Default config error and no naba casa
Hi all any one have any idea on this.
Running hassio on pi4
Upgraded to it in January all has been fine keep everything up to date as realises are available.
Haven’t been doing much with home assistant of late so it just been doing its thing.
Couple of weeks ago could not access the app (I use naba case cloud) when outside of my network. Finally got round to having a look last night.
In the notification had msg saying
The following integrations and platforms could not be set up:
Please check your config and logs.
(Logs)
Setup failed for default_config: Could not set up all dependencies.
8 March 2021, 22:03:02 – setup.py (ERROR)
And I have no naba casa tab to select.
Any ideas
Config
Has the unchanged line default_config:
I also tried adding cloud: but that didm’t help.?
Many thanks .
update: still have this problem it seems to be caused by the router UDM and it started after a update of firmware on the router, putting old router back in resolves it as a test, any advise would be welcomed.
Did you resolve this issue? I just saw this in my logs today…
Yes not home assistant related in the end.
