DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Just remove the person and keep the user :slight_smile:
Really nice dashboard, thank you.
I am a bit puzzled on the temperature numbers for the individual areas (left lower of the area) where do they come from and how to change ?
The temperature indicated on the tiles of the rooms comes from the temperature entities you added to the room. If there is more than one, the average of all entities is used.
thank you. What config file should I edit
I have areas.yaml and entities.yaml
Areas is correct however entities is filled with what looks like a random collection of sensors
The entities.yaml file is automatically fed by the entities you have assigned to an area. In principle, you should not modify these files. To change the state of an entity, in an area select the three small dots at the top right and select edit. Then you can change the state of the entities using the three small dot on the entity.
Got it. Thank you very much.
As it seems now the latest HA version (december) will break DD (again). So I need to look into it. I will try to make some time for DD but i’m really busy with smarthomeshop.io product development for my UltimateSensor.nl
I’ve only just upgraded but it seems to be working fine on Windows 11. Will keep an eye on things and report back.
I am new to DD and I see a very odd behavior on my instance.
I use Nabucasa cloud, on HASS OS core-2023.12.3, and DD v3.6.0
I noticed that if I access the DD through the cloud, it takes a lot of time to react even when changing the state of an entity. Kind of freezes for 30+ seconds. If I navigate from DD to the HA settings page, the Cloud connection status says Connecting…
Sometimes I am getting connection Lost, reconecting message in browser, etc.
If I access it via the LAN, it appears is working fine.
Initially I would have said is the cloud connection, but if I avoid DD, I can do whatever I want in HA, without a single hick-up. Go figure…
Has anyone else seen this or any idea what may be causing it?
TIA
Hello I just installed your dashboards
It works fine, very nice ! except I caanot add a new page
I fill the page name item but I have this error
I forgot something ?
Love this concept as it makes it easy and I don’t need to get really fancy. The issue I’m having though is it loads really slow. Also some of the cards freeze and the only way to fix it is to reboot HA. Anyone else experience this and if so is there a fix?
Hello Dwain. Sorry to bother. But after December and January releases come with some issues to Dwains Dashboard. Unfortunately I know that you are busy with a lot of others things, but do you know when you can fix it ? Otherwise I’ll have to disable it and I don’t want :frowning: thank you so much
Hello Dwain,
thanks a lot for your work. It’s awesome! I have two questions:
(I asked those also on discord, FYI)
  1. I am using Scheduler Card. For some reason, I cannot shift the order in DD. Those arrows are missing:
  1. How do you name your entities? In the “rooms view” I would like something like “ceiling light”. Opposed to that, in the “Devices view”, I would then have many "ceiling light"s.
    Would it be possible to add the room as prefix in the entity view? I.e. I would call the entity “ceiling light” and DD would in the “Devices View” automatically display “{Room} Ceiling light”
Greetings,
Hendrik
Bumping this. If anybody could help me fix this id be extremely grateful!
If there isn’t a fix, Could anybody point me to where I might find the menu in the code to disable it permanently I don’t currently use it.
I really, really don’t want the task of moving away from DD especially because of a seemingly silly issue.
Which menu?
The menu that appears at the bottom on mobile/tablet “Home, Devices and More”. You can see it in the image of my original post.
Any chance you could point me in the right direction @dwains ?
Latest HA release breaks all my device icons in DD, have rolled HA back for now.
Same here, no more Icons in DD since latest HA release.
same here…
same here :frowning:
