DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
The popup? You can create custom popups for any entity you want.
Looking to replace this
is this what you refer to as the popup? and if so, how can I replace the whole section with a picture at a glance card? Thank you in advance!
That is currently not possible.
Is it possible to add another level to the areas in DD3? For example, Area living room, lists all my sonos entites, but to organize the living room area and cleaning it for multiple entities, I would like to make a button/area card, that redirects to another view/page with all my sonos entites. I know it can be done with pop-ups, but would be nicer to use as a directory/folder navigation style.
Is there a way to make the cards transparent and add a background to mimic the homekit look?
Yes just change the HA theme.
Make a more page. hide it from menu. Then create card which links with href to that page.
I have tried but with the iOS themes but I don’t know how to change the color of the cards’ icons. They always stay orange.
That color is from your personal set color in profile you can set other color.image
This option is only available for the default theme.
I tried to add a blueprint dashboard, but I don’t see the Yam code input box. How do I solve this?
On my tablet on the wall
I keep pressing to order by device, i use fully kiosk browser
Every time it keeps coming back, and again i have to order by device
any updates on this? thanks
Hi. Is it possible to use pictures rather than icons on the area cards? I know you can set a picture on the actual area but this does not filter through to DD.
Cheers
Craig
I’m having an issue where the GUI is lagging, when I click a button it does the action like turning on a light but the GUI lags for over 15 seconds before it shows the action, I’m using HAOS on an i5 machine, is there something I’m doing wrong or is this lag normal?
Hi @dwains is there anyway of having the card icon change colour when a device is turned on eg. ceiling fan, light etc…?
https://gprivate.com/62d5u
Did you found something? I would also love to have it more configurable…
Hi!
I have problem with 1 climate entity (thermostat).
I have 3 electronic thermostats in home. 2 works perfect in dashboard (https://allegro.pl/oferta/glowica-termostatyczna-termostat-zigbee-tuya-9939504682) and 1 (https://allegro.pl/oferta/inteligentna-glowica-termostat-tuya-zigbee-wifi-12657551798) works as on pics bellow:
On area tile it showing temperature only when is set for “heat” mode. Others 2 showing temp. all the time, no matter what mode is set. How force it to behave as it should?
Maybe there is an option also to show on area tile actual temperature in room, not this set on thermostat?
This might have been asked or maybe simple but I can figure it out. What am missing to make the persons page work?
