@Robban - could I ask your guidance on this issue of mine:
So at the moment you don’t get any device support in HA?
Can we consolidate information to this thread and we might get some progress
Well, that issue is locked - with no activity for over a year.
It’s not locked and last comment was from me in august
Hi guys,
so now I had the situation again (deCONZ - Official thread - #3553 by jnc).
Pressing the button on the dimmer switch does not trigger anything in HA core but when listening to deconz_event in developer tools it indeed comes from the Add-On
de_conz log shows no errors and also in core there is just nothing de_conz related. Restarting HA core fixes the issue.
Worth mentioning is that this time (unlike before) it happened after power outage to the HA so my wild guess is that when HA started de_conz was not ready or the other way round. On the other hand if this was a fundamental communication issue between the containers we would not see the events fired and other de_conz devices would also not work.
Any ideas?
You were not clear in your answer to me when I asked if your automations uses device id or classic events. I hate the device id way with a passion. I know the event trigger is reliable and names predictable
Here is a complete automation for handling a 4 button Philips dimmer in my HA
- id: 'Bedroom_Dimmer'
alias: 'Bedroom Dimmer'
initial_state: 'on'
mode: queued
max_exceeded: silent
platform: event
event_type: deconz_event
event_data:
- choose:
# Normal ON dimmed
- conditions:
- condition: template
value_template: "{{ trigger.event.data.event == 1002 }}"
sequence:
- service: light.turn_on
entity_id:
- light.bedroom
brightness_pct: 50
# Long press full brightness
- conditions:
value_template: "{{ trigger.event.data.event == 1001 }}"
sequence:
entity_id:
- light.bedroom
- light.bedroom_desk
- light.background
brightness_pct: 100
# Increase
- conditions:
value_template: "{{ trigger.event.data.event == 2001 }}"
sequence:
- service: deconz.configure
entity: light.bedroom
field: "/action"
data: {"bri_inc":254, "transitiontime":50}
# Decrease
- conditions:
value_template: "{{ trigger.event.data.event == 3001 }}"
sequence:
field: "/action"
data: {"bri_inc":-254, "transitiontime":50}
# Stop increase/decrease
- conditions:
value_template: "{{ trigger.event.data.event in ( 2003, 3003 ) }}"
sequence:
field: "/action"
data: {"bri_inc":0}
# Off
- conditions:
value_template: "{{ trigger.event.data.event == 4002 }}"
sequence:
- service: light.turn_off
entity_id:
- light.bedroom
# Off long press
- conditions:
value_template: "{{ trigger.event.data.event == 4001 }}"
sequence:
entity_id:
- light.bedroom
- light.background
#default:
Note that the service call like this assumes deconz GROUP. Syntax differs for single lights for increase and decrease and stop
Sorry for not being clear -
I am using device id. I understand your point with them being random hex number but unless the device changes (which pretty much does not happen in years) they stay so I don’t care.
device_id: fd2cda60688bbce3d1e7c009b616bb2a
domain: deconz
platform: device
type: remote_button_short_press
subtype: turn_on
I had the same issue. After a reboot of the machine where HA is on, the Philips switch using device_id (generated by the visual editor) did not work. Only after restarting HA core the switch was working as expected. Now I changed to deconz_event (and pyscript) and that is working much better. My event handler:
@event_trigger("deconz_event", "id==soverom")
def sw_sytse_handler(event=None, **kwargs):
# log.warning(f"sw soverom: {event}")
if event == 1000:
light.turn_on(entity_id=Lampen.sytse, transition=switch_on_time)
if event == 2000: # up
light.turn_on(entity_id=Lampen.sytse, brightness_step=10)
if event == 3000: # down
light.turn_on(entity_id=Lampen.sytse, brightness_step=-10)
if event == 4000:
light.turn_off(entity_id=Lampen.sytse, transition=switch_off_time)
I use the x000 event, as I assume that is the press button, and x002 is the release?
Hello all!
Another release of Home Assistant so here comes another release log on Phoscon forum for the HA deCONZ integration
Just a small PR that fixes a change in deCONZ API, Air quality sensor PM reporting was broken out to its own type.
Here are the changes coming with
Home Assistant 2023.12.1
Home Assistant 2023.12.0
Cheers!
/Robban
For feature requests of the integration post an issue at pydeconz github
I’m on Github Sponsors if you appreciate my work.
It is very nice to have these updates, but why does not my deCONZ update? I still have 2.22.02 with my Conbee II and my Home Assistant is 2023.12.0. I ordered Conbee III, because the migration should be easy. Unfortunately, the easy migration process requires 2.24, which I do not have. How can I update my deCONZ?
Dear Community!
After the need to set up the deconz integration new, I wondered why it only found 5 devices on the first attempt (there are much more).
Then I clicked again to add a hub, kept the phoscon device’s IP (a Raspberry Pi 2 with ConBee 2 HAT) and was happy to see that more devices were found. However, these now appear under a separate hub (despite it is the same device/IP). Well, I added the same hub again - and guess what? Yet some further devices were found; however, of course again under a separate (but actually the same) hub.
Maybe I did something wrong, but shouldn’t the integration find all devices all together in one attempt?
You cannot see this, but the 5 devices (5 Geräte) are all the same. Why the last shows 1 entity (1 Entität) but the previous last three do not, I have no clue. Some of the 5 devices are among the 15 devices (15 Geräte) shown in the second row, none of them are among the 42 devices (42 Geräte) in the first row.
Is there a way to merge these? If yes, how?
Or is merging in the end not necessary at all? Well, I would like to have it “clean” but if it is just “cosmetics”, maybe I should not bother.
Anyway, thanks a lot for sharing your thoughts on this.
when does deconz update to the new version, where we can use conbee3?
Not sure what you mean with setting up deconz new. If you just removed the integration from HA then all the devices you see in Phoscon also show up in HA
So I assume you started all over with factory reset Conbee or Rasbee
You should only add the hub once in HA. What happens is that you keep on creating a new hub connection with a new key. Delete them all and only add it once inside Home Assistant. Make sure to restart home assistant after you removed the last hub before you add it again.
To pair devices you need to Add New Lights or Add New Plug etc from the Phoscon app. Devices need to be in pairing mode. You need to find out how as the procedure is very different. If you did not unpair the device before then they need to be factory reset to pair again. Usually by long presssing the button. Philips Hue bulbs are reset by using a Philips 4 button remote and holding it really close to the light bulb and press on and off simultaneously for a long time until the bulb flashes.
If for some reason not all devices in Phoscon are loaded into HA try to restart HA. That often solves things.
see this post :
Sorry that my post was a bit unclear. I had no problems with the devices (lights, switches, plugs) on the phoscon/deconz side, but many of my devices were not caught within HA when adding the deconz integration.
But your reply helped me, as I then understood that the multiple instances of the (deconz) hub are due to each getting a new key, which is of course not what I want. The essential hint from you was to “restart home assistant after you removed the last hub before you add it again” - thank you!
I have given up hope with deCONZ updates. Also, ZHA seems to be much nicer and it works with Conbee III.
yeah, but with 100+ devices I dont want to start over. I will wait a little. Its christmas time so… maybe:-)
That depends on how you run deconz.
Hi guys, looking for advice: I am thinking about moving my deCONZ from HA Addon to external device (docker on RPi) to decouple deCONZ from my HA. I tested now and the migration worked flawless, deCONZ is now running outside of HA and all entities are available. However some of my automations are based on events and it seems the these are now not fired. When I go to Developer tools - Events and want to listen to events there is no deCONZ available.
Am I missing something?
Do you mean deconz_event?
