Dashboard: Sonos card
Hi there. I love this card! Thanks so much for creating it.
Can you tell me how I change the colour of the round button on the volume slider? I can’t work it out! I just want to set it to white. Here’s my design if you’re interested:
Thanks in advance!
No idea actually. I’m not sure it’s possible.
Thanks - strangely when I view it on my iPad the button is white…but on desktop it’s blue! No big deal, thanks for replying.
Yes, that is controlled by the browser and device type. If we want to change it you need to “hack” it specific ways for every browser/device type.
Thanks - not a deal breaker so I’ll leave it as is :slight_smile:
I am having an issue with Brave browser…when you start playing music the screen starts shaking … no idea what causes that.
Hello, thank you @PunxsutawneyPhil for creating this. It’s been wonderful.
Does anyone have any advice for making the volume slider larger and give some space between it and the playback controls? I tried to make the player larger but it didn’t seen to have much effect. I have family members with larger fingers and I’m trying to make our dedicated Home Assistant iPad easier to use. Sometimes we accidentally hit the playback buttons while trying to adjust volume and other times we just miss the volume slider altogether. Works perfect on PC with a mouse, though.
styles:
  player-volume-range:
    height: 2rem
PunxaPhil - I like coffee :slightly_smiling_face:
Seen it a few times, but usually just in edit mode. Not sure what to do actually. You could try and play around with sizes with the different elements (using layout), or dig even deeper by making adjustments in css (using styles).
Example:
layout:
  mobileThresholdPx: 500
  groups:
    width: '20%'
    mobileWidth: '80%'
  players:
    width: '20%'
    mobileWidth: '80%'
  mediaBrowser:
    width: '20%'
    mobileWidth: '80%'
  mediaItem:
    width: '20%'
    mobileWidth: '25%'
Good suggestion, could you add a feature request in Github?
Will do. Do you mean in the ideas section? Discussions · johanfrick/custom-sonos-card · GitHub
Thanks again. Working well. I can’t get the coffee payment to go through but I’ll try again later.
What is the plan for “add support for non-Sonos players.” Something like what fork-daapd does?
I have some ideas on how to solve it. I’ll share more once we get closer to the goal :slightly_smiling_face:
Did you find a way to do this? I also need a way to navigate back to the dashboard home page.
With v5.8.0, it is now possible to add other cards to your Sonos Card panel using the new config option: singleSectionMode.
See https://github.com/johanfrick/custom-sonos-card#single-section-mode on how to use it.
FYI: @sdholden28 @raglandan @cowboysdude @abplus
Not sure what I’m doing wrong but I have it as basic as I can get it like this, this is just a test →
- type: horizontal-stack
  cards:
      - type: custom:custom-sonos-card
        singleSectionMode: player
And it’s still showing the entire player
sonos
My actual config is like this but still not working →
        allVolumesText: "All volumes"
        entityNameRegexToReplace: "SONOS "
        entityNameReplacement: ""
        groupsTitle: "My Speakers"
        groupingTitle: "Locations"
        mediaTitle: "Stations"
        noMediaText: "What would you like to hear?"
        layout:
          mobileThresholdPx: 750
          groups:
            width: 20%
            mobileWidth: 90%
          players:
            width: 20%
            mobileWidth: 90%
          mediaItems:
            width: 60%
            mobileWidth: 70%
          mediaItem:
            width: 28%
            mobileWidth: 80%
        selectedPlayer: media_player.sonos_pair
        backgroundBehindButtonSections: true
        skipAdditionalPlayerSwitches: false
        groups:
          order: 1
        players:
          order: 2
        player-body:
          border: 5px black
        player-song:
          color: "#000000"
        font-family: Times New Roman
        font-weight: 900
        mediaBrowser:
          order: 0
        title:
          fontSize: 26px
          fontWeight: lighter
          textTransform: uppercase
          color: white
Very strange. Could it be some browser caching problem?
Just for debugging, create a new dashboard without all that other config you have and add the example config from the documentation (https://github.com/johanfrick/custom-sonos-card#single-section-mode), and see if that works.
If it doesn’t work, Try clearing the browser cache for your home assistant page. It should not be needed, but let’s try anyway.
I cleared the cache made sure I had the right sonos card version and used the example config…
here is what I get…
Not recognizing singleSectionMode
OK so I solved it! :slight_smile:
On the integerations page you have to turn on show beta versions…as it turns out I only had 5.7 installed NOT 5.8.
Once I did that NOW it’s working at it should!!! :slight_smile:
Thank you!
Hi - I’m having the same problem you were having. I can’t see where the show beta versions is, can you share please? Thanks.
