LAN ↔ WAN traffic for security/privacy reasons). I will do so when I have some time left…
Did you noticed any changes with the new firmware? I didn’t find any changelog of the firmware…
FYI, I disabled MQTT in my Z-Wave JS to MQTT addon, as mentioned in the release notes:
Note: Unlike the title of the software suggests, you don’t need to use MQTT part (it is even disabled by default). It will work directly without MQTT using the Home Assistant integration. The add-on will provide a nice secondairy and extensive Z-Wave JS control interface in such cases.
Is there any special procedure on how to add the Danalock V3 zwave to HA. I have an aeotec z-stick 7 and I just clicked to add new device, put the lock in the inclusion mode and it was added. However, even though it does shows the lock’s status, nothing happens when I click to close the lock. It is completely unresponsive. Am I missing anything? Could you give me any tips on how to configure it correctly to make sure that I can lock/unlock from HA? Thank you!
Thank you for your reply! I posted a bit too early. I read through more topics later and found the same advice. I thought that I was close enough at around 2m but then I moved just 30 cm away and that solved it.
Does anyone knows if any Z-Wave Parameters are changed or added (from firmware 0.17.x → 0.21.7) ?
I looks like the Bluetooth remains enabled even when I disable it by Z-Wave…
E.g. I can access my lock by my Android Danalock App, which seems strange to me. I disabled Z-Wave by Home Assistant setting BLE: Always option to disabled. Also when using the Z-Wave JS UI Control Panel → Danalock Node → Values → Configuration v4 → [8-112-0-5] BLE: Always / Custom Configuration - Parameter 5 - get it is reporting the BLE is disabled (0)…
Strange…
Addition 20230902: I noticed two configuration options are added to my HA Danalock Z-Wave device, param005_1 and param001_1.
