You may have to reboot your pi.
If they configured like mine did, look for entities named light.(whatever-you-named-it) for the switches.
Thanks for your reply,
tried to restart HA and still not showing up as entities in HA.
if I go to Configuration --> Intigrations --> deCONZ Zigbee gateway, all i get is a message at the top “This integration has no devices.”
anyone any ideas?
edit:
sorted the above, it turned out that the authentication wasn’t valid so had to delete the entity deCONZ and go to the phocson app to authenticate an API for 60 secs then re-add the deCONZ app. then all is good… untill it dropps the API key and i need to do it all over again… twice today…
Updated from HA 0.101.1 to 0.103.4 and Deconz add-on 3.8 to 5.0.
The devices were first not available in HA after the upgrade to 5.0 (but working and available via the Phoscon app) but after a restart of HA everything is working fine again. Thanks for all the effort you put into this
I did it the same way. Updated from HA 0.101.1 to 0.103.4 and Deconz add-on to 5.0. Unfortunately my Deconz devices are still not available in HA, but working and available via the Phoscon App. I have restarted HA several times incl. Host reboot. Nothing helps. Only when I restore my old Deconz instance to v.3.8 all work’s fine again. Any idea what else I could do to get Deconz v.5.0 running in HA?
ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.32.1
Have you checked these troubleshooting tips and did that help? https://github.com/home-assistant/hassio-addons/tree/master/deconz#troubleshooting
I just updated to HA 0.103.4, Deconz to V5.0 then I restarted HA.
No issue to notice
I just noticed my automation behind the alarm doesnt work. It should be triggered when one of my window/door sensors are triggered.
I noticed that some of my window/door sensors (xiaomi mijia) are not giving feedback, even though in deconz it shows connected and refreshed few seconds ago… but why is it not reporting open, of boulean to true… que…?
Okay, this is just weird:
After upgrading to deconz 5.0, everything now works again after a complete ripdown and reinstall except:
Phoscon web interface Gateway page is blank when I use the HA sidebar menu selection with Chrome, works okay with Firefox (yes, I’ve cleared cache MANY times), works okay with Chrome when I access Phoscon App directly at port 40850.
Thanks, that’s it. Now everything works again with Deconz 5.0
Hi, I have installed succesfully deCONZ HASSIO addon on 103.4.
For various reason on the same LAN I do have 2 HASSIO installation. Is it possible for the other HASSIO installation to “see” the deconz integration of the other HASSIo with deCONZ?
When I had deCONZ on a separate host with debian/raspberry I would simply click Authenticate APP, and the deconz integration would be picked up immediately by HASSIO (from the debian/ubuntu instance).
But now if I click Authenticate app in the HASSIO with deconz stick, this is not picked up by my main HASSIO
Can this be solved?
Does anyone knows if it now is possible to run a pi4 with a ssd drive, conbee and deconz?
Hi @Torbenan,
Currently there are known issues with conbee usb stick and external ssd. There is an issue raised for this matter. Also someone mentioned a workaround to get this to work.
I don’t think it hass an issue with RaspBee instead of Conbee. I run rpi4, raspbee, deconz and hassio. Never had an external ssd yet hooked up…
https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1803
I did that with a pi3, seems no problem
That must be an RPi 4 related issue then since I run my RPi3 off a USB SSD and have both a Conbee and Z-Wave USB stick plugged in and have no problems.
It’s usb3 related
I’ve had all of theese combination working:
- Hassio, Conbee 2, PI4 and SD Card
- Hassio, Conbee 2, PI3 and SSD
- Hassio, Conbee 2, PI3 and SD Card
The only combination that did not work was
- Hassio, Conbee 2, PI4 and SSD. This is what I want for speed and stability.
I found this.
Blockquote rkotulan commented 12 days ago
I had the same issue. My config is HomeAssistant Ri4 and SSD connected to USB3 port. Conbee2 in USB2. I put ConBee2 on extension cable (2m) and then Phoscon App connected to stick. Magic
I would really like a confirmation that this works as I think, I have already tried this. I did not work (as I recall) and I took my 4-5 hours to bring my system back to work.
With the RPi 4 (with other devices as well) it is always recommended to use an extension cable for the ConBee, as USB 3.0 can cause interference with ZigBee. Intel wrote an article about this issue:
Hey @frenck,
I have weird issue with addon v5. When I open the deconz side panel my gateway is no longer discovered. When I manually enter the port 40850 in the network section and open it in Firefox everything is working fine.
I have cleared cookies and browser cache and also tried in Chrome but issue remains. I have restartet hass, the deconz addon and also rebooted the vm running hass without success. Sidepanel is not able to connect to gateway.
Logs:
15:02:11:998 CTRL skip polling while permit join is set
15:02:13:034 CTRL skip polling while permit join is set
15:02:14:068 CTRL skip polling while permit join is set
15:02:15:103 CTRL skip polling while permit join is set
15:02:16:138 CTRL skip polling while permit join is set
15:02:17:171 CTRL skip polling while permit join is set
15:02:18:204 CTRL skip polling while permit join is set
15:02:19:237 CTRL skip polling while permit join is set
15:02:20:272 CTRL skip polling while permit join is set
15:02:21:305 CTRL skip polling while permit join is set
15:02:22:338 CTRL skip polling while permit join is set
15:02:23:375 CTRL skip polling while permit join is set
15:02:23:562 Current channel 11
15:02:23:570 Device TTL 3058 s flags: 0x7
15:02:24:409 CTRL skip polling while permit join is set
15:02:25:443 CTRL skip polling while permit join is set
15:02:26:476 CTRL skip polling while permit join is set
15:02:27:512 CTRL skip polling while permit join is set
15:02:28:548 CTRL skip polling while permit join is set
15:02:29:581 CTRL skip polling while permit join is set
15:02:30:612 CTRL skip polling while permit join is set
15:02:31:647 CTRL skip polling while permit join is set
15:02:32:681 CTRL skip polling while permit join is set
15:02:33:292 CTRL skip polling while permit join is set
15:02:33:371 CTRL skip polling while permit join is set
15:02:33:716 CTRL skip polling while permit join is set
15:02:33:958 CTRL skip polling while permit join is set
15:02:34:059 CTRL skip polling while permit join is set
15:02:34:751 CTRL skip polling while permit join is set
15:02:35:783 CTRL skip polling while permit join is set
15:02:36:816 CTRL skip polling while permit join is set
15:02:37:851 CTRL skip polling while permit join is set
15:02:38:884 CTRL skip polling while permit join is set
15:02:39:917 CTRL skip polling while permit join is set
15:02:40:950 CTRL skip polling while permit join is set
15:02:41:984 CTRL skip polling while permit join is set
15:02:43:019 CTRL skip polling while permit join is set
15:02:44:054 CTRL skip polling while permit join is set
15:02:45:088 CTRL skip polling while permit join is set
15:02:46:122 CTRL skip polling while permit join is set
15:02:47:157 CTRL skip polling while permit join is set
15:02:48:193 CTRL skip polling while permit join is set
Any idea?
Have anyone successfully managed to integrate this add-on to a second HA-server?
This used to work in before recent upgrades but I can now only discover/integrate the add-on within same hassio ecosystem (and not in my main HA server running on the same network but different hardware). Further detail in post 1077
I have noticed the same with Edge: The Gateway page is blank, but it’s ok with Chrome.
