While in MySQL command, I noticed something that is 4 hours off:
| 2018-08-06 03:56:30 | -35.85 |
| 2018-08-06 03:57:30 | -35.97 |
| 2018-08-06 03:58:30 | -36.08 |
| 2018-08-06 03:59:30 | -36.2 |
| 2018-08-06 04:00:30 | -36.31 |
| 2018-08-06 04:01:30 | -36.43 |
| 2018-08-06 04:02:30 | -36.54 |
| 2018-08-06 04:03:30 | -36.65 |
| 2018-08-06 04:04:30 | -36.76 |
| 2018-08-06 04:05:30 | -36.88 |
| 2018-08-06 04:06:30 | -36.99 |
| 2018-08-06 04:07:30 | -37.09 |
| 2018-08-06 04:08:30 | -37.2 |
| 2018-08-06 04:09:30 | -37.31 |
| 2018-08-06 04:10:30 | -37.42 |
| 2018-08-06 04:11:30 | -37.52 |
| 2018-08-06 04:12:30 | -37.63 |
| 2018-08-06 04:13:30 | -37.73 |
| 2018-08-06 04:14:30 | -37.83 |
| 2018-08-06 04:15:30 | -37.93 |
156 rows in set (0.01 sec)
MariaDB [home_assistant]> SELECT now();
| now() |
| 2018-08-06 00:16:18 |
1 row in set (0.00 sec)
MariaDB [home_assistant]> \q
Bye
hass@home-assistant:~$ date
Mon Aug 6 00:16:26 EDT 2018
The time zone for my Linux container and Home Assistant are both set to America/New_York.
The recorder is configured as follows:
recorder:
purge_interval: 0
db_url: "mysql://hass:[redacted]@127.0.0.1/home_assistant?charset=utf8"
exclude:
domains:
- automation
- updater
Even if both Home Assistant and MySQL showed me the correct time, why is the recorder writing 4 hours ahead of time for it to not show up in Grafana?
I’m using just a plain LXC container. No docker or virtual environment. Grafana and Home Assistant are able to communicate with MariaDB just fine. And just to be sure:
configuration.yaml:
homeassistant:
time_zone: America/New_York
And in Linux container command line:
hass@home-assistant:~$ ls -l /etc/localtime
lrwxrwxrwx 1 root root 36 Jul 16 10:44 /etc/localtime -> /usr/share/zoneinfo/America/New_York
