Deako custom integration - version key problem
I am using a custom integration to control Deako lights (github) . Since the update to v2024.3 my integration is failing w/ the error “The custom integration ‘deako’ does not have a version key in the manifest file and was blocked from loading”
i checked based on the warnings and the manafest has a version key in it.
custom_components/deako/manifest.json
  "domain": "deako",
  "name": "Deako Smart Lighting",
  "documentation": "https://github.com/sebirdman/deako_hass_integration",
  "issue_tracker": "https://github.com/sebirdman/deako_hass_integration/issues",
  "iot_class": "local_poll",
  "dependencies": [],
  "config_flow": true,
  "codeowners": ["@sebirdman"],
  "requirements": [],
  "version": "0.0.1"
i tried a few things w/o luck:
  1. moving the “version” entry in the manifest, changing it from minor 0.0.1 to major 1.0
  2. the custom code is installed in custom_components/integration_blueprint. Following this version key comment, i tried renaming folder “integration_blueprint” to “deako”.
  3. option #2 but this time fully removed the custom integration and recreated it with the same target IP.
Followed by a HASS restart.
any other suggestions?
I’ve been using this integration (via HACS) for a few weeks and its been pretty stable - GitHub - DeakoLights/homeassistant_alpha
