DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Seems like an issue with HACS. I would ask the creator of HACS or check their github issues.
V3.1.0 - Contains some much requested features & bug fixes
I spend again a lot of work on 3.1 😮‍💨 Please consider a donation :+1:
How to update
  • Update through HACS or download the zip and copy over existing files.
  • Reboot HA and CLEAR CACHE (browser and mobile app)!
V3.1.0 changelog
  • If you hide or disable an entity in HA itself it also now doesn’t show/load up in DD.
  • Re-programmed the homepage and devices page load so it must now load a lot faster.
  • The function that refreshed all areas on the background is also re-programmed from ground up. So DD also must now eat less ram from your browser/device.
  • You now can exclude entities from DD. This means for example if you got a temperature sensor you can exclude it from showing up on the area button as temperature value. Or if you got a switch that is always on like a fridge you can exclude it so you can don’t see it as on switch.
  • Added two new buttons in top of area edit view. You now can disable or hide all entities inside an area with 1 click. This way you can start by enabling the entities you want instead of the other way around with hiding/disabling all entities you don’t want (the way DD defaults works).
  • Only users with Admin (role) now can edit settings inside DD!
  • The order of the devices on the devices page is now also the order of the grouped device view on the homepage area view.
  • The order of the ungrouped homepage areas is now also the order of the grouped area view on the devices page.
  • Made it possible to hide/disable persons. If you disable a person it also doesn’t show anymore on the homepage house information card.
  • Always show all installed blueprints inside the blueprint select popup, only the usable blueprint is selectable in the popup.
  • Scene button now show last changed/triggered time instead of a timestamp.
  • Fixed a bug that climates with state “Off” showed as on in the house information.
  • Added Italian language.
  • Added Spanish language.
  • Fixed a bug with sorting not working in Firefox. This now works.
  • Fixed a bug that a horizontal scrollbar below the navbar was always visible on Firefox. It’s now hidden.
  • Brought back the function to double click on an area button to toggle all lights inside the area.
  • Added sorting functionality to favorites on homepage.
  • Added sorting functionality to more pages (on the more page itself and it also reflects the sorting on more pages placed in the navbar).
  • For extra large screens there are not 4 rows of more pages buttons on the more page.
  • You now can disable an area :slight_smile: including all entities inside that area. If you disable an area it is fully disabled in whole DD.
  • Support for Apexcharts Templates in DD itself and in the blueprints. Inside the blueprints you can use apexcharts_card_templates: and by hand you can use
    dwains-dashboard/apexcharts_card_templates folder and put your template YAML files inside that folder. After that reboot HA.
  • Added success message after installing blueprint.
  • Fixed bug with editing existing cards inside DD causes error related to input_entity and input_name.
  • Fixed a bug with multiple checkboxes inside a blueprint where not working. Now you can make as many checkboxes as you want.
  • Fixed a bug that when you got an alarm or weather entity set in global settings you couldn’t remove it. You now can remove/disable it.
  • Added some new theme variables for theming things: --dwains-house-information-badge-background, --dwains-house-information-badge-color, --dwains-info-badge-background, --dwains-info-badge-color.
  • In the blueprints select popup/modal the list of installed blueprints is now sorted on the type of blueprint.
  • If you click in the house information on a device like Open doors you now also see them grouped by area.
  • Made an option to hide device overviews on the devices page. Now you can hide them if you don’t want see a specific device overview.
  • If you open the popup of all on lights or on switches now you got a button at the bottom to quickly Turn off all of them.
  • In the devices tab om phone when press the 3 dots in edit-mode you didn’t get a menu with option’s but instead it will go to the page. This is now fixed.
  • When you add a card within a device overview you cannot remove it anymore through the UI the button Remove just did nothing. This is now fixed.
  • When you add a custom card within a device overview then it will be directly above the auto-entities no space in between. This is now fixed.
  • Added device_class smoke as binary_sensor class so it now also shows.
  • Fixed a bug where navbar was not sticking to bottom of screen on Android devices.
  • Added an option in the Global settings popup to go back to Dwains Dashboard v2 layout if you prefer that. So all pages 100% full width.
  • Added Polish translation.
  • Changed the checkbox styling of a checkbox fieldtype in a blueprint.
  • Added default_value for blueprint checkboxes (true which is checked or false is not checked by default).
  • Scene button now only has turn_on. It tried to turn it off and that is not possible causing an error.
New here with Dwains Dashboard?
This corrected itself when 3.1 was made available for download. Maybe just an oddity. I am up to date now. Thank you for everything again!!
So how is it going with v3.1? Pretty quiet here :stuck_out_tongue: Do you all notice it is a lot faster then 3.0? Also can you all please enable the HA analytics on your ha setup? :slight_smile: Thanks
I’m def noticing a speed improvement. I’m loving the dashboard, especially the drag and drop. Is there any way to add pic to the area cards?
Looking for the setting in 3.1 that let’s you wipe a dashboard to start with a clean slate. Am I missing something obvious?
Utility Meter now supports unique_id.
In 3.1. Go to an area. Then enable edit mode. Then you see 2 buttons Hide all and Disable all. Click on Disable all. Then you get all entities disabled and you can re-enable only the ones you want in DD.
Good afternoon, I’m not able to activate 3 entities of mine, it appears as hidden. can you help me with this?
Good Evening, I’ve got a problem with hiding persons. When I change them to hidden, they are not shown anymore under Devices => Persons, but they won’t disappear in the Home View.
Thanks for your help in advance, and of course for this awesome Dashboard.
Rock solid here. Thanks for all your hard work.
@dwains Just checking to see, were you able to correct the “Automations” showing “Automations” rather than “Unknown”? I have updated to the latest version 3.1, I have also drased cache, and this still seems to exist as a problem. Thank you for any response!!
Hi! Anyone know how can I make the same size entities cards?
In this case, I guess only adjusting the height.
Captura de Pantalla 2022-05-13 a las 7.14.46
Thanks!
i want to be able to hide an entity on say the “devices / lights” page BUT not on the page / area that the light belongs to
atm if i hide an entity it’s hidden from everywhere, any ideas of a work around or am i doing this wrong
cheers
Thanks Hopefully its faster :slight_smile:
How do you mean exactly?
@dwains I believe something is broken with “Group by Device” on the home page. Everytime I do it, the screen freezes and when I refresh, everything has disappeared from the “home” page. This doesn’t happen on the devices page. Do you or anyone here have any ideas?
I also wanted to add that when I delete cookies and restart browser. The home page goes back to normal. But again when I try to group by device, it does nothing, when I hit refresh on the browser window, it goes to the blank screen.
I have exactly the same problème since version 3.1 !!
Can you try 3.1.1 its in beta on hacs.
Can do. Will give it a try this evening. Thank you!!
