I didn’t had time for testing but I am quite sure that on HassOS we are not able to use /dev/ttyAMA0 from Deconz container. @marthocoo do you have suggestions on how to do some troubleshooting on that?
I am using @marthocoo add on and I have added Xiaomi sensors and Hue bulbs. Xiaomi works all the time, but I some times loose the connection to hue bulbs. I suspect it might be because I have one bulb, which is the closest to the Conbee USB, that sometimes is powered off from the switch so it is unavailable. This seems to cut off all the hue bulbs and all of them are unavailable.
Can that be something with deconz that if one is unavailable it deems them all that way or can it be because the bulb is a repeater and thus all of the other hue bulbs is rendered unavailable if the repeater goes offline.
I can’t seem to find a way via the add on to see the deconz interface where I would be able to see the zigbee mesh, but am I missing something there?
It makes a lot of sense as the bulbs become unavailable pretty quick after I power off the closest bulb. Last night it had overnight to heal, but that wasn’t enough. Is it possible to force a heal as with z wave?
The mesh should heal on it’s own. When routing fails new route discovery from the source node to the destination node will be started. This may take a while and prior to route discovery several attempts to send an request might be made.
Thats the theory
In practise meshing between different vendors has been challenging, the spec leaves some grey areas for interpretation so not all products work the same, mixing IKEA and Philips has caused troubles in the past. With firmware updates this will hopefully improve over time.
Is this still the easiest way to install DeConz om Hassio? I have done a new install based on HassOS and would like to continue where I left off with all my Xiaomi products.
I have the same problem, the current implementation of the add-on doesn’t support the 64-bit version of hass.io but it appears that they are working on it.
