Dashboard help - looking to have rotation of 3 cameras in my dashboard show on one card
Good afternoon, all, I have three cameras that I want to rotate on a single card on my dashboard and have found anyway to do that yet?
Here is a screenshot of one of my cameras on a picture entity card, similar to this, (if possible) I’d like to continue to use a single card (does not have to be a picture entity card) but every 5 seconds (or whatever time desired) to switch to the next camera view.
Here is a copy of my yaml for my current single camera picture entity card (not sure if that can help).
thank you very much in advance!!
show_state: true
show_name: true
camera_view: auto
type: picture-entity
entity: camera.side_yard
any and all advice is appreciated!
Use a swiper card and tune the auto play parameters.
A good code example here to get you started: Lovelace: Swiper card - #283 by CrocMonster
I have the same set up for three cameras too…
hi BenM7, thank you for all this information! I am in the midst of setting it up, I believe I am getting, please see below, Also, it does work to swipe with my fingers between the two cameras.
One more step I am looking to do, but I am still getting wrong. How do I set it up (for example) to automatically switch between those two cameras on my dashboard? I believe my code for ‘autoplay’ (delay and speed) are wrong.
Below is a screenshot of the one camera and yaml and also here is an exact copy of the yaml text as well.
thank you very much!
type: custom:css-swipe-card
parameters:
  effect: flip
  slideShadows: true
  autoplay:
    delay: 7000
  speed: 3000
  timer: 5
  scrollbar:
    hide: true
    draggable: true
    snapOnRelease: true
cards:
  - type: picture-entity
    entity: camera.driveway_camera_fluent
you might be best asking your question in the swiper card forum, I don’t autoplay mine sorry so I think im at the end of the line in terms of support for that part :slight_smile:
It’s my understanding the custom advanced-camera-card can be configured to do that:
Hi BenM7, thank you!!! I figured it out!!! I was using the wrong custom card :cry::cry:. I downloaded the exact one you showed me now (before I rushed and downloaded a similar one but not same.)
Please see my yaml for the card!!! THANK YOU!!!
type: custom:swipe-card
parameters:
  effect: null
  slideShadows: true
  autoplay:
    delay: 7000
  speed: 3000
  timer: 5
  scrollbar:
    hide: true
    draggable: true
    snapOnRelease: true
cards:
Glad to hear you got it sorted!
