deCONZ Integration not working after Setup (non-Addon): [pydeconz.websocket] Client connection error
My initial Setup is a Windows Desktop (before a Raspi4) with VirtualBox and HassOS + deCONZ Addon and Conbee II Stick, but with that Setup I had Problems for a longer time:
  • from time to time the the Connection failed (cbc_acm errors, like here) and I had to restart the VM
  • after Restarting I had to Restart the VM and Homeassistant sometimes to get the a Connection to deCONZs
  • I had to wait ~30min before I can use the deCONZ Web/VNC Interface, it seems the the System had to wait till the Conbee II Stick (Configuration tool) is discovered
  • I couldn’t add any more Lights (but Sensors), then the System would get stuck and couldn’t be used anymore.
  • I couldn’t rename anything the deCONZ Webapp, nothing is saved
Looks like most of the Problems are not present when using the Windows Dezconz Program, directly on the Host. So I tired to use the deCONZ Integration with the Host, Setup works fine and all Device are synced in HA
2021-02-06 22:43:09 DEBUG (MainThread) [homeassistant.components.deconz] Preparing linking with deCONZ gateway {'host': '192.168.1.253', 'port': 80}
2021-02-06 22:43:09 INFO (MainThread) [pydeconz.utils] API key: xxx
2021-02-06 22:43:10 INFO (MainThread) [pydeconz.utils] Bridge id: xxx
2021-02-06 22:43:10 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: s1
2021-02-06 22:43:10 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: s2
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.climate] Setting up climate.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.cover] Setting up cover.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.fan] Setting up fan.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.light] Setting up light.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.lock] Setting up lock.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.scene] Setting up scene.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.switch] Setting up switch.deconz
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.deconz entity: binary_sensor.lumi_sensor_magnet_aq2
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.extended_color_light_12
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.color_light_13
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.extended_color_light_14
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.color_temperature_light_3
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.tvlight2
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.extended_color_light_9
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.deconz entity: light.group_5
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.deconz entity: sensor.daylight
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.components.sensor] Not adding entity Daylight because it's disabled
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.deconz entity: sensor.s1_battery_level
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.deconz entity: sensor.s2_battery_level
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.on_off_plug_in_unit_10
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.test
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.t1
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.t2
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.powerpc
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.on_off_plug_in_unit_7
2021-02-06 22:43:10 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.deconz entity: switch.on_off_plug_in_unit_8
After that every Device is immediately Unavailable, Log (set to debug) only says “Client connection error”
2021-02-07 10:11:42 ERROR (MainThread) [pydeconz.websocket] Client connection error
2021-02-07 10:11:42 DEBUG (MainThread) [pydeconz.websocket] Websocket starting
2021-02-07 10:11:42 DEBUG (MainThread) [pydeconz.websocket] Reconnecting to deCONZ in 15.
Connection seems fine:
Removing the Integration and adding it again also works without a Problem
In the Debug View from the DeCONZ Program I can’t see any Connections from HA (beside my curl Request and the initial setup from HA)
If they go unavailable you have an issue getting the integration talking with deconz over websocket. Check you have set up hass correctly and that no firewall is blocking the expected ports
Thanks, if anyone has the same problem and don’t know the websocket port, check the deconz debug view after you connected to home assistant.
You just saved my bacon with this.
Feels so obvious in retrospect. Port 80 was open, but not 443 -_-
I think I’m in the same issue (no update in HA while sensor updated in Phoscon app).
Deconz and HA working on 2 separate containers on my Syno NAS.
I redirected both 80 & 443 deconz port to 8080 & 8084 ports of the NAS, and both are in allowed in the NAS firewall.
What do I miss?
Thanks for your help
R2
