Deconz for Hass.io
I’ve setup DeCONZ with hass.io and I can see the xiaomi sensors I have, and that part is all working fine. Is there a way to have the temperature from these devices show in Home Assistant? I can see the temperature in Phoscon and also on the restapi response, but most of the devices only show battery level as an additional attribute, if that. I figured if I can pull back the temperature of window / door sensors, then I can use these with my boiler for automation.
