That is my dashboard, you can’t just use things out of the design/dashboard standalone. Everything is build into 1 package. You either need to use my dashboard or make it yourself
@dwains It’s a Nest Hub Max, so clearing the cache is a bit difficult.
I use this blueaprint automation to achive this: Cast and re-cast a lovelace view to a Google Hub
You can try it yourself.
These are my settings in the automation:
This works with the default lovelace theme and dashboard after tweaking the resources (adding the resources that give a red box).
Here are some faqs about it: Home Assistant Cast - FAQ
Maybe this is the cause, but I don’t know much about this. This is a the bottom of the faq page:
Some custom cards rely on things that are only available in the normal Home Assistant interface. This requires an update by the custom card developer.
If you’re a custom card developer: the most common mistake is that LitElement is extracted from an element that is not available on the page.
Thank you Dwain for all your efforts in terms of this project, awesome work!
Is it possible to have more than one media_player (TV, Soundbar)/Lights (Ceiling, Floor lamp) in a Room? Tried with more_entities, but they won’t show up in Devices > Media Players/Lights when turned on.
Looking forward to any suggestion.
Thanks again!
Create a group and use the group?
I thought I am not able to control every device in a group individually I thought wrong…
Works fine, thank you!
Hello, I am discovering the customizing of DD and started to use more page and addons.
Can I also change the weather page that comes up by clicking the weather in the main view?
Have got the Atomic Calendar working - are you still having issues?
Thanks for asking, I greatly appreciate it, but the dashboard stopped loading at all. I don’t have much time to play with this stuff these days so I just uninstalled it. If you have a working config you could post, it may help someone else that was asking before I did.
I would like to come back to this in the future also so having something to look at to figure it out would be nice.
thanks
Find My now also in Dwains Dashboard!
Grap your copy now: dwains-dashboard-addons/more_page/find_my at master · dwainscheeren/dwains-dashboard-addons · GitHub
Here is the page.yaml content that I have - located in “config/dwains-dashboard/addons/house_information/calendar”
`# dwains_dashboard
## House-information add-on: Calendar
## Created by Jeroen Klompen
## Version: 1.1.0
- type: custom:dwains-heading-card
title: {{ name }} - type: custom:atomic-calendar-revive
style: |
ha-card {
border-radius: 5px;
background-color: var(–dwains-theme-primary);
.cal-titleContainer {
display: none;
showProgressBar: false
eventBarColor: ‘var(–dwains-theme-grey)’
dayWrapperLineColor: ‘var(–dwains-theme-grey)’
timeColor: ‘var(–dwains-theme-grey)’
entities:
{{ (data | fromjson)[‘calendars’] }}`
Note: It looks like the addon has been removed from https://github.com/dwainscheeren/dwains-dashboard-addons/blob/a584b00d9faca731f73d73592cc58f648dc04f59/house_information/calendar/page.yaml
I have then followed the instruction located here: https://marksie1988.github.io/atomic-calendar-revive/quickstart.html
Hope that helps - any questions - let me know, and will try to help
Hey everyone!
Has anyone been able to put multiple fans under the addon page? I’m struggling to do so. I don’t want to group them because I want to control separately.
Here is my code:
page.yaml:
# dwains_theme
## Created by Cameron
## Room add-on: FAN-control
## Version: 1.0.0
- type: vertical-stack
cards:
- type: custom:dwains-flexbox-card
padding: true
items_classes: 'col-lg-6 col-md-6 col-sm-12 col-xs-12'
cards:
- type: horizontal-stack
cards:
- type: custom:button-card
style: |
ha-card {
background: var(--dwains-theme-primary);
border-radius: 10px;
box-shadow: 10px;
font-weight: bold;
opacity: 0.8;
icon: mdi:fan
entity: {{ (data | fromjson)['entity'] }}
tap_action:
action: call-service
service: fan.toggle
service_data:
entity_id: {{ (data | fromjson)['entity'] }}
#speed: 'off'
state:
- operator: template
value: >
[[[ if (states['{{ (data | fromjson)['entity'] }}'].state === 'off' ) return 'on'; ]]]
styles:
icon:
- color: >
[[[ if (states['{{ (data | fromjson)['entity'] }}'].state === 'off') return '#grey'; return '#299ec2' ; ]]]
rooms.yaml
# https://dwainscheeren.github.io/dwains-lovelace-dashboard/configuration/rooms.html
resources:
- url: /hacsfiles/hass-bha-icons/hass-bha-icons.js
type: js
rooms:
- name: Main Bedroom
icon: mdi:lamp
light: group.main_bedroom
temperature: sensor.main_bedroom_temp
humidity: sensor.main_bedroom_humidity
media_player: media_player.samsung_un65ks8000
cover: cover.switchbot_curtain
more_entities:
entities:
- entity: cover.switchbot_curtain
addons: ## Room Page Extra Button
- name: Fan
icon: fas:fan
path: "dwains-dashboard/addons/rooms/mainbedroom/fan/page.yaml"
button_path: "dwains-dashboard/addons/rooms/mainbedroom/fan/button.yaml"
fans:
- entity: fan.main_bathroom_fan
- entity: fan.main_toilet_fan
Any ideas as to what I’m doing wrong?
You need to create a for loop and loop each entity
The calendar is back: dwains-dashboard-addons/house_information/calendar at for-dd-2.0 · dwainscheeren/dwains-dashboard-addons · GitHub
Yes. House_infornation is back!
What’s the reason why not all devices are in the right corner on top when the device is on?
I have several devices but the devices based on a sensor by example aren’t listed when they are powered on.
Update time!!!
V2.0.3 - Compatible with HA 2021.5
v2.0.3 is only compatible with HA 2021.5 and newer!
How to install 2.0.3 fresh (if you are new):
It contains some small core changes, not notable, compatibility with HA 2021.5.
How to update to 2.0.3:
If you are running 2.0.0, 2.0.1 or 2.0.2:
- Download version 2.0.2 and unzip the file.
- Inside this folder you will see a folder called
custom_components
copy this folder. - Go to the main folder of your Home Assistant installation. This is the folder where you config is. (Hint: its the folder where for example the files
ui-lovelace.yaml
andconfiguration.yaml
are located). - Paste the
custom_components
to the main folder of your Home Assistant installation and overwrite all existing files! - Make sure you are updated to HA 2021.5!!
- Reboot your Home Assistant
- Clear your browser cache on all devices
- You are done!
If you are running older version then 2.0.0:
First upgrade to 2.0.0 and then to 2.0.3. To upgrade to 2.0.0 follow this upgrade guide: Dwains Lovelace Dashboard | An auto generating Home Assistant Lovelace UI dashboard for desktop, tablet and mobile by Dwains for desktop, tablet, mobile
Please consider a donation
Everybody got 2.0.3 working with HA 2021.5 ?
yes, working here
Yup, no issues so far. Thanks!
Yes it is working. But not with the HACS method. This was giving some strange error
