Updated deCONZ to 2.05.58 and addet a new power switch (with metering) in Phoscon (this is registred as light?). Then restarted HA.
A new switch (switch.power_and_metering1) AND a new sensor (sensor.consumption_2) in HA appeared. The switch without the attribute for power consumption. The additional sensor with power consumption (the attribute "on:" is not possible to toggle).
Unfortunately I messed up my setup. I could not change the sensor/switch-name in HA, so deleted all switches in Phoscon (wanted a total fresh start) and the entries in config.storage\core.entity_registry.
Have uninstalled deConz. Installed once again, rebooted.
Now I can add switches to Phoscon but no switches and sensors are getting in HA. Did the latest HassOS 2.8 do something(?)
How do I totally clean deConz from HA?
Hey, sorry for that late feedback. I cought the flu and was in bed most of the time
The PR is good to go. Setting temperatures and showing the actual / target temp works.
Reporting from the device itself is a bit slow, but thats on deconz side.
I have been playing with my two power- consumption switches. The consumption functionality just came with the latest Deconz release. And I am finding some odd behavior.
In Phoscon I can’t find any sensor for consumption
My to identical switches are getting totally different consumption values for the same lamp (10W LEDD lamp).
I have restarted HA with the switches off. When HA come online the consumption for the power sockets showed 6.063 kWh and 24319.0 kWh. The I turned both switches on, and into one power socket (the 24319.0 kWh) I connected a vacuum cleaner on full power. No change in consumption appeared.
Those are some big values [pydeconz.websocket] Websocket data: {“e”:“changed”,“id”:“2”,“r”:“sensors”,“state”:{“consumption”:2.4324e+07,“lastupdated”:“2019-02-08T16:17:27”,“power”:2},“t”:“event”,“uniqueid”:“00:12:4b:00:08:b5:e1:35-01-0702”}
What can be deduced is that it is not the component that is at fault, but if it is the device or deconz I can’t say.
Hi everyone, I’ve been using deconz with a conbee since a couple of months ago (currently using the @marthocoo hassio addon)
I have read in the last release of HA that there is also ZHA component that supports conbee.
What is your experience with the ZHA component? Is it worth giving it a try?
I appreciate the feedback of deconz network representation, and it has helped me a lot to install my devices.
@foraster i’ve recently tried the ZHA component, and although they have made HUGE gains these past months, it still has device support issues. At least in the area i need it, Xiaomi/Aqara sensors. which apparently don’t conform to the standard really, why they are harder for developers to support. i hear deconz supports them fine, and i’ve been using zigbee2mqtt which has fantastic support for them, and I was even able to add support easily for a new device it didn’t.
Hopefully this year with the great work that, i forget his name, sorry, is doing, ZHA will be all we need and I can drop another link in my “chain” of devices/services
I have used Zha/Elelabs ZigBee Shield for couple months. I also have Raspbee/DeConz and zigbee2mqtt. Maybe because I started with ZHA and I am more used to it I like it the best for me. The weak part for me is that Elelabs Shield (they quit selling them) so I would love to get Raspbee to work with ZHA.
I have Xiaomi temp/hum/pressure sensors, waterleak sensors, door/window sensors, motion sensors … They all work just great in my system. Only with Xiaomi buttons/switches I have had problems with ZHA events.
i forget his name,
I think we are talking about dmulcahey here (David) - thanks for him; he has done excellent work with ZHA.
