Hello everyone. Is there any way to lower the time in which the state is turned on? Why does it take 60 seconds to turn off? I read that if I know the ip I can enter and configure it but I can’t find the ip. The router I use is from sonoff and it is configured in zigbee2mqtt. Thank you
EDIT: read it a bit and check the link to the youtube videos on ‘cooldown’ plus the solution by that OP…build it yourselves
I forgot to comment that the sensor I have is an aqara
