Source Routing is an application based, alternate routing which is only possible between powerd devices. The way to the battery powerd switches and motion devices will be calculated via the old way.
The minimum LQI defines, which link should be considered for the route calculation from one divice to the next one. If you have a good network, you can use 150 and above.
The calculated routes will be stored in the application and primary used for communication.
Maximum hops is self explanatory.
Fast neighbor discovery is new for me as well but seem to be only good for the first, new route calculations.
I work with source routing for a long time and could solve all instability with that.
My recommendation to give it a try.
Before I spend a small fortune on a Philips Hue lamp (450 dollars)… Anyone running a Philips Hue Ensis on Deconz? Does it register as two colour lights? Most lights just work but I am unsure about this one.
I have some problems with the latest update 6.14.1.
some of my sensors (mostly aqara temp/humidity or sonoff door sensors) become suddenly unavailable and I have to pair them again. I restored a backup for now and will look if this happens again.
anyone else with problems on latest build? or do I miss something?
I cannot remember a release of HA or Deconz where we did not have a report of lost Aqara sensors.
It is not the release that is the problem. It is the fact that an upgrade means a restart. I sometimes see all my Ikea switches showing offline. Until I press then once which wakes then up.
You should try to wake up your sensors and switches first before you declare then disconnected and needing repairing. Battery devices sleep unless something happens that wake then up. Like pressing a button or opening a window. In some cases with some devices you need to short press the pairing button which makes then wake up but not doing a factory reset.
Thanks for your reply. I don’t mean that the sensors are gone directly after the upgrade. They suddenly go off one or two days after last state change. And I don’t want to press a button every two days
