Currently I’m using some Sonoff Zigbee Bridges (with the Tasmota firmware) to connect to my Zigbee devices (bridges are using MQTT to connect to Homeassistant). I would like to use some Zigbee devices outdoors as well, and to cut a long story short: the Sonoff bridge is not a good match because the wifi and zigbee parts in the same case and I’d like to put a cable between them (so I can keep the wifi part indoors, but have the Zigbee antenna/module outdoors). Hope this diagram makes it clear:
I’m reading good things about the Conbee II USB Gateway. So my question is: is it possible to have a Raspberry Pi + Conbee II gateway, integrated with my Homeassistant (which is running on another Raspberry Pi)? Can I use the deCONZ integration for that, or does that integration requires that the Conbee II gateway is plugged in directly in the Raspberry Pi that’s running Home Assistant?
Thanks!
