Hi. just upgraded to 2024.9.0 and first got a message:
“Database upgrade in progress”
Then after a minute or so two other messages came in:
“Database Migration Failed”
“Recorder could not start”
What should a database noob like me do now? Revert to the version before the update to 2024.9.0 by restoring a backup? Anything else?
Is this a known bug already or on my end? Never had this issue before.
I am running MariaDB and InfluxDB. Most automations seem to work, but stuff like logbook, history, and the energy dashboard does not. Grafana seems to receive proper data from sensors through InfluxDB. I assume this is related to MariaDB.
I restarted both MariaDB and InfluxDB integrations.
Restarting Home Assistant triggers the data base migration, which always fails.
Logs and screenshots below.
Thanks for any ideas how to solve this.
Logger: homeassistant.components.recorder.migration
Source: components/recorder/migration.py:577
integration: Recorder (documentation, issues)
First occurred: 08:40:57 (1 occurrences)
Last logged: 08:40:57
Could not modify column MODIFY event_id BIGINT in table states
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1967, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 924, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/cursors.py", line 179, in execute
res = self._query(mogrified_query)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/cursors.py", line 330, in _query
db.query(q)
File "/usr/local/lib/python3.12/site-packages/MySQLdb/connections.py", line 261, in query
_mysql.connection.query(self, query)
MySQLdb.OperationalError: (1034, "Index for table 'states' is corrupt; try to repair it")
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 577, in _modify_columns
connection.execute(text(f"ALTER TABLE {table_name} {column_def}"))
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1418, in execute
return meth(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/elements.py", line 515, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1640, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1846, in _execute_context
return self._exec_single_context(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1986, in _exec_single_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
db.query(q)
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (1034, "Index for table 'states' is corrupt; try to repair it")
[SQL: ALTER TABLE states MODIFY event_id BIGINT]
(Background on this error at: https://sqlalche.me/e/20/e3q8)
and
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:981
Database error during schema migration
db.query(q)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 981, in _migrate_schema
new_schema_status = migrator(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 334, in migrate_schema_live
schema_status = _migrate_schema(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 300, in _migrate_schema
_apply_update(instance, hass, engine, session_maker, new_version, start_version)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 703, in wrapper
job(instance, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 883, in _apply_update
migrator_cls(instance, hass, engine, session_maker, old_version).apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 929, in apply_update
self._apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 1722, in _apply_update
_modify_columns(
return meth(
db.query(q)
