deCONZ - Official thread
Does it happen every restart even after you’ve reloaded automations and it started working?
Open issue Deconz 2022.5.0: Missing button action in Ikea Tradfri 5 button remote · Issue #71329 · home-assistant/core · GitHub
Yes after every restart the problem occurs.
Then I reload the automations (deactive…activate), everything works.
then I reboot, then the problem is still there.
Hey guys.
deconz running good in my HA installation.
Just two questions:
  • How can i set an password for VNC?
  • How can i i disable deconz from spamming the log and save the life of my emmc?
    Dont get it how to configure loggiong :slight_smile:
It writes several entries in a few seconds, like:
20:11:31:356 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x1234
20:11:31:356 0x00158D00052BC4DA extract Xiaomi special attribute 0xFF02
20:11:31:356 	64 on/off 1
20:11:31:356 	01 battery 3042 (0x0BE2)
20:11:31:357 	04 unknown 5032 (0x13A8)
20:11:31:357 	06 LQI (?) 4294967296 (0x0100000000)
20:11:31:357 	Struct index 05 unknown (counter?) 417 (0x01A1)
20:11:31:357 	Struct index 06 unknown (counter?) 90 (0x5A)
20:11:31:361 ZDP get simple descriptor 0x01 for 0xD2EF
20:11:32:741 Set sensor check interval to 1000 milliseconds
20:11:32:795 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:11:32:801 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:11:33:741 Set sensor check interval to 100 milliseconds
20:11:36:998 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0001, ep: 0x02, frame control: 0x18, mfcode: 0x0000
20:11:38:341 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0102, ep: 0x01, frame control: 0x08, mfcode: 0x0000
20:11:38:940 sensor 103 (lumi.sensor_motion.aq2): disable presence
20:11:39:826 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:11:41:141 Set sensor check interval to 1000 milliseconds
20:11:45:812 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:11:47:281 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:11:56:481 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:11:56:489 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:11:56:734 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:11:57:241 Set sensor check interval to 100 milliseconds
20:11:59:276 Device TTL 2523 s flags: 0x7
20:12:01:453 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:12:02:440 sensor 103 (lumi.sensor_motion.aq2): disable presence
20:12:03:630 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:12:03:651 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:12:04:146 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:12:05:087 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
20:12:05:555 ZCL attribute report 0xXXXXXXXXXXXXXXXX for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
Thanks a lot
I suffered a system failure and I have to rebuild a part of my network.
I’ve been adding devices but I cannot seem to edit the device names due to errors in the UI. Not sure if I should post them here or somewhere else but here they are:
Uncaught TypeError: name is null
    getDeviceInfoMap http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/global.js?ef6aba:3
    getDeviceDevtype http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/global.js?ef6aba:3
    addOne http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-lights.js?598c57:3
    > Underscore
    a Backbone
    initialize http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-lights.js?598c57:3
    > Backbone 2
    setGui http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-lights.js?598c57:3
    <anonymous> http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-lights.js?598c57:3
    > jQuery 12
and
Uncaught TypeError: app.router is undefined
    edit http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-lights.js?598c57:3
    > jQuery 8
    > Backbone 6
and
Uncaught TypeError: sg is null
    initialize http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-sensors.js?117456:3
    > Backbone 2
    showSensor http://10.0.0.11:8123/api/hassio_ingress/.../pwa/js/devices-sensors.js?117456:3
Would be very happy for any helpfull comment :blush:
I think your question qould be better served over there: https://forum.phoscon.de/
This is just the addon for HA which serves as a bridge for HA<>deconz.
The actually routing zigbee magic is done in deconz itself.
Here are some hints on my experience with my zigbee network:
If an hub has poorly programmed firmware, it could be that it doesnt work very well as an zigbee repeater/hub.
For an example some “Paulmann” devices forwarding traffic very poor/slow.
Hue devices (lamps in my case) works very well as an repeater. Just place some physically in between the RaspBee II and nodes with weak signal.
That should help.
Hello all!
Another month comes with another release log on Phoscon forum for the HA deCONZ integration
As the beta has been cut I wanted to share what will be released with Home Assistant 2022.6.0
The refactor train building upon the rewrite of pydeconz continues. Still not much new functionality in sight though, but the code base is looking better and better.
Streamline setup of platforms
Move to using interface controls, next step in utilising pydeconz refactorization
Try the beta out and report any bugs you experience!
/R
Is this based on 2.16.1 which was released recently?
Thx
@pOpY Do not mix up Deconz (stand alone or HA addon) and the Home Assistant Integration. Robban maintains the Integration. The 2.16.1 release is Deconz.
Yup, blissfully free from maintaining the add-on :stuck_out_tongue:
Oh, sorry for mixing things up.
All of a sudden none of my lights are not connected anymore. Only a few Aqara sensor. How do I force connecting them? I really dont wont to repair 40+ light bulbs :confused:
Edit. I figured out. I bought a new TV (Samsung The Frame), and I placed the One Connect box next to my Rasberry Pi with RaspBee, and that seem to have caused the problem. I moved the Pi one meter, and that seems to solve it.
But out of curiosity: Why isn’t there a new version of the addon with the 2.16.1 release?
Also waiting for the addom update to 2.16.1.
2.15.3 had a rather annoying bug with scenes and Hue dimmer switches.
Also with Aqara sensors. I had to roll back to a previous version.
yeah, i also rolled back to 6.12.0 addon version (2.14 deconz version).
A PR has been raised to update the add-on. It’s just waiting to be merged.
Addon version 6.14.1 is now available!
i now notice this in the log, not sure what it is…
2022-05-30 21:42:14 WARNING (MainThread) [pydeconz.models] Unsupported device type Unknown
Great share a debug log file with me and I’ll add it to the supported list. I’ve tried to make sure the rewrite of the library becomes better over time. Creating these kind of logs helps me get more examples I can use for testing which is great
