awesome work, thanks @fredrike
got a few of errors in the log, I haven’t in the HA docker image before, any suggestions, please?!
No data in response from hub None
17:23 components/xiaomi_aqara/binary_sensor.py (ERROR) - message first occured at 14. Juli 2019, 21:05 and shows up 7 times
Cannot connect to Gateway
Update of binary_sensor.door_window_sensor_xxxxx is taking over 10 seconds
17:23 main.py (WARNING) - message first occured at 14. Juli 2019, 21:05 and shows up 7 times
Error doing job: Task exception was never retrieved
15:08 util/temperature.py (ERROR) - message first occured at 00:47 and shows up 25 times
Unable to connect to Dark Sky. HTTPSConnectionPool(host=‘api.darksky.net’, port=443): Max retries exceeded with url: /forecast/XXXXXXXXXXXXX?units=ca&lang=en (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc00a51c908>: Failed to establish a new connection: [Errno -3] Try again’))
15:05 components/darksky/weather.py (ERROR)
Endpoint is disabled
13:41 components/ios/notify.py (ERROR) - message first occured at 07:00 and shows up 5 times
Got exception while fetching the state: Unable to discover the device 192.168.178.43
10:36 components/xiaomi_miio/vacuum.py (WARNING) - message first occured at 03:52 and shows up 3 times
Unable to discover a device at address 192.168.178.43
10:36 components/xiaomi_miio/vacuum.py (ERROR) - message first occured at 03:52 and shows up 3 times
Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
10:36 main.py (WARNING) - message first occured at 03:52 and shows up 2 times
Unable to connect to Dark Sky: HTTPSConnectionPool(host=‘api.darksky.net’, port=443): Max retries exceeded with url: /forecast/XXXXXXXXXXXXX?units=si&lang=de (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc00a4d38d0>: Failed to establish a new connection: [Errno -3] Try again’))
08:03 components/darksky/sensor.py (ERROR)
Unable to connect to Dark Sky. HTTPSConnectionPool(host=‘api.darksky.net’, port=443): Max retries exceeded with url: /forecast/XXXXXXXXXXXXX?units=ca&lang=en (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc00a502a20>: Failed to establish a new connection: [Errno -3] Try again’))
05:04 components/darksky/weather.py (ERROR)
Unable to connect to Dark Sky. HTTPSConnectionPool(host=‘api.darksky.net’, port=443): Max retries exceeded with url: /forecast/XXXXXXXXXXXXX?units=ca&lang=en (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc00a18c3c8>: Failed to establish a new connection: [Errno -3] Try again’))
03:28 components/darksky/weather.py (ERROR)
Unable to connect to Dark Sky. HTTPSConnectionPool(host=‘api.darksky.net’, port=443): Max retries exceeded with url: /forecast/XXXXXXXXXXXXX?units=ca&lang=en (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc00a17b940>: Failed to establish a new connection: [Errno -3] Try again’))
00:47 components/darksky/weather.py (ERROR)
Update for media_player.vu_zero4k fails
- Juli 2019, 22:01 components/enigma2/media_player.py (ERROR) - message first occured at 14. Juli 2019, 22:00 and shows up 6 times
http://192.168.178.23:8123/frontend_latest/chunk.cc929c57c6a4d7f5f19d.js:2877:1343 TypeError: e is undefined
- Juli 2019, 20:47 components/system_log/init.py (ERROR)
