Datetime in To-Do list
Hello !
An option should be added to add a datetime to the todo ! In google tasks if the todo as a datetime, it activates a notification.
it directly adds another interest !
Just use the local calendar and an automation.
Personally, I need a notification in my smartphone when a calendar event ends. Google calendar doesn’t allow me to directly create a notification at the end of the event.
I need notification on my smartphone, but not just a push notification (because I’m able to delete it without reading), so a task is perfect! but with notify !
Maybe there’s another way ?
Personally I’d like to see due date as a datetime entity part of a to-do list. I think it would be great for house keeping tasks. For example I need to check gas fittings once a year, I could put that as an automation based on house-chores.due date == today, like flash lights, send notifications and display the title on a led matrix. Bonus points if we could make items reoccurring😍
Is that not what the calendar is for ?
When triggered you can add it automatically to the ToDO list.
As I have said in other posts, as written it is not a ToDo list … it is a shopping list.
If it truly aspires to be a ToDo List is is missing several things:
  1. Due Date
  2. Start Date (not creation date, start date)
  3. *** Dependencies on other ToDo’s ***
Now:
ToDo = Mow the lawn
Done Right:
ToDo = Mow the lawn by xx/xx/xxxx
Needs before:
ToDo = Buy gas by xx/xx/xxxx
ToDo = Sharpen mower blades by xx/xx/xxxx
ToDo = Chane lawn motor oil by xx/xx/xxxx
Without this, the integration is no more than having shopping lists. It ain’t “ToDo’s”
Related thread:
Check out Calendar - Home Assistant
  - platform: calendar
    event: end
    offset: "0:0:0"
    entity_id: calendar.work
condition:
  - condition: template
    value_template: "{{ trigger.calendar_event.all_day == false }}"
  - service: todo.add_item
      item: You're done {{ trigger.calendar_event.summary }}
      entity_id: todo.tasks
I use both :v:
